33s or 35s with 4.10s? opinions please! - JeepForum.com
post #1 of 74 Old 07-23-2010, 12:30 AM Thread Starter
andrew c
I just bought a 2007 2 dr x, 6 speed, with 4.10 gears. i am buying a lift and gears this weekend and i need some opinions. i am keeping the 4.10s, so should i get 33s, or 35s? i am going to be driving it from Tx to Colorado to drive trails for a week and im concerned about power and mpg with 35s. im a college student and cant waste money experimenting! opinions PLEASE!
andrew c is offline
post #2 of 74 Old 07-23-2010, 01:10 AM
Warlord2
You would be more happy with 33" tires if you dont regear. When I had 4.10 gears and 35's with my 6 speed manual transmission it was tolerable and fine when its flat land, but any hills/headwind/towing it became a real problem. I lasted about 5k miles before I just had to regear, everyone at the time said 4.10 and a manual would be fine. That was back in 07 before people new any better and a lot of assuming was going around. If I had more accurate info I would of stayed with 33" maaayybe 34" tires atleast untell I new what I was getting myself into.
Maybe try buying some used 32-33" tires that have maybe 1/3-1/2 tread left or something so you can time the regear and needing new tires so they will get done around the same time..
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #3 of 74 Old 07-23-2010, 01:15 AM
MilitaryJK4455
2010 JK Wrangler
I run 35" tires with 3.73's and a six speed and I can easily maintain highway speeds at 18 mpg's.... With 4.10's you should be able to easily run 35's and be just fine And especially with you down there in the flat lands you would be happy with it.
MilitaryJK4455 is offline
post #4 of 74 Old 07-23-2010, 08:16 AM
1398653
2017 JK Wrangler
dont listen to these guys telling you to get 33s. If you plan on wheeling your jeep get 35s or 34s. 4.10s with manual and 35s will be fine. You wont win any races on the street but if you wanted to win races you would have bought a honda. I have 34s on 3.21 and it is liveable on the street. Off road it is not good enough for the wheeling I do so I am going to regear but I wuold think 4.10s would be fine off road. If you change your mind it is only about 1200 bucks for a reagear. Put 100 bucks a month away for a year and regrear. You can live with it for a year if you are not happy with performance. If you get 33s you will be ticked at your self and want bigger tires. now if you dont plan on wheeling than go ahead and get the 33s.
Steve, Allegany NY, 2017 JK Unlimited Rubicon
1398653 is offline
post #5 of 74 Old 07-23-2010, 08:32 AM
DeepSky
^ What they said. You can always regear if you really feel you need to.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #6 of 74 Old 07-23-2010, 09:21 AM
MilitaryJK4455
2010 JK Wrangler
4.10's with an auto will almost be ideal, not just ok... The ideal set up for 35's and a standard are 4.88's and that is in the low end of the performance side just above an ideal stock setting... My 3.73's are good offroad... I rarely use 4Lo and 1st gear, I always have to run in 2nd or even 3rd sometimes... Go for 35's bro You WONT regret it!
post #7 of 74 Old 07-23-2010, 11:58 AM Thread Starter
andrew c
Thanks guys! im going to 4 wheel parts to pick up a 2.5 procomp coil, and 35 inch km2s!
andrew c is offline
post #8 of 74 Old 07-23-2010, 12:04 PM
Dronac
35's with 3.73's and an auto? If it's managable, I may opt for that over 33's but what would my gas mileage look like? I can handle 17-18 mpg highway, but can't really afford to drop much more then that.
2008 Jeep JK X: auto trans, 3.73 gears, D44 rear, D30 front
Mods: 2'' Rusty's coil lift, Superchips 93 octane tune, Cobra 75 CB radio, 33'' Duratrac's, onboard air compressor
My Build Thread! ---> http://www.jeepforum.com/forum/f96/dronacs-build-thread-1104134/
Dronac is offline
post #9 of 74 Old 07-23-2010, 12:12 PM
Crasher
FWIW, I went with the 305X75R17 (34") MTRs from 4wheel parts. It's a compromise between 33s & 35s. With the 410s and an automatic it was ok for me. I added a superchip that guys rave about, but I didn't notice much change in performance. Keep in mind, though, that I'm not in need of a lot of power. I did regear to 513s which gave me better performance at the expense of 1 1/2-2 mpg. I wish I had kept the 410s for the economy. From this experience, I know you'll be fine with 34s and maybe ok with 35s.
2005 LJ, 112" wb, RJ60's, ARB lockers, Fox Coil overs, 40" Creepies
Crasher is offline
post #10 of 74 Old 07-23-2010, 12:24 PM
Dronac
What was your MPG before the regear?
Dronac is offline
post #11 of 74 Old 07-23-2010, 12:34 PM
No4x4Yet
Depending on gearing size and tire size you would be bringing the gearing back to factory. Larger tires have the same affect as putting shorter gears in.
No4x4Yet is offline
post #12 of 74 Old 07-23-2010, 12:38 PM
Imped
Imped's Avatar
I've had plenty of experience with the transmission you have, the NSG370. 4.10's and 35's isn't NEARLY as bad as most would expect due to the low gearing of the transmission itself. It's almost equivalent to 4.56 gears/35" tires and the older 5 speeds in most TJ's so you'd be fine with 35's.
OlllllllO
IndyORV
Imped is offline
post #13 of 74 Old 07-23-2010, 12:39 PM Thread Starter
andrew c
ok new question. MPG? once again im a poor college student. what could i expect from 4.10s on a speed with 35s vs. 33s?
andrew c is offline
post #14 of 74 Old 07-23-2010, 12:40 PM Thread Starter
andrew c
traffic situations(dallas), and highway hills in CO once a year?
andrew c is offline
post #15 of 74 Old 07-23-2010, 12:42 PM
JIMBOX
I've got a JK 4dr/w 33" tires, before I got about 17mpg, with stock 32"
Now I get about 16mpg, with 33", it varies all over !
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
33" tires , 35" tires , 4.10 gears , gear tire question , JK Wrangler , wrangler
what should i do need opinions ert9218 TJ Wrangler Technical Forum 2 11-05-2009 11:53 AM
Opinions please! 350 into a YJ YJyoungster YJ Wrangler Technical Forum 38 05-19-2009 12:38 PM
opinions please flys_yj YJ Wrangler Technical Forum 14 04-09-2008 07:37 AM
I need some opinions here Marine_Mike YJ Wrangler Technical Forum 7 03-21-2008 03:26 PM
need some opinions! 86comanche TJ Wrangler Technical Forum 1 12-08-2004 10:52 AM
