Are 315/70/17's 35's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Are 315/70/17's 35's?
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 02-02-2011, 10:40 AM   #1
trowand
2009 JK Wrangler
I've got a 2" Old Man Emu lift on my '09 Rubicon Unlimited and I'm about to get new tires. I've been wanting to jump up from my Rubi's stock 32's to 34's along with 1.25" or 1.5" wheel spacers. When I look up metric size tires, 305/70/17's come out to be 33.8" x 12" while 315/70/17's come out to be 34.4" x 12.4" according to some of the many tire size calculators online. I can only find ONE 305/70/17 that I like (Maxxis Bighorns) but there are MANY options in the 315 size which are bigger but I'm afraid they will be too big. So one of my questions is are the 315/70/17 what we commonly call 35's? Even though the calculators online call it 34.4" high?
'09 Unlimited RUBICON in "Detonator Yellow". Old Man Emu 2" Light Duty lift. 305/70/17 (34"x12"), 1.5" wheel spacers, Bushwacker Flat Flares, three sets of 100+ watt IPF lights. Four wheelin' in the Jersey Pine Barrens!
trowand is offline   Reply With Quote Quick reply to this message
Unread 02-02-2011, 10:48 AM   #2
dsjk
2011 JK Wrangler
my Goodyear Duratrac 315/70/17's measured at about 34.7 and like 13ins wide
dsjk is offline   Reply With Quote Quick reply to this message
Unread 02-02-2011, 11:08 AM   #3
gdub
2010 JK Wrangler
This should help...
http://1010tires.com/TireSizeCalculator.asp
2.5" Rock Krawler Stock Mod Lift : Bilstein 5100's Front & Back : Rock Krawler Discos : 35X12.5X17 Goodyear MTR/K's : ProComp 7089's 17x9 4.75BS : Poison Spyder Evap Skid : Poison Spyder Brawler Lite : Spiderwebshade - Trailmesh : Recon 10,500lb Winch : Olympic Rock Sliders : Hella Black Magic Lights
gdub is offline   Reply With Quote Quick reply to this message
Unread 02-02-2011, 11:34 AM   #4
Woodchuck
Woodchuck's Avatar
Here is how you do it:
Take first number (tire width - 315) and divide by 25.4 to convert to inches.
This is the width of the tire in inches (12.40).
Then multiply the result (12.40) by the second number (aspect ratio - 70) divided by 100.
This gives you the sidewall hieight (8.68).
Multipy sideway height (8.68) by 2 and add to the last number (wheel diameter - 17).
This give you the total tire height (34.36).
So this tire is 12.40 inches wide and 34.36 inches tall.
Hope this helps and is not too confusing
'08 Red Rock Unlimited Rubicon / AEV 2.75" Lift with Remote Reservoir Shocks / AEV Heat Reduction Hood / AEV Front & Rear Bumper with Tire Carrier / AEV Skidplates & Rear Corner Guards / Riddler Diff Covers / Mopar Enhanced Rock Rails / Warn 9.5ti Winch / Mopar Gas Cap Cover / 4.88 Gears / IPF 900xs Drive Beams / Eagle Eye HID Spotlights / Daniel Stern Headlights / 17" AEV Pintler Wheels with 35x12.5r17 BFG Mud-Terrain KM2's / Tuffy Security Drawer / sPod and Benchmark Dual Battery System / Cobra 75 CB / Lockpick with Front and Rear Cameras / Katzkin Heated Seats / Line-X Interior / Hitchsafe Key Vault / and a Trasharoo and a lot more little stuff or just stuff I forgot!!!
____oooo
[ l_,[____],
l---L -[OlllllllO-
( )_) ( )_)-o-)_)
Woodchuck is offline   Reply With Quote Quick reply to this message
Unread 02-02-2011, 11:58 AM   #5
2012Rubicon
OOOOrrr you can be lazy, post a thread asking, and have someone else do the math (I 100% perfer the latter)
[[NEW]] 2013 Jeep Wrangler "S" True Blue
[[OLD]] 2007 Jeep Wrangler.....2.5 TF Coil lift...TF Quick Disconnects...Bilstein 5100's...35's....Rancho Front/ Rear tire carrier...hi-lift jack..
2012Rubicon is offline   Reply With Quote Quick reply to this message
Unread 02-02-2011, 01:59 PM   #6
MrOrange
2009 JK Wrangler
To the OP, yes the tire in question is equivalent to 35's. A lot of tires measured in inches aren't exactly what they imply. Most 35in tires measure less and are just rounded up. If you go to any manufacturer's website, they will have a spec sheet breaking down the actual measurements of the tires.
'09 X Unlimited, 4WD, auto, half-doors, soft-top
RC 2.5" Series II BB, JKS Quick Discos, JKS adjustable front track bar
15x8 Unique 297 (Soft 8), Goodyear MTR/Kevlar 35x12.50R15
5.13 gears, ARB front locker, Currie front shafts
Bushwacker flat flares, Rubicon rails with steps added
MrOrange is offline   Reply With Quote Quick reply to this message
Unread 02-02-2011, 02:41 PM   #7
jstrubberg
2009 JK Wrangler
At 30 psi, mine are 34.25.
jstrubberg is offline   Reply With Quote Quick reply to this message
Unread 02-02-2011, 05:15 PM   #8
RescuedJK
my procomp extreme mt's measure out to 34.4"
01 xj 3" RC full kit. Rock sliders. Front n rear hitches. Black soft 8's on 31's
RescuedJK is offline   Reply With Quote Quick reply to this message
Unread 02-02-2011, 06:39 PM   #9
wh1plash
Originally Posted by gdub View Post
Hey thanks for that link, it just what I've been looking for this week.
Been wondering how exactly you tell what range of tire width is optimal for a certain size rim. For instance, how wide of tire I'd need for a 17x9.
2013 Wrangler 2DR Sport S, Soft top on 33's, Crush Orange
2010 Wrangler 2DR Sport S, Hardtop - SOLD
2010 Yamaha R1 LE, Rossi livery
wh1plash is offline   Reply With Quote Quick reply to this message
Unread 02-02-2011, 09:48 PM   #10
No_Return
Tires with the same (315/70/17) dimensions can vary by 1/2" or more in Actual Size.
Make sure you check the actual size with the tire manufacturer... Places like tirerack also have the actual sizes as well as a tool to compare.
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline   Reply With Quote Quick reply to this message
Unread 02-03-2011, 12:00 PM   #11
ChicagoGuy
KC4x4SAR Mission Director
ChicagoGuy's Avatar
It's not a hard and fast rule, but generally I look at rim size as fine for a tire 1 and a 1/2 times size. IOW, a 9" rim would be good for up to 9+4.5=13" tire.
- Bill (formerly VetteDriver)
ChicagoGuy is offline   Reply With Quote Quick reply to this message
