3-Lights came on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 3-Lights came on
Visit 1aauto.com For ShockTober Deals on Monroe shocks andAdvance Adapters SYE KitsFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-16-2014, 08:06 AM   #1
Trendsetter75
Trendsetter75's Avatar
2010 JK Wrangler
3-Lights came on
I was just in the parking lot idling and all of a sudden 3 dash lights came on. ABS, ESP, Traction.
2010 JKU (6-spd)
Trendsetter75 is offline   Reply With Quote
Unread 09-16-2014, 08:43 AM   #2
number40Fan
2014 JK Wrangler
A bad ABS sensor can cause all three.
number40Fan is offline   Reply With Quote
Unread 09-16-2014, 10:33 AM   #3
LVCapo
The Voice of Reason
LVCapo's Avatar
Could be a bad ABS sensor, could be bad clockspring, or the turnbuckle on your drag link might have rotated, or be borderline to begin with.
Eliminate the easiest first, align your wheels perfectly straight and look at the steering wheel. If it is offset to either side, straighten it using a 15mm wrench by loosening the bolts on the drag link turnbuckle and turning it a little clockwise/counter clockwise to move the steering wheel to 12 o'clock (get a buddy/spouse/girlfriend to watch the steering wheel).
If that doesn't work (or isn't the problem), hit the dealership for a diagnoses, but do the work yourself. There's guides (and Youtube videos) for fixing both the ABS sensor and clockspring issues.
LVCapo is offline   Reply With Quote
Unread 09-17-2014, 07:56 AM   #4
14Sport
2014 JK Wrangler
...or a loose connection or broken wire.
2014 JK Sport, auto, 35x12.5x17, 3.73s.
I jeep therefore I am.
14Sport is offline   Reply With Quote
Unread 09-17-2014, 04:33 PM   #5
floridajpr
My 2012 JKU had the same intermittent lights and it was just a loose battery terminal. There still could be a wheel sensor issue but I would check my battery terminals first.
The stinkin Christmas Tree light problem SUCKS!
Florida Native Cracker Just Tryin to Stay Above Sea Level
floridajpr is offline   Reply With Quote
Unread 09-17-2014, 04:42 PM   #6
14Sport
2014 JK Wrangler
Usually battery going bad or loose connection sends up 4 or 5 lights but I wouldn't rule it out.
