3.8 Supercharger Kit 07 jeep - Page 2 - JeepForum.com
post #16 of 49 Old 01-27-2007, 04:11 PM
Kyoseki
Inconceivable!
Kyoseki's Avatar
Don't forget to sell it with a couple of these emblems
Due to lack of interest, tomorrow has been canceled
Kyoseki is offline
post #17 of 49 Old 01-27-2007, 07:41 PM
Sweeney
Originally Posted by thundercat900
We are also prototyping a plug and play unit that will give us full control of fueling and timing along with several other PCM controls.....stay tuned...
When I get some dyno data I will show both engine HP and raw to the rear wheel data so there will be no "fudge factor" LOL
I put about 30 miles on it today around town and so far it's looking good. Very quiet and smooth power.
I'm not going to post too many Pic's of the current setup.....Don't want the competition to copy...
Good! I see too many people assume huge drive train losses so they can post a BIG horse power number.
Plug and play is good especially if it's supplied pre-programed (at least 90% of the way). We actually see greater than 100% power increase at 1bar boost on our BMW engines. Proper tuning is key.
Any thoughts on how much power the stock internals of the 3.8 can handle?
I still have my '98 TJ... been toying with turbo charging it but... well, it's way down the list.
So you know I some clue to this forced induction stuff, this is me and a buddy... a side gig for me... www.turbochargingdynamics.com
I look forward to seeing your progress.
Sweeney is offline
post #18 of 49 Old 01-27-2007, 07:58 PM Thread Starter
thundercat900
thundercat900's Avatar
we can hook you up with a nice Supercharger setup for yor 4.0 or even a 4.7 stroker kit and aluminum head if your interested
We were messing around one day on the engine dyno and bolted the supercharger i'm currently running on a stock 4.0l out of the junkyard. No fuel or timing changes...6 lbs and run it to redline 300+hp at 13.4 to 1 AFR. The 4.0 is one tough engine...we tried real hard to blow it up and the dam thing still run's as good as new
I wish they would have kept the 4.0L We are gonna miss it.
thundercat900 is offline
post #19 of 49 Old 01-27-2007, 08:09 PM
Sweeney
Thanks, but if I go FI on the jeep I'll build a turbo system from scratch... no offense
The 4.0 is tough like the old BMW 3.5. We're pushing over 400lb/ft of torque at the wheels from 3000 -5200 rpm and 400whp with our kits. This is with all stock internals with a MLS head gasket and studs.
Do you guys have a "delivery" date for the kit?
Sweeney is offline
post #20 of 49 Old 01-27-2007, 08:26 PM Thread Starter
thundercat900
Let me know when your ready to boost her, we have a plug in play unit that works really good.
either way i'm hoping to have the kit out by the end of next month. We are going to début it the second weekend of feburuary at the world of wheels car show in Birmingham Alabama http://www.worldofwheels.info/
FEB 9 10 11
post #21 of 49 Old 01-27-2007, 09:16 PM
ShockTherapy
Is this a handheld programmer, and can you mention who it is made by? Also, do you use your computer to modify parameters then load it to the programmer or can some of the changes be made directly from the handheld? Thanks!
ShockTherapy is offline
post #22 of 49 Old 01-27-2007, 10:21 PM Thread Starter
thundercat900
its not a handheld unit, It plugs into the factory computer and has preset programs based on your mods. Up to 6 different tunes can be selected via a switch. Updated tunes can be emailed to you and can be download into the unit via laptop ......or desktop for that matter.
Its a full tune...not just a Wide open throttle tune like most handhelds and such.
I can't release the name of it yet but after we get the testing done I will post up all the specs.
post #23 of 49 Old 01-27-2007, 10:22 PM
ShockTherapy
Sweet, thanks for the info.
post #24 of 49 Old 01-28-2007, 08:18 AM
Cobra Jeep
Well I dont have a JK, but I do have a YJ that I plan on strokeing in the next year or two, or when ever it starts crapping out on me (210K and still strong!) But I would like to have one of those super bling aluminum heads for it. Yall gonna have one of those on display at the W.O.W. show? I have never been to one, think I might go this year. I am just up the road in cullman.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #25 of 49 Old 01-28-2007, 08:49 AM Thread Starter
thundercat900
We should have one there. Give Bennie a call at the shop, he is the jeep engine guru 205-251-1472
post #26 of 49 Old 01-29-2007, 09:24 AM Thread Starter
thundercat900
3.8 jeep supercharger
120 miles so far and it keeps getting stronger. Engine computer must be learning my driving habbits and applying the throttle more agressivly
post #27 of 49 Old 01-29-2007, 12:39 PM
woolf
Interesting, I loved my avenger but am always open to new products.
woolf is offline
post #28 of 49 Old 01-29-2007, 10:21 PM
ShockTherapy
What size and injectors does the 3.8 come with stock (19lb or 24lb maybe?), and are they standard size injectors?
post #29 of 49 Old 01-30-2007, 10:08 PM Thread Starter
thundercat900
Well we cranked up the boost today. We are now running on production base kit boost levels. Testing diferent combo's and measuring air temps. There is not a lot of room under the hood and it seals up very well so not much air gets in or out. Hopefull I will be able to post up some dyno numbers soon
We should have the tuner tomorow and testing will begin soon on it.
post #30 of 49 Old 01-31-2007, 07:15 PM
Houdini
I know your boost level is relativily low, but has there been any discussion of charge cooling?
Houdini is offline
supercharger for those of us in CA? Cavi JK Wrangler Technical Forum 12 08-02-2007 11:28 AM
Jeep Tj Supercharger KEATSKI TJ Wrangler Technical Forum 44 02-12-2004 06:40 PM
4.0L supercharger TeraflexTJ TJ Wrangler Technical Forum 10 01-28-2004 11:31 PM
jeep supercharger Lyle36 YJ Wrangler Technical Forum 1 06-03-2002 08:05 PM
