3.8 engine oil - JeepForum.com
post #1 of 11 Old 01-06-2013, 06:39 PM Thread Starter
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
3.8 engine oil
We all know how the 3.8's like to burn/use oil, but are these engines made so bad that they would cause the oil to have a burnt/overheated smell/look to it after just 5000 miles? I had my oil changed at my regular Penzoil Quick lube and the tech stated that the oil smelled like it was burnt. I use Penzoil Platinum 10W30.
I have 41000 miles on the Jeep and it has never been overheated. Are the rings that bad? Clearances too loose?
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #2 of 11 Old 01-06-2013, 06:41 PM
jeeperjk
2009 JK Wrangler
Is 10W30 recommended for the 2011's? I know my '09 recommends 5W20. Not sure if that'd have any bearing on this, but figured I'd throw that out there.
jeeperjk is offline
post #3 of 11 Old 01-06-2013, 08:04 PM Thread Starter
michiganmaveric
Got Beer?
2011 JK Wrangler
N0t recommended but my dealer said OK and would not void the warranty if I take it to him for problems. 5W20 recommended, but I don't see where the weight would make a difference in the burnt smell.
Lifetime member #13
post #4 of 11 Old 01-06-2013, 08:58 PM
jeeperjk
2009 JK Wrangler
Eh, probably not, but I figured I'd ask. Would a thicker/thinner heavier/lighter oil not cause more friction/heat?
jeeperjk is offline
post #5 of 11 Old 01-07-2013, 12:53 AM
Rtone1583
2009 JK Wrangler
My opinion: Motor oil (for gas motors) is designed to operate around 350 F so, I would think, if it smells burnt or actually is burning that something bigger/worse is happening in the motor to get it over the operating temp and into the burning temp range, although I don't know what the burning temp is for motor oil. It may be worthwhile to have your oil tested next time you have it changed to see if anyting abnormal pops up.
Rtone1583 is offline
post #6 of 11 Old 01-07-2013, 05:29 AM
LIJeepJC
To say that an engine that has been around for such a long time and has been used in many different applications successfully, is "so bad" is a bit shall we say, wrong?
Are you sure the oil is burnt? Does the engine sound weird? What does your mechanic say? Not saying you are wrong, just being objective. Good luck
LIJeepJC is offline
post #7 of 11 Old 01-07-2013, 07:29 AM Thread Starter
michiganmaveric
Got Beer?
2011 JK Wrangler
^^^^^^Yes, the 3.8 has been around for a long time, but as noted they are known for high oil consumption. From what I have seen on the web sites they have a ring problem. I am just wondering if the tolerances are so loose that some combustion is bypassing the rings and overheating the oil.
I have never had an engine that when brand new uses oil from the get go. Although mine is not as bad as others I have read about, I am using about a quart per oil change, 5000 miles.
Haven't taken it to a mechanic, just going on what the oil change tech told me.
Lifetime member #13
post #8 of 11 Old 01-07-2013, 07:31 AM
Joevacs
2010 JK Wrangler
I think yall have all missed the key to this mystery. He took it to a Jiffy Lube ( or equivalent ) ...
Do you really trust what one of those guys tells you about ANYTHING ? Sure there are probably a few good ones, but on average those places have idiots working for them.
Just a thought. If your's is a good one , or if you know the guy that's fine. Not trying to offend, just pointing out what seems obvious to me.
I would recommend changing your own oil and use 5w30. A JK is about the easiest thing there is to change oil on. I changed mine a week ago. Took me about 10 minutes and that was mostly wait time for the oil to drain out.
2010 Rubicon, 4" lift, Currie control arms and trackbar, 40" Procomp MTR
Joevacs is offline
post #9 of 11 Old 01-07-2013, 07:54 AM
LIJeepJC
I missed the "JiffyLube" part of the OP's thread...
Honestly, take it to a REAL mechanic bro... Have them look at it. These guys that change oil at these quicky lube joints are bottom barrel when it comes to knowledge..
LIJeepJC is offline
post #10 of 11 Old 01-07-2013, 07:56 AM
LIJeepJC
I agree... I have read threads about the 3.8 and oil consumption. But please, take her to a mechanic that knows what they are talking about. That's all I am saying...
BTW, Maybe what he smells is oil spilled on the exhaust header, or some other hot part?? Just sayin!
Good luck!!
LIJeepJC is offline
post #11 of 11 Old 01-07-2013, 09:35 AM Thread Starter
michiganmaveric
Got Beer?
2011 JK Wrangler
In the summer I do change my own oil, but no garage in the winter means I take it to a quick lube. I have used this place for years and trust them. I did check my oil before going there and it did seem to look a little on the burnt side color wise.
Probably will not take it to a mechanic. Will drive it until the warranty is up keeping an eye on the oil level. Might do an oil analysis next change and see what they say.
No offense taken, as I know a lot of the quick lube places are really bad.
Lifetime member #13
