3.5 or 5.5 RK lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 3.5 or 5.5 RK lift
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRough Country Deals at JeepHut.comJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 04-24-2012, 11:31 AM   #1
cabotgsxr86
2010 JK Wrangler
3.5 or 5.5 RK lift
Ok i've been searching and searching. I can't make up my mind between the rock krawler 3.5 mid arm or the 5.5 long arm. I know one is a long arm and the other is not. I guess what im having trouble with is i am going to be driving the jeep every day of the week. And im wondering what the handling differences would be compaired to stock with the 5.5 long arm? I've also heard that these lifts actually give you more lift than advertised. So what do these lifts actually give u? And for those of you that have the 5.5 lift is it too much of a lift to drive on the street every day? I will be running 37" and 5.13 gears. And the rig will see a very good amount of trails.
cabotgsxr86 is offline   Reply With Quote
Unread 04-24-2012, 11:50 AM   #2
KrawlOff-Road
Vendor
KrawlOff-Road's Avatar
What type of wheeling will you be doing? The RK 3.5" lifts are a great height to run 37's. All RK lifts work well on the street for a DD. You will see more body roll with the 5.5" do to it just sitting up higher. They are great lifts though!
If you have any questions about them, feel free to PM, email, or call us at anytime!
-Jason
Serving all your "KRAWLER" needs...
Poison Spyder Customs, Rock Krawler, RIPP MODS, Dynatrac, River Raider, Warrior Products, Rock Hard 4x4, Poly Performance, Max-Bilt, TERAFLEX, and MANY MORE...
Tires-FREE SHIPPING!!
KrawlOff-Road is offline   Reply With Quote
Unread 04-24-2012, 12:00 PM   #3
cabotgsxr86
2010 JK Wrangler
Originally Posted by krawloff-road View Post
what type of wheeling will you be doing? The rk 3.5" lifts are a great height to run 37's. All rk lifts work well on the street for a dd. You will see more body roll with the 5.5" do to it just sitting up higher. They are great lifts though!
If you have any questions about them, feel free to pm, email, or call us at anytime!
-jason
a good bit of woods and mud riding. Also a bit of rock's but not a whole lot.
Unread 04-24-2012, 12:02 PM   #4
cabotgsxr86
2010 JK Wrangler
I just don't want to get the 3.5 and then feel it wasnt enough, and have wanted the 5.5.
Unread 04-24-2012, 12:12 PM   #5
DrHolliday
DrHolliday's Avatar
2011 JK Wrangler
Is this going on a 2 door or 4 door? The 3.5" can also be had in a long arm.
The reason I ask is the 2 doors tend to see more lift from the kits then the 4 doors. I have a 2 door with the 3.5" x factor mid arm and I was lifted over 5.5" front and 4.5" rear in actual lift. 37's fit great on the 3.5" lift.
2011 JK Rubicon 2 door 6-speed manual, 3.5" Rock Krawler Suspension lift, 1.25" Daystar body lift, 40x13.50R17 Nitto Mud Grapplers
My build thread
DrHolliday is offline   Reply With Quote
Unread 04-24-2012, 12:19 PM   #6
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Actually, RK offers both the 3.5" and 5.5" in an Long Arm setup. With the 3.5" you will have plenty of room to run 37's. Long Arm rides better than short arm, less lift rides better than more lift. With more lift you're looking at increased body roll, squat, and dive.
There are two options for the 3.5" long arm:
1.) Standard 4-link: essentially the same as your factory suspension just relocating the frame-side control arm mounts for improved geometry. It will be a good all around performer and provide you with the best on-road handling.
2.) 3-link rear end (triple threat long arm system): Utilizes a 3-link rear end suspension. It does away with the two upper control arms and replaces it with a single upper control arm in the center of the axle. This is arguably one of the best performing rear suspensions out there....off-road. It allows the rear axle to travel without binding so it has superior articulation compared to traditional 4-link designs. It won't be as nice as a 4-link for daily driver duties (increased body roll mainly) but I doubt you'll find any issue with it.
If you plan on installing either of these yourself, I hope your welding skills are up to par. The 3-link will require more welding as it places a truss over the differential of the rear axle. For my $ I'd go 3-link as you've said it will see lots of trails...there won't be much out there that can compete with you. Also, if you're spending this much coin on your lift, I'd go ahead and have a look at doing the coilover upgrade for the front suspension. Long travel shocks are expensive as it is, and when you delete the cost of the coil springs from either the 3.5 or 5.5 kit, you don't spend a whole lot more for significantly better performance.
From Rubicon to Icon - 4-link, Tons, Atlas Build
Build Thread
Need parts? Need product advice? Contact Jason at Krawl Off-Road
ArticRubi is offline   Reply With Quote
Unread 04-24-2012, 12:21 PM   #7
cabotgsxr86
2010 JK Wrangler
Originally Posted by drholliday View Post
is this going on a 2 door or 4 door? The 3.5" can also be had in a long arm.
The reason i ask is the 2 doors tend to see more lift from the kits then the 4 doors. I have a 2 door with the 3.5" x factor mid arm and i was lifted over 5.5" front and 4.5" rear in actual lift. 37's fit great on the 3.5" lift.
it's going to be on a 2 door. It will have front and rear aftermarket bumpers and a winch. If the 3.5 will actually give me 5.5 in the front and 4.5 in the rear. I would be more than happy with the rk 3.5" lift.
Unread 04-24-2012, 12:26 PM   #8
ArticRubi
Arrogant SOB
ArticRubi's Avatar
You'll definitely be happy with 3.5" Doc^^ is running 40's on his 3.5" and I'm on 35's, going to 37's. I've got aftermarket bumpers and a winch, RK uses progressive rate front coils which (in terms of added weight) are much less affected than standard rate springs.
Build Thread
Unread 04-24-2012, 12:57 PM   #9
cabotgsxr86
2010 JK Wrangler
Well let me ask this with the 5.5 long arm. With that much add height does it ever feel like its too much lift, as far as on the trails and in the rocks does it feel like its too top heavy? And lean too much?
Unread 04-24-2012, 01:38 PM   #10
ArticRubi
Arrogant SOB
ArticRubi's Avatar
I honestly can't comment on the difference between the 3.5" and 5.5" in terms of how much more body roll there would be, I'm running the 3.5" system myself and I haven't had any seat time in rig with the 5.5". Generally speaking, more lift = more roll/squat/dive, sorry I can't help much outside of that.
I'd recommend giving Rock Krawler a call, their technicians are very knowledgable and helpful and could definitely give you a good idea of the differences in handling characteristics of the kits. When you find out what you need, give Jason at Krawl-OffRoad a call and he'll set you up with a great price!
Build Thread
