3.21 v. 4.10 - JeepForum.com
post #1 of 10 Old 02-26-2007, 03:21 PM Thread Starter
Matthew Davis
3.21 v. 4.10
Hello,
Can somebody please explain to me the nuances between 3.21 and 4.10? What exactly does it mean? What are the advantages of one over the other? It seems gas mileage is significantly effected, what else?
Thanks,
Matt
Matthew Davis is offline
post #2 of 10 Old 02-26-2007, 03:26 PM
igofshn
Locked @ both ends
igofshn's Avatar
If you plan on doing any modifications to your Jeep, then you will definately want 4.10's.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 10 Old 02-26-2007, 03:42 PM
woolf
It is the final drive ratio. When your drive shaft makes a revolution, the rear end either makes 3.21 or 4.10. It is all a matter of matching your powerband, tire size, and final drive ratio. Go with the 4.10s, I personally see very little to no benefit with the 3.21s, the motor doesn't make enough power down there.
woolf is offline
post #4 of 10 Old 02-26-2007, 04:07 PM
Kyoseki
Inconceivable!
Kyoseki's Avatar
Other way around, for ever 3.21/4.10 revolutions of the drive shaft, the rear wheels make 1 revolution.
Higher numbers mean more torque, which means better acceleration, but typically worse gas mileage as the engine is more efficient at lower rpms.
Due to lack of interest, tomorrow has been canceled
Kyoseki is offline
post #5 of 10 Old 02-26-2007, 04:37 PM
SecondTJ
SecondTJ's Avatar
you'll want 4.10s, mileage aside
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #6 of 10 Old 02-26-2007, 05:39 PM
scottyc
I plan on adding some aftermarket seat covers. Thanks for the heads up!
scottyc is offline
post #7 of 10 Old 02-27-2007, 05:04 PM
2K1TJ
2K1TJ's Avatar
2K1TJ is offline
post #8 of 10 Old 02-28-2007, 10:51 AM
redrom01
JCOB-4-LIFE
redrom01's Avatar
Once you add those seat covers you'll be extremly happy that you got the 4.10 gears.
-Jeep History-
1992 XJ - '00 till '04 - RIP (thanks alot dave)
1995 XJ - '03 till '07 - Sold to the HUB
______o00o
/__l_l_,\____\,__
l_---l_l__l----[ ]llllll[ ]
._(o)_)__(o)_)--o-)_)__
-Current Jeep-
2007 JK Rubi (Steel Blue)
Searching for an MJ
|¯¯l,[___],
l---L--OlllllllO¬
=~~~==oo==
()_) ()_)--<>-)_)
redrom01 is offline
post #9 of 10 Old 02-28-2007, 10:54 AM
jeepers3
Just make sure you do not have side impact airbags (:
jeepers3 is offline
post #10 of 10 Old 02-28-2007, 03:13 PM Thread Starter
Matthew Davis
Dude, thats awsome.
Thanks for all the input everyone. This may sound odd but I never actually looked at my build sheet to see what I had. I assumed it was 3.21. It turns out that I have 4.10 due to the tow package addition. Yeah! I did not order my X, it just happen to show up on the dealer lot and had my requirements.
Thanks,
Matt
