285/70/17 with -12mm offset/4.5 backspace??? - JeepForum.com
post #1 of 5 Old 11-02-2012, 10:25 PM Thread Starter
bombero69
So I decided to purchase this wheel/tire setup 285/70/17 with -12mm offset/4.5 backspace/17*9 rim just wanted to know any thoughts,concerns or input don't want want to go bigger since I only have 3.21 and no lift.
Thanks
bombero69 is offline
post #2 of 5 Old 11-03-2012, 07:13 AM
TheBoss
On the road you will be fine. Off road disconnected sway bar you may rub your fenders stuffed. A leveling kit or spacer will fix that though cheap and easy. Your new tire size is only slightly larger in diameter than stock but is wider hence the need for the offset wheels. With 3.21 gears you will probably notice the lag due to the weight increase in tire combo. What tires did you get ? load range?
TheBoss is offline
post #3 of 5 Old 11-03-2012, 10:36 AM Thread Starter
bombero69
I looking at Duratracs on Vtec Raptors just wanted some input.
Thanks
post #4 of 5 Old 11-03-2012, 10:40 AM Thread Starter
bombero69
Like the look and don't mind them sticking out.
post #5 of 5 Old 11-03-2012, 10:56 AM
TheBoss
Compare weight of new vs old Duratracs are nice tires but be leary of heavy e rated tires with your gearing. Good luck.
TheBoss is offline
