Quantcast 265/75/16 tires on a JK - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 265/75/16 tires on a JK
Old 12-09-2008, 08:15 PM   #1
TraumaJunkie
Hey Guys,
I got my new rims and I want to install some 265/75/16 AT tires on a stock height 08 JK. I had one member here tell me that he had no problems with size which why I am considering these tires. Anyone else run this size tire? I think the gearing on my 08 is 3:23 and I have a 6-speed manual, any issues there with that combo? Any pictures of how this size tire will look? Thanks for all your help!
TraumaJunkie is offline   Reply With Quote
Old 12-09-2008, 08:33 PM   #2
JIMBOX
I'm putting a set of ProComp AT's and wheels on mine
Putting a set of Bushwackers on, at the same time
JIMBO
JIMBOX is offline   Reply With Quote
Old 12-09-2008, 11:34 PM   #3
devilsfiddle
reply
Thats nothing for a JK. Some folks are putting 33's on them with out a lift.
JK 08 X
devilsfiddle is offline   Reply With Quote
Old 12-09-2008, 11:50 PM   #4
alaskanthunder
I was one of them.
2007 JK 2-dr X | Steel Blue | 4.10 Auto D44
alaskanthunder is offline   Reply With Quote
Old 12-10-2008, 06:31 AM   #5
devilsfiddle
reply
Originally Posted by alaskanthunder View Post
I was one of them.
Right on..
JK 08 X
Old 12-10-2008, 04:49 PM   #6
stuart2410
Go with 285 i went with 265 and wish i had went with something bigger
stuart2410 is offline   Reply With Quote
Old 12-10-2008, 04:53 PM   #7
N2rock
N2rock's Avatar
265/75/16 = 31.6x10.4/16
That is no problem on a JK
for details and info on our JK's, check out http://n2rock.com
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline   Reply With Quote
Old 12-10-2008, 05:42 PM   #8
Avian
My stock rubi tires are 255/75/17. 265's arent much bigger at all.
Detonator Yellow JK-X
150w windshield mount long range KC's
bumper mount Hella 500's/ 130w KC drivers
Uniden Bearcat CB/PA
Mopar bumper
Moabs/ BFG KM's
Avian is offline   Reply With Quote
Old 12-10-2008, 07:22 PM   #9
TraumaJunkie
HeyGuys ,
Since I am a noob to Jeeps, i do appriecate all the answers!! These new tires are gonna cost big $$ so I want to make the right decision on them. It appears that the 265's will fit without issue, has anyone ran the 285/75/16 on a stock height 08 JK without any rubbing or any issues at all?
Old 12-10-2008, 10:03 PM   #10
DangFoo
Anti-Socialist Member
DangFoo's Avatar
Originally Posted by TraumaJunkie View Post
HeyGuys ,
That converts to standard at 32.8" height x 11.2" tread width, which is right about the threshold for largest tires on stock suspension without rubbing at full steer lock. There are plenty of guys running a 33" tire that's wider at 12.5" and some claim to rub lightly at full turn - it depends on the wheel offset or backspacing as well.
I'd have no hesitation about running 33s at stock height, unless you do a good share of wheeling beyond fire trails.
Post some pix - welcome aboard.
DangFoo is offline   Reply With Quote
Old 12-11-2008, 08:18 AM   #11
jimb66
265/75/16 AT are smaller than stock for the Sahara and Rubicon. Zero issues
jimb66 is offline   Reply With Quote
Old 12-11-2008, 09:06 AM   #12
Grimscale
I am running a set of TrXus M/T in 285/75 R16, but I'm using a set of Cragar Soft-8 16"x7" rims with 4" of backspacing. No rubbing at all, and with my 4.10 gears, the Jeep handles the added weight just fine.
I will be going with a set of Cooper Discoverer STT in probably a 235/85 R16 after these tires are dead. I'm looking to go tall and skinny, but stay within the 32" barrier for my warranty (local dealer won't warranty if I run "oversized tires")
Here's a pic of my rig when I got the new bumper (only thing missing from the pic is the CB antenna off the rear license plate holder).
Another view (with the stock bumper):
Grimscale is offline   Reply With Quote
Old 12-11-2008, 01:09 PM   #13
Matts02
Actually, your wheel and tire package on the rubicon are roughly 32.06 inches tall. The sidewall of the tire is not as tall as a 265/75, but the inch bigger rim offsets this. As someoned mentioned, a 265/75/16 is roughly 31.6 inches tall. The 255/70/18 wheel and tire package on the Sahara is 32.06 inches tall--same as the Rubicon. Some JKs come with 32" tall tires and 3.21 gears with the six speed from the factory, so you will be within spec. However, you will probably find 6th gear is useless on even the slightest grade.
Matts02 is offline   Reply With Quote
Old 12-11-2008, 02:14 PM   #14
b_c
i'm running 32's w/ a 6spd with 3.21...
...no problems here
(but no mountains, either)
b_c
Colorado JeepPeople
my 2008 jk build
greater love hath no man than this, that a man lay down his life for his friends -john 15:13
b_c is offline   Reply With Quote
Old 12-11-2008, 02:17 PM   #15
Avian
A Some JKs come with 32" tall tires and 3.21 gears with the six speed from the factory, so you will be within spec. However, you will probably find 6th gear is useless on even the slightest grade.
100% correct, lol. My jeep hates long hills and going top/ doorless above 65mph. Its a struggle to maintain speed.
Mopar bumper
Moabs/ BFG KM's
Glock Forum
