06-19-2012, 08:07 PM
#1
25K miles and eating a quart and half of oil in between changes
WTF? that seems excessive to me. My Land Cruiser has 180K on it and doesnt leak or eat a drop. Is this still breaking itself in or is this normal?
06-19-2012, 08:12 PM
#2
That's not normal at all. I go 5k between changes and it doesn't move on the stick. You can have something as simple as a clogged PCV system or a dieing motor.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
06-19-2012, 08:40 PM
#3
Location: Crown Chrysler Jeep Service Bay in Chattanooga
Folks will be along shortly to reassure you that it is not Jeep/Chryslers fault. If you have wheeled it, you deserve it for being hard on your vehicle but if you have only driven it on the highway, that is worse on it, so it should be expected.
That seems excessive to me, but I'm just an unhappy Jeeper, so take it for what it's worth.
Get some duck tape, lube it up and punch it in the nose. It's a jeep thing.
everything above this is my opinion
06-19-2012, 08:53 PM
#4
Junior Member
Not right at all! Contact your dealer and get it checked out.
'01 Sport, Silverstone Metallic Pearlcoat
5 speed. 4.0
BFG Mud Terrain 35 X12.5
4" Pro Comp short arm lift. LoD tire carrier/bumper. Warn front bumper.
#5
Park it on flat pavement after driving it for 10 to 20 minutes. Then crawl under it to make sure it's leaking and not coming out your exhaust.
06-19-2012, 11:10 PM
#6
Never been wheeled, it's the wife's rig. It doesn't leak. Frickin chrysler!
06-19-2012, 11:16 PM
#7
If it only has 25k it should still have warranty til 30k right? I'd drop it off and have them fix it.
06-19-2012, 11:23 PM
#8
Replace PCV value and switch to 5w30. Should slow it down if not stop it from using oil
2009 JK Unlimited
2000 WJ Grand Cherokee V8 sold at 251,000
The bitterness of poor quality remains long after the sweetness of low price is forgotten
06-19-2012, 11:25 PM
#9
Sorry I didn't see that last post. Chrysler doesn't care until its burning 1qt/1000miles
2009 JK Unlimited
06-19-2012, 11:36 PM
#10
Let it run low and it will. Lol Dump some comet cleaner on the top of the air filter and that should scuff the walls enough to get a qt every 1k miles.
06-20-2012, 12:04 AM
#11
I have one of the lifetime powertrain warranty Jeeps. They ran a consumption test and the tech told me 1qt every 1000miles is when they would replace it  I have never seen any stock car use that much oil either. In my experience the PCV valve is often the cause. I swear you have to be burning more oil then gas for Chrysler to care!
2009 JK Unlimited
06-20-2012, 12:09 AM
#12
Please explain to me how highway is worse for the car then wheeling
2009 JK Unlimited
06-20-2012, 12:48 AM
#13
I think he was meaning that you can't win for loosing. No matter what you do with your jeep it ain't right.
06-20-2012, 01:06 AM
#14
I was having an issue with this, called the dealer and they told me that the PCV has been going around 15k miles on the newer JKs and to bring it in and they would check it out. I did - they did, PCV valve replaced under warranty.
06-20-2012, 03:04 AM
#15
