2017 Navigation Update for 2009 Wrangler RER NOT 2017 Data - JeepForum.com
post #1 of 7 Old 08-15-2017, 02:35 PM Thread Starter
denverj1ms
I'm guessing you already know how the updates are not totally what they say they are but I just updated my navigation database to what was advertised as a "2017" update. After loading, I noticed some information that I had expected to be there was not so I checked into the disk I was sent.
On the install disk I found notation that this database is not 2017 but "2Q 2016". I had several back/forths with the HERE, INC. folks and finally they admitted that this was indeed the case. Gave me a song & dance about it taking 12-18 months to test before release. Not buying that but, since my old database was from 2012, it was still an update for me so kept it. FYI, the 2017 update CD installed version: N 1645 3.0.0 of the navigation database.
It took a while for them to even admit that; claiming that they don't know what Jeep does with the releases.
However be aware that this is the age of the information on the update in case you are tempted to shell out the $$ assuming that it really IS 2017 information.
Best, Jim
denverj1ms is offline
post #2 of 7 Old 08-18-2017, 03:26 AM
ohio79
2011 JK Wrangler
On the install disk I found notation that this database is not 2017 but "2Q 2016". I had several back/forths with the HERE, INC. folks and finally they admitted that this was indeed the case. Gave me a song & dance about it taking 12-18 months to test before release. Not buying that but, since my old database was from 2012, it was still an update for me so kept it. FYI, the 2017 update CD installed version: N 1645 3.0.0 of the navigation database. It took a while for them to even admit that; claiming that they don't know what Jeep does with the releases.
Best, Jim
I've been getting the update reminder for awhile in map update. Is it worth the cost of the update and if so can a dealer do the install. I have a $75 credit and was going to use it towards the maps
ohio79 is offline
post #3 of 7 Old 08-18-2017, 12:51 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Sometimes its worth it - the newest maps no longer have me running off grid on a freeway exchange built 6 years ago! Don't have the dealker do it - it takes an hour and they bill that. Its EASY to do yourself, use the credit for something you CANT do yourself (or is messy lol).
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #4 of 7 Old 08-19-2017, 12:48 PM Thread Starter
denverj1ms
I agree with 'jwmbishop'. You can pay shop to install but it is an easy self-install. Instructions provided with disks are easy to understand. Essentially: "Put disk 1 in & remove when done; then put disk 2 in & remove when done". If you already have the OS update installed - a simple check - you don't even have to do disk 1.
I didn't even have to sit through the disk 2 nav database update. Started it then went in for leisurely cup of coffee. Came back out to find it completed.
Also, I didn't mean to suggest that the update was not worth it, especially if your current version was old enough like mine was. Just wanted to make sure folks knew that the info was >1yr old and definitely NOT 2017 data.
Best, Jim
post #5 of 7 Old 08-20-2017, 08:02 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Mine came on USB thumb drive. Turn radio off, insert thumb turn radio on follow prompts.
post #6 of 7 Old 08-20-2017, 09:06 PM
JTPhoto
JTPhoto's Avatar
Where do you fellas get the maps update .. my 2008 has had software updates but never actual map updates.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #7 of 7 Old 08-21-2017, 03:13 AM
ohio79
2011 JK Wrangler
Best, Jim
Looked up the ordering process. Guess it's pretty popular because it's on backorder.
ohio79 is offline
