2017 JK Clutch Problem: Warning! - JeepForum.com
post #1 of 15 Old 08-14-2017, 04:34 PM Thread Starter
azhang253
1995 XJ Cherokee
Purchased a brand new 2017 Jeep JK back in February. The clutch has been making a some strange noises: a rattling at idle coming from the transmission and crunching nosies when depressing the pedal. I'm guessing that the issue is caused by a bad throwout bearing or slave cylinder. Apparently, this is not covered by my bumper-to-bumper, and all clutch related items are only warranted for 12k miles and I'm at 14K miles. I've read many places on different forums that people have had the same issue, some even at as low as 8k miles.
So far, the dealership has been unwilling to repair the issue. They've told me that they've greased everything up to quite it down, but it will come back. I've read online that there could be incorrect pre-load on the TOB (TSP 06-002-07).
Has anyone repaired this issue at home? I'm pretty technically inclined, but I'd like to know what the correct preload should be, the TSP just vaguely specifies washers. I've also read that National has Moog throwout bearing that are of higher quality. Does anyone have a part number? While I'm at it, should I replace my slave cylinder or clutch?
I must say, that I'm highly disappointed in this transmission. I will call Mopar today and see if they will create a case and fix it free of charge. I will keep you updated.
Video of the noise: youtube.com/watch?v=-fy67KPexKA
azhang253 is offline
post #2 of 15 Old 08-15-2017, 10:34 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Video of the noise: /watch?v=-fy67KPexKA
azhang253,
I'm sorry to hear about this with your brand new Jeep--did you already reach out to our Customer Care team on the phone? If not, please send us a private message with your VIN. While you are correct that the clutch warranty is 12 months/12K miles, we would be happy to look into this further.
Kori
Jeep Social Care Specialist
JeepCares is online now
post #3 of 15 Old 08-15-2017, 01:32 PM
Bill123
2016 JK Wrangler
Don't let something like this get away from you, regardless of whether JeepCares actually does anything to help you or not. This is a major drivetrain component, so you don't want to have to repair this on your own dime simply because it was potentially faulty from the factory. That's why there is a manufacturer warranty. Take it back repeatedly until they fix it. That will also ensure that everything is documented. If one dealer can't or won't do anything, take it to another one until they finally decide to fix it.
2016 Wrangler Unlimited
2.5" Teraflex Lift
305/70-17 Toyo Open Country AT2
Fuel Lethal Wheels
Bill123 is offline
post #4 of 15 Old 08-17-2017, 06:53 AM Thread Starter
azhang253
1995 XJ Cherokee
Update Post!!!!
Hello again JeepForum, got an update!
Yesterday, at around 2pm, I received a call back from the dealership service department. The mechanic I spoke to told the the issue was fixed. He told me, over the phone, that the issue was the clutch fork retainer clip (Iím not sure exactly which clip heís referring to, the clips that hold the throw-out bearing to the fork, or the little return spring that holds the clutch fork onto itís pivot point). I was told that the spring was replaced, the fork was greased, and the sound was 100% gone.
Strangely, when I received the statement of work, I didnít see anything regarding a clip, only grease, however; it may have been noted only as a part number that I donít know of fthe top of my head.
I picked up my Jeep from the dealership at 6:30PM, when I got off work. Unfortunately, after the vehicle warmed up (and Iím guessing as the grease was flung off) the issue was 100% back. I'm skeptical that anything was indeed fixed. I'm also getting worried about the condition of my pressure plate, since the pressure plate spins against the throw-out bearing, and I can hear a grinding noise when I depress the clutch pedal. The dealership service department reported that the throwout bearing was ok, however; I donít know how long it will stay OK. I realize that the clutch and pressure plate are wear parts, however; if they are damaged by a defective shifting mechanism, then they should be covered by JEEP.
I've taken another video of the issue. This video is taken only 18 miles after getting back from the dealership.
youtube.com/watch?v=53FwcGCMBNc (to watch, please copy and paste into browser, I don't have enough posts to post links)
Originally Posted by JeepCares View Post
azhang253,
Kori
Hi Kori! Thanks for replying to my thread! I highly appreciate your efforts to help. I've already contacted Customer Care (I had to contact them in order to get the dealership to even attempt to properly diagnose the issue, as it requires removing the transmission). I'm supposed to receive a call from my Case Manager today, but I will likely call him and the dealership at noon since that's my lunch break. I will PM you my Case number and VIN. **PM Sent**
post #5 of 15 Old 08-17-2017, 09:14 AM Thread Starter
azhang253
1995 XJ Cherokee
Update Again!
I got a call from my Case Manager, and it seems like Kori had updated him with info from this thread.
I will be bringing my JK back in for service once the dealership get one of their loaner vehicles back. I will updated this with more info once I get some!
post #6 of 15 Old 08-17-2017, 03:14 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
You're in good hands with the care team...
The clip is a shot I would take if I inspected and found it not there. Unfortunate miss. Let em have another aim.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
post #7 of 15 Old 08-28-2017, 09:11 AM Thread Starter
azhang253
1995 XJ Cherokee
Update on the issue: I'm still waiting for the dealership to have a loaner vehicle available.
post #8 of 15 Old 08-28-2017, 05:22 PM
Bill123
2016 JK Wrangler
Personally, I'm not as much of a fan as some are about the care team. Once they sell you the vehicle, they are pretty much done with you unless you really push it. I would suggest that you keep pushing them because they certainly aren't going to push it for you.
2.5" Teraflex Lift
Fuel Lethal Wheels
Bill123 is offline
post #9 of 15 Old 08-29-2017, 03:00 PM
PootKlopp
What state do you live in? Could qualify for lemon laws that can help if their is a problem with transmission.
PootKlopp is offline
post #10 of 15 Old 08-30-2017, 10:14 AM Thread Starter
azhang253
1995 XJ Cherokee
Update!
I have no plans of letting up, I will keep pushing until the issue is fixed! I am documenting my experience here, but I will document it on Facebook, Instagram, my Dealership's facebook page, and other forums should it come to that.
HMM, I live in Michigan, I will look into this!!
A small part of me wishes I was able to find a lower mileage TJ with an AX15 for a good price, I feel like I trust the 4.0/AX15 a lot more than the 3.6/NSG370 combo. I've got a 95 Cherokee with zero transmissions issues (just LOTS of rust and it had a cracked head, which I've since replaced).
Update:
Got a loaner car and took the JK in for service again today. The last loaner I got was a Trailhawk Renegade. That was a pretty cute and cool little car. This time I got a 2WD Patriot. I can't help but wonder what the point of a 2WD Jeep is haha. The patriot is way better on gas though, my JK get 16MPG Highway.
post #11 of 15 Old 08-30-2017, 04:25 PM
John Strenk
John Strenk's Avatar
1976 CJ5
... This time I got a 2WD Patriot. I can't help but wonder what the point of a 2WD Jeep is haha. The patriot is way better on gas though, my JK get 16MPG Highway.
Around here we call that a mail truck....
John Strenk is offline
post #12 of 15 Old 09-12-2017, 02:26 PM Thread Starter
azhang253
1995 XJ Cherokee
Update!!!!
I just got word from the dealership today that my Jeep was ready for pickup.
I picked up the Jeep, and so far have only driven it 20 miles. The problem does seem to be fixed, and the clutch engages must smoother (funny how slow deterioration is always undetected). The dealership replaced the clutch, pressure plate, throw out bearing, clutch fork, slave cylinder and master cylinder.
Thank you Chrysler for fixing your product. I appreciate the customer service. I also hope that this fix lasts longer than 14.5k miles.
Will report back after I've put some miles on the transmission.
post #13 of 15 Old 09-12-2017, 03:10 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Glad to hear you're back in the Jeep! Keep me posted on any other developments.
Kori
post #14 of 15 Old 09-14-2017, 05:20 PM
Centerforce
Vendor
Centerforce's Avatar
In your video it definitely sounded like you had a bad pilot bearing, which they should have replaced during a full clutch job. Glad to hear your issue was resolved without too much out of pocket cost!
Centerforce is offline
post #15 of 15 Old 09-15-2017, 03:23 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Yea I agree, pilot is conspicuously missing from parts list. 1 part shy of a complete rebuild.
