2015 tuner question - JeepForum.com
post #1 of 18 Old 06-11-2016, 06:26 AM Thread Starter
lloydsmale
2015 JK Wrangler
2015 tuner question
I see the diablo lists that theres will work with a 2015-2016. Superchips says the computer needs to be unlocked and it requires sending in your computer or swaping for one of theres. Going to have to pass if that's the case because the dealership is now going to know you've been tweeking.
2015willys 4 cyl tj 2017 silverado yamaha grizzly, Polaris rzr 04 z06 vette, 600/800 crossfire cat
lloydsmale is offline
post #2 of 18 Old 06-11-2016, 07:27 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
2015+ FCA products have locked PCMs. No matter what tuner you purchase, you either have to buy a cracked PCM or send yours in to be cracked.
BTW, even on previous model years and stock PCMs, a dealer can tell if you've been using a tuner on it.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 18 Old 06-18-2016, 08:54 AM Thread Starter
lloydsmale
2015 JK Wrangler
how big of a tire will a dealer adjust your speedometer for?
post #4 of 18 Old 06-18-2016, 01:20 PM
222Doc
222Doc's Avatar
before you go up in tire might want to know your gear ratio. Unless 15+ has changed so much that the easiest way to set simple things like tire size, psi at thetires, gear ratio could done with something like the one AEV has been selling a long time. Just be sure its for your year.
Most the tuners are a bit limited and cost for what if any real gain. Going "cold air" and other things will generally cause more issues in a jeep off road than any claimed gains. If anything in the intake should be done is if you plan to ford water that could cause water ingestion. or stock here wins.
The aev is just a small box that connects to the OBD-2 port. it has a set of dip switches to set the things it does, rather simple. once used it locks to the vin so you can not buy a used one. last i heard unless someone cracked that.
222Doc is offline
post #5 of 18 Old 06-18-2016, 01:23 PM
Spank
2014 JK Wrangler
What are you trying to change? If you're tweaking the speedometer because you got new tires or wanting to adjust the transmission because of a gear change, a simple programmer will work just fine on a 15. A full-on tuner is a completely different story.
'14 Wrangler Unlimited Rubicon
Spank is offline
post #6 of 18 Old 06-18-2016, 03:14 PM Thread Starter
lloydsmale
2015 JK Wrangler
didn't know that. I thought you had to get into the computer to adjust for tire size. I'm not looking for HP just compensating for the change to bigger tires (speedometer, shift points).
post #7 of 18 Old 06-18-2016, 03:34 PM
SLADE
You need to look into something like an AEV Procal.
Keep it simple.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #8 of 18 Old 06-18-2016, 03:43 PM
Spank
2014 JK Wrangler
Keep it simple.
I'd go with the Flashcal F5 over the AEV unit. For $9 more, you get a screen, simple to use menus, a decent UI, and you can actually reset to stock. AEV units are notorious for not letting go of a VIN after a reset.
Spank is offline
post #9 of 18 Old 06-18-2016, 03:48 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Or the Superchips Flashcal. The AEV is done blindly with dip switches, the flashcal has an actual screen and buttons.
http://www.quadratec.com/products/17609_5131.htm
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #10 of 18 Old 06-18-2016, 04:09 PM
SLADE
Im not pushing the AEV Procal over anything else. So what ever works to keep it simple, go for it.
I like the looks of the unit Kruzin posted just for the added feature of being able to read and clear codes
I have an AEV Procal for both JKs and they have worked without issue. BUT if I were to do it again, for the little bit more $$$ this unit costs I could see myself going this route just for the hand held unit and being able to read and clear codes.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #11 of 18 Old 06-19-2016, 03:02 PM
222Doc
222Doc's Avatar
Me too not pushing the Aev. what ever works, that is simple, low cost. when i bought that was back in 2012. No need for anything else for me. I have a scanner always on board. today that is like having duck tape for a Cj.
222Doc is offline
post #12 of 18 Old 06-21-2016, 05:25 AM Thread Starter
lloydsmale
2015 JK Wrangler
anyone actually use one of these tire size programmer on a 2015? I guess I am thinking that you still are going to have to alter a program in the computer.
post #13 of 18 Old 06-21-2016, 07:48 AM
SLADE
Ive used the AEV on a 2013 for gear ratio and tire size, on a 2014 for tire size.
No experience with a 2015.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #14 of 18 Old 06-21-2016, 08:05 AM
duneslider
From what I have been told, the way the AEV programmer works is very different than tuners. You aren't really replacing anything, all you are doing it modifying values that are allowed to be altered. They are all things that chrylser's starscan is allowed to change too but they have limited how much starscan can do when changing tire size. So, the AEV, and presumably the superchips version, is not rewriting the tune, just changing some values which are allowed to be changed.
07 JKU Wrangler
10 XK Commander Limited
duneslider is offline
post #15 of 18 Old 06-21-2016, 12:44 PM
DCMastercraft
I used a programmer on my 2016 JKUR to adjust tire size, speedo, and shift points. Worked fine.
DCMastercraft is offline
