2014 Wrangler Unlimited - Tire Size? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 2014 Wrangler Unlimited - Tire Size?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955
Unread 06-18-2014, 05:59 PM   #1
rtowner
Just bought a new 2014 Wrangler Unlimited....I want to put a wider tire on it without doing a lift. What is the biggest tire size I can put on it? Also, has anyone put a leveling kit on one of these and what size tire are you using?
rtowner is offline   Reply With Quote
Unread 06-18-2014, 06:02 PM   #2
1222
Make mine a Jeep!
1222's Avatar
JK F.A.Q. - Frequently Asked Questions / Will It Rub and Links to Popular Threads!
1222 is offline   Reply With Quote
Unread 06-18-2014, 06:18 PM   #3
Matt98XJ
2014 JK Wrangler
To this date, I don't think anyone has done any mods to a 2014. You might be the first. Good luck OP.
Well I woke up this morning, I grabbed myself a beer.
The future's uncertain and the end is always near.
Matt98XJ is offline   Reply With Quote
Unread 06-18-2014, 06:53 PM   #4
Prot
Prot's Avatar
2014 JK Wrangler
Generally, 285/70-17 will work well for what you describe.
2014 Copperhead Pearl Unlimited Sahara in progress
Prot is offline   Reply With Quote
Unread 06-19-2014, 01:49 AM   #5
1222
Make mine a Jeep!
1222's Avatar
Should be no different than any other JK I would imagine other than the pinch seam (rear fender wells) being factory removed in the last couple of years
