2014 Rubo Lift Gate Door... - JeepForum.com
post #1 of 13 Old 08-24-2014, 02:06 PM Thread Starter
Filthy4x4
2014 JK Wrangler
Hey guys just a very simple/noob question, I just purchased a 2014 Rubicon 4dr and when I open the rear door past 90 degrees I hear a clicking/popping noise.
Is this normal? and if its not what would cause such a thing??
Thanks!
Filthy4x4 is offline
post #2 of 13 Old 08-24-2014, 03:25 PM
JIMBOX
Well, you've got two hinges/2 lift arms(4 friction ends) and three wires/hoses extending from the top, to glass/window washer/wiper--
Checkem out !mines very quiet after 5 years of desert sand !
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #3 of 13 Old 08-24-2014, 03:37 PM Thread Starter
Filthy4x4
2014 JK Wrangler
JIMBO
This only happens when I open the door past a certain point. Its the black hinge looking object that is making the popping noise.
post #4 of 13 Old 08-24-2014, 03:48 PM
JIMBOX
Squirt some WD-40 in the hinge and if that quiets it--
Getta can of White Lithium spray grease and use some ofit sparingly-cause WD-40 isn't a good lubricant, it's justa bandaid-
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #5 of 13 Old 08-24-2014, 04:52 PM Thread Starter
Filthy4x4
2014 JK Wrangler
Good luck
JIMBO
Will do sir!!
Cheers
post #6 of 13 Old 08-24-2014, 05:08 PM
AlbertaJeeper
Check the arm that holds the door open. The screws on mine were loose so they made a popping noise
AlbertaJeeper is offline
post #7 of 13 Old 08-24-2014, 06:22 PM
BlackJeep2013
Yes tighten the bolts ours did the same thing and it was due to the bolts being loose.
BlackJeep2013 is offline
post #8 of 13 Old 08-24-2014, 06:35 PM Thread Starter
Filthy4x4
2014 JK Wrangler
Awesome, do you guys know where and how I get to those screws?
post #9 of 13 Old 08-24-2014, 07:02 PM
JIMBOX
Well, unless the 2014 is THAT different-
There's one "NUT at the top of the lift arms (10mm) and three torx screws at the bottom (T-27)
There pretty obviously on the visible holding brackets for the lift arms-
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #10 of 13 Old 08-25-2014, 01:50 AM
1222
RIP John
1222's Avatar
OP,
Mine also does the exact same thing and has been that way for quite some time. It hasnít really bothered me that much although I have planned to look into it someday. I guess Iíll just wait and see what you come up with and hopefully do the same to mine.
(2011-2016)
1222 is offline
post #11 of 13 Old 08-25-2014, 12:45 PM Thread Starter
Filthy4x4
2014 JK Wrangler
Awesome!
Thanks to everyone that replied, yup it was easy as tightening the two star screws on the door latch... no more popping sound!!
Cheers to all!!
post #12 of 13 Old 08-25-2014, 01:10 PM
YATZI1980
2011 JK Wrangler
Yes very simple fix. Mine was making noise also. Like a popping sound when it opens all the way. It was the 2 torx screws that hold the arm to the tail gate. Just tighten them up... Noise gone good luck
YATZI1980 is offline
post #13 of 13 Old 08-26-2014, 07:36 PM
1222
RIP John
1222's Avatar
Well unfortunately for me nothing was loose and no amount of lubrication would stop the cracking/popping noise. I ended up taking the whole assembly out yesterday to check it out but it seems to be the part that canít be disassembled.
I guess itís off to the dealer (if itís still under warranty) for me to get it repaired.
(2011-2016)
1222 is offline
