2014 lift kit ? - JeepForum.com
post #1 of 17 Old 11-04-2013, 08:35 PM Thread Starter
Totallytwisted
2014 JK Wrangler
2014 lift kit ?
I've searched just about everywhere and I don't find any reviews on Procomp lifts. I'm looking at the new Procomp 3.5" lift that includes front and rear adjustable track bars, coil springs, and shocks. I will be running 35's and I have 3.73 gears. Any thoughts or advise on this set up? This is my first jeep so go gentle I'm still learning
Totallytwisted is offline
post #2 of 17 Old 11-04-2013, 08:39 PM
ncb
ProComp isn't known for quality lifts. Did you see the lift at 4 Wheel Parts?
ncb is offline
post #3 of 17 Old 11-04-2013, 09:15 PM
HappyTrails
HappyTrails's Avatar
Like NCB said, ProComp advertises heavily, but does not emphasize quality.
Many ProComp users I've known have complained about springs losing their lift (sagging). Look into TeraFlex, Rock Krawler, AEV, Metal Cloak, et al. Those mentioned are very popular in this forum.
Do some searching here on the forum. I'm sure many have already lifted their 2014's.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #4 of 17 Old 11-04-2013, 09:16 PM Thread Starter
Totallytwisted
2014 JK Wrangler
Yes also on 4WD.com
I have also been looking at this kit
http://www.4wheelparts.com/Lift-Kits...pn=R%2fERE7142
post #5 of 17 Old 11-04-2013, 09:18 PM
HappyTrails
Originally Posted by Totallytwisted View Post
Yes also on 4WD.com
NO!!!!
Okay, I'll say it like it is, avoid Rubicon Express, Rough Country, Rusty's, and ProComp lift kits. (I'll probably catch Hell from some people for stating these brands, but oh, well).
You get what you pay for.
post #6 of 17 Old 11-04-2013, 09:31 PM Thread Starter
Totallytwisted
2014 JK Wrangler
Originally Posted by HappyTrails View Post
NO!!!!
That's what I want to hear I want honesty. I have a budget in mind but if I have to save up a few more weeks I would much rather do that then waste money on junk.
I've never done suspension work but I've done a lot of wrenching if I can install it myself I could save on labor and get a better kit.
I'm being told that if I go more the 3.5" I will need a new driveshaft as this is my DD is there any truth to that ?
post #7 of 17 Old 11-04-2013, 11:09 PM
sean0168
2014 JK Wrangler
I have a 2014 JKUR with a AEV 2.5 lift and 35's. It was a pretty easy install (I did not do it myself but helped) and I am happy with the results. I did add a RK adjustable front track.
sean0168 is offline
post #8 of 17 Old 11-04-2013, 11:24 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
At 3.5 in if you don't get them now you will need them in the future. You will want adj control arms to set caster front and pinion angle rear IMO.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #9 of 17 Old 11-05-2013, 03:40 AM
HappyTrails
If you have basic wrenching skills (be able to tell the difference between crescent wrench and a channel lock), then you can do a lift install yourself. Having a friend give you a hand is definitely recommended though (sometimes you need an extra pair of hands).
To run 35" tires on your Jeep then you can do fine on only 2.5" of lift. Do you have a 2-door or a 4-door (JKU)? A 2-DR will get more lift than advertised due to it weighing less. I am running 37" tires on 2.5" of lift by just trimming the edges of the plastic fenders and trimming back the pinch seams of the body.
I recommend doing the lift install yourself and get to learn how your Jeep operates. If I were you, I'd just save up more $$ and get a quality lift. That way you won't end up spending more money by doing it twice.
The more complicated lifts (i.e. Rock Krawler 2.5" X-Factor Long Arm) may require welding and/or cutting. A JK (current generation of Jeep) has very large wheel wells and can accept relatively large tires without much lift. Most JK's run 2.5"-4.5" of lift and take between 4-6 hours (or more if you throw beer into the mix, LOL).
P.S. I just noticed your name, and laughed. Here, THIS is Totallytwisted (was my front driveshaft):
post #10 of 17 Old 11-05-2013, 02:07 PM Thread Starter
Totallytwisted
2014 JK Wrangler
How the heck did you twist that?
I have a 4 door.
Is there any truth that over a 3.5" lift I have to get new drive shafts?
post #11 of 17 Old 11-05-2013, 02:15 PM Thread Starter
Totallytwisted
2014 JK Wrangler
I love the way that looks!
2014 JKU S 4Dr
Auto Trans, 3.73 gears W/tru lock, 17" rims 35/12.50R17 Toyo Open County MT's on the way
XRC Smittybilt front & Rear bumpers, Smittybilt X2O8 Comp winch, 2.5" BB Lift
post #12 of 17 Old 11-05-2013, 03:40 PM
HappyTrails
I have a 4 door.
Pure, unadulterated, adrenaline-fueled lead foot-itis.
Actual conditions: 37's, 4.10 gears, supercharger, Rubi transfer case in 4LO, locked front and rear, stuck in the rocks, and left rear axle shaft already snapped. Got frustrated and floored it. Next thing I knew...front tires were not spinning. Looked underneath and there was my front driveshaft....TotallyTwisted like a candy wrapper. So, now I was stuck with only the right rear tire capable of moving me. Only took 3 hours of winching me to get up the rest of the trail.
Lesson learned (the hard way): Go with technique, not brute force.
post #13 of 17 Old 11-05-2013, 06:23 PM
Spank
2014 JK Wrangler
I have a 4 door.
Yes. I have an AEV 3.5" lift and my rear driveshaft is starting to go. It's simply a matter of time.
'14 Wrangler Unlimited Rubicon
Spank is offline
post #14 of 17 Old 11-05-2013, 06:49 PM
1222
RIP John
1222's Avatar
I’m not going to get into what lift is best for you as there are several that will fill the bill. I will say however that you must do your research because unfortunately there are also a few kits for the JK’s that are less than sub-par.
Don’t be in such a rush to slap on a suspension lift and larger tires right away. Take your time and buy only once. In the meantime just driving your Jeep stock on or off road will lessen the anxiety you feel until it’s finally lifted.
Like already mentioned, if need be then just wait and save up for a quality kit; this is something you do not want to skimp on.
1222 is offline
post #15 of 17 Old 11-06-2013, 02:30 PM
ROCKR8R
Listen to Happy Trails on this thread (he has a nice lift too in the Rock Krawler). You can go 2.5” and fit 35’s and nearly skip the control arms, driveshafts etc… I say nearly, cause some few still have problems at 2.5” but not likely.
Some brands to consider, the aforementioned Rock Krawler, Teraflex, Synergy Suspension, MetalCloak and Clayton.
-Dan
ROCKR8R is offline
