2014 JK unlimited hard top to bimini top - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 2014 JK unlimited hard top to bimini top
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiIRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK
Unread 06-25-2015, 07:38 AM   #1
davlefty0584
2014 JK Wrangler
Good morning everyone. Have a question. I currently have a 2014 Wrangler Unlimited with hard top. With the summer months already upon us, I was looking at putting the hard top away until the late fall and going with some form of protection from the elements when needed. I was looking into bimini tops, specifically the QuadraTop brand. Looking at the installation, it says I need to remove the windsheild header. Now, it does not show how to remove it, or if they are reffering to a soft top header. The header shown does not look like the header I currently have. Now, if I need to get an additional header, that is fine. But how do I remove my current windsheild header? Now keep in mind, I do have the bluetooth capability so I think my mic is located above the driver side.
davlefty0584 is offline   Reply With Quote Quick reply to this message
Unread 06-29-2015, 02:51 AM   #2
OH9JK
2009 JK Wrangler
There is no header with a hard top. Most bikini tops require you to purchase one. Which top are you looking at purchasing?
OH9JK is offline   Reply With Quote Quick reply to this message
Unread 06-30-2015, 12:09 PM   #3
davlefty0584
2014 JK Wrangler
I was looking at getting the Quadratop Bimini top. Unless of course there are better ones out there.
Unread 06-30-2015, 03:08 PM   #4
shin0bi1
I use the mopar sun bonnet which has a built in header and I like it a lot. I get no leaks in the front and it works like the factory soft top header.
shin0bi1 is offline   Reply With Quote Quick reply to this message
Unread 07-02-2015, 10:04 AM   #5
davlefty0584
2014 JK Wrangler
ha' reat!! Thank you. I will check it out!!
Unread 07-07-2015, 12:22 PM   #6
knupe387
2014 JK Wrangler
is the tops rain proof
knupe387 is offline   Reply With Quote Quick reply to this message
Unread 07-08-2015, 09:17 AM   #7
shin0bi1
There are two versions of the Mopar sun bonnet (bikini top). One that uses the stock softop door channels/frame (i believe) and the one that i have that does not. I dont run doors or the factory soft top door channels at all during the summer time so i opted not to get that version. There are no leaks or anything from the top but since obviously i run with no doors and stuff i get wet on the sides. But then again i dont give a **** about that lol its a jeep
-Shin0bi1
