2014 jk oil pressure light on - JeepForum.com
post #1 of 37 Old 11-02-2013, 06:50 PM Thread Starter
charliebrownjk
2014 JK Wrangler
3400 miles decided to change the oil on my jk today. Valvoline 5w30 synthetic and now my oil pressure light comes on at idle. It's fluctuating between 0 and 4 psi. Any ideas?
charliebrownjk is offline
post #2 of 37 Old 11-02-2013, 07:10 PM
1222
RIP John
1222's Avatar
Did you install the proper oil filter for your year, 2014?
1222 is offline
post #3 of 37 Old 11-02-2013, 07:14 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
I haven't had the opportunity to see a new oil filter system, but from what I understand they use a cartridge now. I would suspect that something is wrong in this area.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #4 of 37 Old 11-02-2013, 07:22 PM Thread Starter
charliebrownjk
2014 JK Wrangler
Update. My jk does not like the wix filter or the guy at oreilly gave me the wrong one. I installed the factory one back in and no problems. The wix filter he gave me was part number 57526
post #5 of 37 Old 11-02-2013, 07:30 PM
1222
RIP John
1222's Avatar
There is a thread from just the other day from JeepCares that let us know that the oil filters for the 3.6 (2012 and up) are different for each year. I‘ll find that thread and post here in a few.
Because of that all JK owners from 2012 on up need to double check to see that we have purchased the correct oil filter and not to rely on what the parts guy gives us.
EDIT: Here's that info.
Originally Posted by JeepCares View Post
Just an FYI - current MOPAR numbers:
A NEW OIL FILTER IS RELEASED FOR 2014 MODELS THAT INCLUDE A 3.6L / 3.2L OR 3.0L (PENTASTAR FAMILY ENGINE)
The oil filter that was used in the 2013 Pentastar engines WILL NOT work with the 2014 engine.
Using a 2013 filter on 2014 model engines will create an oil leak situation.
2014 - 68191349AA - Filter Kit = Filter and Cap O-ring
Not backward compatible
2013 is 68079744AB - Filter Kit = Filter and Cap O-ring
Not forward compatible
The below 2014 engines will also use the 2014 filter 68191349AA - Filter Kit = Filter and Cap O-ring
2014 – 3.6L, DS DX JC JF JK JS J3 LC LD LX RM RT VF WD WK W6
2014 – 3.2L, KL K2
2014 – 3.0L, JK LX WK (BUX)
1222 is offline
post #6 of 37 Old 11-02-2013, 07:41 PM Thread Starter
charliebrownjk
2014 JK Wrangler
Awesome thanks for the info. Wish I would have known that before because he did give me the 2013 oil filter because their computers did not have part numbers for the 2014s yet.
post #7 of 37 Old 11-02-2013, 07:54 PM
1222
RIP John
1222's Avatar
We can all be thankful for the info from JeepCares. Up until his post I didnít have a clue either and might have run into the same problem with my Jeep too.
1222 is offline
post #8 of 37 Old 11-02-2013, 08:02 PM Thread Starter
charliebrownjk
2014 JK Wrangler
Kinda scary the auto parts store does not have 2014 part numbers and they are thinking the 2013s are interchangeable.
post #9 of 37 Old 11-02-2013, 09:00 PM
1222
RIP John
1222's Avatar
I would have thought the same thing and never given it a second thought.
1222 is offline
post #10 of 37 Old 11-03-2013, 10:18 AM
ncb
How long did you let it run like this?
ncb is offline
post #11 of 37 Old 11-03-2013, 10:19 AM Thread Starter
charliebrownjk
2014 JK Wrangler
Only a couple minutes
post #12 of 37 Old 11-03-2013, 02:29 PM
Jiblet
What a nightmare. I've gotten a few incorrect parts from dealers, I don't trust dealer parts counters let alone regular autoparts stores.
What is the change in the newer filters? I mean the difference between the '13 and '14. Is it obvious to your eye?
Jiblet is offline
post #13 of 37 Old 11-06-2013, 01:51 PM
jeepwrnglr92
2015 JK Wrangler
WOW good info. I just got a new 2013 3.6 jeep. I will have to watch this. I have 2 years of oil changes with it so that's a dlr issue for now.
Why do they run 5w20 oil?
I have always had 10w40 or 5w30 but never 5w20...
Anyone running synthetic? I run mobile 1 in all my GM cars, vettes and trucks etc.
Wondering if I should keep with the dealer oil changes or just do my own an swap it out for synthetic mobile 1
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline
post #14 of 37 Old 11-07-2013, 04:21 PM
73azbronco
my theory on synthetic is, if you run long and hard and go many miles between changes (5-10,000 or so), go synthetic. If you follow the Jeep oil change of 3-6000 miles depending on usage, I'm staying dyno oil.
go on the balckstone website they have a good explanation on viscosity, which basically is, you can use any viscosity, but mileage may suffer, upper end may suffer, or lower end may suffer. best to use what the engineers designed the motor for. on high mileage vehicles, I will push into the 5-40's or 5-50's.
73azbronco is offline
post #15 of 37 Old 05-12-2014, 09:20 PM
woof359
how bout
welll a 2014 fit the older 3.6 ? and are 2013 and 2012 the same ? just camed the oil on my 2012 and i cood swear it had that nose cone type thing. gotta check the number
woof359
woof359 is offline
