2014 JK News?? - JeepForum.com
post #1 of 16 Old 01-26-2013, 03:41 PM Thread Starter
LIJeepJC
2014 JK News??
Hey!
Got an email from Jeep announcing the new 2014 Grand Cherokee. It's a sweet SUV and I like the new styling changes. But most notably the new U-Connect radio! Anyone else see this?? Definitely a step up from the current 430/730N radios. So my q is, will this radio come out in the '14 JK? And, can it be retro'd into the 2012's??
Thanks!!
LIJeepJC is offline
post #2 of 16 Old 01-26-2013, 07:01 PM
Doctorsti
Originally Posted by LIJeepJC View Post
Hey!
Thanks!!
Can't be retrofitted as it requires Chrysler's Powernet electrical architecture which the 2013 and older models don't have.
It's anyone's guess if the 2014 will get Powernet or not but if it does it means 8.4" touch screen radio, 8-speed automatic transmission, better performance and gas mileage, and more sophisticated crash safety protocols with which the powernet helps to coordinate.
It seems an obvious addition to me as it will make the highway mileage go up from 20/21 to 25+ due to having two overdrive gears instead of one in the 5 speed auto. they need to start to push this mileage up for the coming CAFE standards so I would think it would make sense for them to run the 8sp/pentastar combo for a couple years tweaking it until they release an all new Wrangler in 2016/early 2017 (think Grand Cherokee early release).
The new wrangler can then have the multiair technology from Fiat and a more aero shape to reduce drag coefficient and then we'll be talking 30/31 highway along with adding a 4cylinder/9speed auto carried up from the compass/liberty line that will get 35mpg highway.
All my opinion based on all my reading but it seems Marchionne has made insinuations that the 8speed will be on the wrangler soon but didn't say specifically next year as he didn't want to cannibalize 2013 sales too badly yet.
Doctorsti is offline
post #3 of 16 Old 01-26-2013, 08:31 PM Thread Starter
LIJeepJC
Wow, great reply! Thanks
LIJeepJC is offline
post #4 of 16 Old 01-26-2013, 09:04 PM
Godholio
The gearing is going to have to be so close it'll be obnoxious. There's only so much room in the powerband to lower the rpms at highway speeds, I don't think you can get it low enough to hit an average of 25mpg and still generate enough power to push this brick through the air.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #5 of 16 Old 01-27-2013, 08:52 AM
Doctorsti
Sure you can with the power the new pentastar produces. Remember there are two overdrive gears meaning they are equalling a lower final drive ratio or "more turns of the tires per turn of the final drive gear". Example the 5 speed 1:1 gear is 4th and 5th is .83 or something. On the 8 speed the 1:1 gear is 6th and 7th is 0.84 and 8th is 0.67. This means essentially when you are in your highway gear on the 5 speed you are only in seventh on the 8sp meaning you have a whole gear to drop down to that is significantly lower.
There is also a taller 1st gear in the 8 speed meaning more spinning with less power at 4.71 conpared to 5 sp 3.59. 2nd gear in the 8 speed is 3.14 so its very close to 5sp 1st gear.
The bashing of the 8 speed assumes the same gear "range" which if you know the facts is just not true. It would be stupid to replicate the same range with more steps as it would cause too much "hunting" as some would say. In fact the 8 speed has significant expansion on the available hearing and will not only result in better gas mileage but also significantly better performance no matter what shape the car/truck is.
post #6 of 16 Old 01-27-2013, 10:21 AM
Godholio
5th gear is that weak? I assumed it was taller. I recently swapped out a 4-speed to a 5-speed w/.67 OD in my other car, and the highway mpg went from 13 to 20.
I'll have to play around on the highway and see how much power is actually available at speed. I love the Pentastar but I'm still concerned that at a .67 ratio there's just no room without downshifting at the slightest bump of the gas pedal.
Utah Jeep Crew #148
Godholio is offline
post #7 of 16 Old 01-28-2013, 08:07 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
From what I've been able to find out - no UConnect for the 2014 JK (think "carry-over" radios.)
Depending on the model - the following radios are currently available on the 2014 WK:
UCONNECT 5.0 AM/FM/BT (RA2) (Standard on the Laredo and Limited)
RA3 UCONNECT 8.4A AM/FM/BT/ACCESS
Includes: 8.4" TOUCH SCREEN DISPLAY (RFL)
GPS ANTENNA INPUT (JLP)
NAVIGATION READY (JLA)
ROADSIDE ASSISTANCE AND 9-1-1 CALL
(RSR)
RR VIEW AUTO DIM MIRROR W/MICROPHONE
(GN5)
SIRIUSXM SATELLITE RADIO (RSD)
UCONNECT ACCESS ADVANTAGE (RS7)
Nav. Ready-- See Dealer;
RA4 UCONNECT 8.4AN AM/FM/BT/ACCESS/NAV
Includes: 1-YEAR SIRIUS TRAVEL LINK SERVICE (X9F)
1 YR. TRIAL (REGISTRATION REQUIRED)
(X9K)
1-YR SIRIUS REALTIME TRAFFIC SERVICE
(X9C)
FOR DETAILS, GO TO DRIVEUCONNECT.COM
(X9E)
FOR MORE INFO, CALL 888-539-7474 (X9A)
GPS NAVIGATION (JLN)
HIGH DEFINITION RADIO (RE8)
(RSR)
(GN5)
SIRIUSXM TRAFFIC (RSS)
SIRIUSXM TRAVEL LINK (RSM)
JeepCares is online now
post #8 of 16 Old 01-29-2013, 06:36 AM
Doctorsti
(RSR)
(GN5)
(X9K)
(X9C)
(X9E)
(RSR)
(GN5)
Well that answers that! If this is legit info and not a diversion to reduce cannibalization on the 2013's then it also means no 8-speed. No way do they put in powernet and 8-speed but leave the old antiquated head units. I've heard from reliable sources it was 99.9% confirmed NO 8-speed for 2014 but I had my hopes.
post #9 of 16 Old 01-29-2013, 03:09 PM
zeke6785
Or they could release the CRD for American markets and average about 34mpg and make us all very happy.
2012 Wrangler
35" Pro-Comp Xtreme M/T
3" Full Traction Lift
Smittybilt Stinger
zeke6785 is offline
post #10 of 16 Old 01-30-2013, 12:37 AM
Doctorsti
To jeepcares:
When can we expect something from Chrysler on the specs of the 2014 Wrangler? There seems to be a few media outlets reporting the 8-speed will be in the 2014 and statements from those supposedly "in the know" saying no way in 2014 but yes eventually we will see the 8-speed. I know it's only almost February but hearing and seeing so much on other Jeep brand 2014 vehicles makes me think we should hear something concrete soon.
Feel free to break the news anytime!
post #11 of 16 Old 01-30-2013, 07:22 PM
Stilly
(RSR)
(GN5)
(X9K)
(X9C)
(X9E)
(RSR)
(GN5)
So what exactly does think carry over radio mean?
Stilly is offline
post #12 of 16 Old 01-31-2013, 06:18 AM Thread Starter
LIJeepJC
To me it looks like the current radio will carry over to the 14 jk
LIJeepJC is offline
post #13 of 16 Old 01-31-2013, 07:30 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
To jeepcares:
The 2014 currently scheduled start is summer this year - the "normal" time for new vehicle production.
Not sure about any breaking news. I try not to post rumors. While they might come true; sometimes they don't. A lot can change between now and change over. Sometimes things such as supplier capacity restraints can adversely affect what's planned and what actually happens.
post #14 of 16 Old 02-02-2013, 08:31 PM
NMBruce
One can hope, the radio would mean a dash redesign, where the Powernet and 8-Speed could be dropped in.
2013 JKUR sold
2006 GX470
I knew I shoulda taken that left turn at Albuquerque! - Bugs Bunny
NMBruce is offline
post #15 of 16 Old 02-03-2013, 07:45 AM
GreenRenegade
The U Connect seems nice in pics and on paper, but if you don't go with the $1000 upgrade to Beats Audio, you will hate it. It sounds like doo doo. And when you order the Premium Radio, you get the lowest model (go figure)... It just means it comes with Alpine speakers, but still no sub and no bass whatsoever. You cannot swap the radio out for a different headunit, as the radio controls a bunch of other stuff, like your heater, AC, suspension (option)... You could get an adapter from PAC to run an aftermarket amp and sub(s), but you would have to rewire all your speakers from the new amp, as the old one gets bypassed completely. You would also lose control of your bass/mid/treble settings on the radio.
Info from 2013 Charger owner...
2013 Wrangler Rubicon 2dr
GreenRenegade is offline
