2014 eng oil pressure - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 2014 eng oil pressure
Steering and more from Ruffstuff!Ruffstuff 3 Link Kit!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 10-13-2014, 07:03 PM   #1
CABBOTT
1982 CJ7
So I have a '14 JKU Rubi today I notived the engine had a different noise, just not the typical engine sound. So while driving at 35 mph I checked my gauges and found all were normal except the oil pressure was was at 80psi! That was low rpm's, so impressed the skinny pedal and to my disbelief oil pressure went up to 98 psi! Has anyone else run into this before?
CABBOTT is offline   Reply With Quote Quick reply to this message
Unread 10-13-2014, 09:39 PM   #2
79cj7amc304auto
Makes me wanna check my gauges more often. No I've never had this, but it may just be a bad sender. Start cheap then go from there. Is it throwing a code yet?
79cj7amc304auto is offline   Reply With Quote Quick reply to this message
Unread 10-13-2014, 09:41 PM   #3
79cj7amc304auto
I had to have a sender replaced... but I got a check engine light. No change in engine performance.
Unread 10-13-2014, 09:45 PM   #4
ronjenx
ronjenx's Avatar
Here are the oil pressure ranges for the 3.6L JK engine.
3.6L Engine Oil Pressure Chart
Pressure @ Curb Idle Speed..........5 psi minimum
Pressure @ 600 - 1200 RPM..........5 (warm) - 139 (cold) psi
Pressure @ 1201 - 3500 RPM........30 (warm) - 139 (cold) psi
Pressure @ 3501 - 6400 RPM........62 (warm) - 139 (cold) psi
2008 JKU Rubicon
42RLE Auto
ronjenx is offline   Reply With Quote Quick reply to this message
Unread 10-13-2014, 10:31 PM   #5
COLOUXJ
2010 JK Wrangler
Are you surprised that you have oil pressure that goes up with engine speed? Do you think that sounds low or high? Looks normal to me.
"When i die, bury me with my jeep. Its never been in a hole it can't get out of"
Black Jeep Society
My JEEP helped win a War > Your Honda mows my grass!!
Mechanical Engineers Build weapons Civil Engineers build targets
Originally Posted by cyberpyrot View Post
is it a plink plink kerrrrdunk? or more of a brrrrrconk doc doc miiiidge pang!!!? or is it a badonk ka donk? if it is the latter its just the normal fat *** of the JK
COLOUXJ is offline   Reply With Quote Quick reply to this message
Unread 10-14-2014, 08:35 AM   #6
14Sport
2014 JK Wrangler
Mine goes up to 99 all the time when cold. I have a 3 digit gauge but I'm thinking it stops at 99 for oil pressure. The lowest I've seen mine was 22.
2014 JK Sport, auto, 35x12.5x17, 3.73s.
I jeep therefore I am.
14Sport is offline   Reply With Quote Quick reply to this message
