2014 3.6 oil change problem - Page 2 - JeepForum.com
post #16 of 42 Old 10-23-2013, 09:54 PM
73azbronco
Originally Posted by Godholio View Post
The change was not only to Wranglers, it's a change for the 3.6L engine across models. And this isn't unusual, either. Ford changed the oil filters on their old 3.0L, small-block Chevies used to have cartridge filters instead of spin-ons, etc.
Yes, but Ford 302-5.0 use FL-1A, still do... Isn't unusual to see one change, but it looks like three in as many years.
73azbronco is offline
post #17 of 42 Old 10-24-2013, 05:30 AM
bogleparsons
I wasn't saying we should stay in Flintstones mobiles you asshats but to change the filter 3 times in like 5-6 years is a little ridiculous.
And yes I could do with less catalytic converters.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #18 of 42 Old 10-29-2013, 05:53 AM
Mello03
Originally Posted by brianjw View Post
Any idea if this new filter assembly reduces oil starvation at start up?
Interested in this as well. Could someone with this new setup let us know if that initial clatter is there on startup with the 2014s?
2013 JK Rubicon-Nth springs, Metalcloak arms, Warn M8000, Spod, 35" Nitto Trails, LOD bumpers....
Mello03 is offline
post #19 of 42 Old 10-29-2013, 10:48 AM
Godholio
This is one change.
The entire engine changed for 2012, 2013 was the same, then 2014 gets a new filter. The Pentastar was in use for a couple of years before showing up in the Wrangler, too.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #20 of 42 Old 11-04-2013, 06:46 PM
GC14
I have recently picked up a 14 grand Cherokee with the 3.6 replacing my 02 liberty. Went to the dealer for the first oil change as I was getting a blue screen on the reverse camera. Went to change the oil again on Sunday, went to two part stores both didn't have anything in stock he said dealer only. I was close to telling him just give me the one for 13 glad I didn't! I will be running to the dealer today to pick the correct one up I guess.
GC14 is offline
post #21 of 42 Old 01-14-2014, 08:13 PM
zpayne08
Anyone came across part number 68079744AC?
zpayne08 is offline
post #22 of 42 Old 01-14-2014, 08:28 PM
Jiblet
That's the latest version for the 2013 filter.
Jiblet is offline
post #23 of 42 Old 01-14-2014, 08:55 PM
zpayne08
Ok great. The filter sticky needs updating
zpayne08 is offline
post #24 of 42 Old 01-15-2014, 10:17 AM
1222
RIP John
1222's Avatar
Done.
(2011-2016)
1222 is offline
post #25 of 42 Old 02-18-2014, 10:30 PM
MR91387
2014 Jeep Wrangler Rubicon ... 1st Oil Change...
Well, my first mistake, I took my 2014 Jeep rubicon to Jiffy Lube for her first Oil change. Sure enough, had a problem already with jiffy lube..
Upon competing my first basic oil change my oil light stayed on. Of course wanted it corrected. The service guy called over his MGR, MGR says .. No worries!
Changed the oil to the synthetic blend....
It didn't sit right with me....
So I go on line and found Jeep Forum....
Someone had the same issue but it was do to the oil filter...
I mentioned it to the service guy...
He put back the old one,, light stayed off))
But I asked him why they put a 2013 oil filter in a 2014 jeep...
He said, that's all they had!!!
AMAZING.!!!!!
NEVER AGAIN...
GOOD BYE JIFFY LUBE.
Thanks Jeep Forum
MR91387 is offline
post #26 of 42 Old 02-18-2014, 10:39 PM
zpayne08
Or just change your own oil... Lol. Takes 30 minutes of that
zpayne08 is offline
post #27 of 42 Old 02-19-2014, 01:55 AM
RyeMan11
****ing jiffy lube changed my oil and did their multi point inspection, left jiffy lube jeep sounded a lot deeper checked under the hood they had left my air box open all four clips undone filter not put in correctly and they also cracked the edge of it. But hey they changed the oil correctly.
RyeMan11 is offline
post #28 of 42 Old 02-19-2014, 05:45 AM
invest2m4
A couple years ago a friend took his car there. By the time he got the three mikes back home, his car was smoking. Lucky it didn't burn to the ground. Apparently, one guy filled the oil thinking the other guy drained it. Nothing like 10 quarts to keep things moving!
invest2m4 is offline
post #29 of 42 Old 02-19-2014, 07:13 AM
n3tfury
This. I even got the "maintenance for life" from my Jeep dealer, but after they tried to tell me a third party stripped my oil drain plug, I've been doing it myself. Fact is, THEY stripped the plug because I've never taken it anywhere else.
n3tfury is offline
post #30 of 42 Old 02-19-2014, 03:07 PM
73azbronco
Back fifteen or so years ago Jiffy. Lube got to buy my dad a new rear end for his f150, they didn't tighten the drain plug, lost oil, locked up the axle.
