2013 rubicon wheels on 2012 - JeepForum.com
post #1 of 20 Old 09-10-2012, 02:25 PM Thread Starter
rubicon1000
I have done alot of searching but can not find a good answer. will I have a tpms error when I install 2013 rubicon wheels and tires on my 2012. thanks
'12 unlimited sport S, 3.73, trac loc, towing package, rubicon unlimited springs and shocks
SOLD 03 Rubicon , nv 3550 ,4'' RC lift ,1'' RC MM lift, 1.25'' body lift, HD rear bumper, hummer snorkel cap with buick airbox and custom piping, 265/75 r 16 tread wright retread mud tires on stock rubicon wheels, smitty built 8k winch, cobra cb radio, rrc front bumper, pre-runner rear bumper, HID headlights in Hella housings
rubicon1000 is offline
post #2 of 20 Old 09-10-2012, 02:29 PM
rubiwannabe
Youll be ok...theyre compatable
rubiwannabe is offline
post #3 of 20 Old 09-10-2012, 02:55 PM Thread Starter
rubicon1000
ok cool I know they changed the sensors in 2011 just didnt know if they changed them again
post #4 of 20 Old 09-11-2012, 12:09 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
The 2012 and the 2013 Wranglers both use the 433 MHz TPM sensor.
JeepCares is online now
post #5 of 20 Old 09-11-2012, 12:13 PM
paul84043
So, you upgraded from a 2012, to 2013? (wheels, that is..)
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #6 of 20 Old 09-11-2012, 08:42 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
Originally Posted by paul84043 View Post
So, you downgraded from a 2012, to 2013? (wheels, that is..)
corrected
My builds:
and
or follow us on
spyder6 is offline
post #7 of 20 Old 09-11-2012, 09:23 PM Thread Starter
rubicon1000
yes I had stock sport s wheels now new rubicon takeoffs
post #8 of 20 Old 09-15-2012, 01:28 PM Thread Starter
rubicon1000
I have been running these for 2 days and now today I get the tpms light blinking then stays on solid and ideas?
post #9 of 20 Old 09-15-2012, 02:03 PM
BadTrainDriver
Pressure too low?
I thought the new(2013) TPMS gave actual PSI in each tire.
Are you sure they're compatible with the 2012 system that just warns when the pressure falls below a certain PSI?
To me, that doesn't sound compatible.
2012 Jeep Wrangler Unlimited Rubicon
Stock, for now...
BadTrainDriver is offline
post #10 of 20 Old 09-15-2012, 02:39 PM Thread Starter
rubicon1000
yeah im not to sure
post #11 of 20 Old 09-15-2012, 02:40 PM Thread Starter
rubicon1000
maybe I meed to ho see the dealership
post #12 of 20 Old 09-15-2012, 03:29 PM Thread Starter
rubicon1000
I guess I will need to take it to the dealership. I was thinking with the same feq. I would be fine
post #13 of 20 Old 09-15-2012, 08:32 PM
pato1031
It depends on the the Jeep they were taken off of. If the Jeep had connectivity group then the new wheels do in fact have different sensors and will not work on the 12.
Premium TPMS is part of the connectivity group and does have a different frequency. And no you can't turn on the premium TPMS on a 12, it wasn't an option.
You should be able to buy new sensors that will work just fine. I know places like discount tire carry the correct sensors.
pato1031 is offline
post #14 of 20 Old 09-15-2012, 08:46 PM
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
Try filling the tires to 10-15 psi above the lower limit that your TPMS is set for and see if that clears it. Then back the pressure off to where you want to run it.
We save dogs:
JBWood05TJ is offline
post #15 of 20 Old 09-15-2012, 10:35 PM Thread Starter
rubicon1000
the tpms malfunction light is on study I turned the system off right now with my procal. would it be worth playing with the pressure or will I just need to get new sensors. sucks cause I just sold my stocker today then the light came on a few hours later
