2013 Rubi Wheels on a 2009? (TPMS) - Page 2 - JeepForum.com
post #16 of 18 Old 01-03-2013, 12:15 PM
MGIMELLI
Originally Posted by gregaf3
Schrader makes most of the tpms systems and they switched frequencies in 2013. http://www.schraderinternational.com..._11-13-12.ashx
You can use the catalogs and cross reference places to get part numbers. For switching the sensors use service kit 20018 (2.54 @ sams club) DO NOT PAY THE $29 at the dealer for each one.
I had all of my sensors taken out of my old wheels, and put in the new wheels with all 10 wheels mounted and balanced for under $30 at my local sams club.
With the schrader part number 20018 you were able to get that to work with the 2013 jeep? 20018 says ford service pack. Does it work because its the same frequency as the jeep @ 433mhz? Some clarification would help thanks.
2013 JKUR (NEW PROJECT)
97 TJ- 5.7L HEMI, (SOLD) http://www.jeepforum.com/forum/f22/97-tj-5-7l-hemi-build-1212248/
MGIMELLI is offline
post #17 of 18 Old 01-03-2013, 12:21 PM
MGIMELLI
Never mind it looks like pt# 20018 is just the stem. So you would have to break the tire down and re use the original sensor and attach to the new stem?
MGIMELLI is offline
post #18 of 18 Old 01-03-2013, 09:05 PM
gregaf3
Yes, they should have the t10 bit to separate the sensor from the valve stem. I took the jeep in had the sensors removed then came back and had them install the new ones
ForumRunner_20130103_200432.jpg   ForumRunner_20130103_200500.jpg   ForumRunner_20130103_200539.jpg
Professional Slacker
gregaf3 is offline
