2013 Manual Gear ? - JeepForum.com
post #1 of 8 Old 09-30-2013, 06:15 PM Thread Starter
JohnBarleycorn
2013 Manual Gear ?
I have a stock '13 jk 2dr with 33" km2's manual tranny and 3.21's (i think). I am looking at installing a TT LSD and figured I might as well do gears while I am at it. I will at some point go with 35's so I would like to future proof myself. What would driving 33's on 4.88's be like? My tires have less than 4k miles on them so the bigger rubber wont be happening for a while. Also what advantages are there in adding the TT to the front in addition to the rear? For background the rig is my daily driver but I go up some steep passes to get to the mountains several times a month. Also in the late spring early fall I have to drive snow covered logging roads. In the winter I also plan on towing a couple of snowmobiles.
Thanks in advance for your help.
All things are possible in a Jeep
JohnBarleycorn is offline
post #2 of 8 Old 09-30-2013, 07:17 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
Your mileage will suffer and 1st gear will be completely useless, but it'll do for a bit
My builds:
and
or follow us on
spyder6 is offline
post #3 of 8 Old 10-01-2013, 01:50 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Yup, I am running 4.88 with 35s and often start in 2nd gear...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #4 of 8 Old 10-01-2013, 02:17 PM
SLADE
It's really going to depend on your daily commute and how fast you normally drive. The 4.88 gears won't effect your fuel mileage much if any until you get above 50MPH - 55MPH. If you drive highway daily and must maintain 65MPH or 70MPH+ for long periods, then you'll see a larger impact to your fuel economy.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #5 of 8 Old 10-01-2013, 04:15 PM
ROCKR8R
Consider 4.56 too. Many consider the 4.10/3.6L/manual to be great for 35's. 4.56 will have you set up for 35/37" tires in the future. 4.88 will for sure spin them 33's.
-Dan
ROCKR8R is offline
post #6 of 8 Old 10-01-2013, 06:34 PM Thread Starter
JohnBarleycorn
I would say 80% of my daily driving is on side streets getting to work, 45 mph tops. But 75% of my miles are actually on highway either driving into the city or across the state over our mountain passes. I think I would prefer optimal drivability for going over the mountains, currently I have to downshift to 4th and even 3rd to maintain speed. A good mix of performance and economy would be desirable.
post #7 of 8 Old 10-01-2013, 07:20 PM
SLADE
You'll be happy with 4.88's and 35's. The 3.6 has plenty of RPM's to work with so you'll be fine with the 33's and 4.88's for a little while, but you will definitely be out of the green /"ECO" RPM range when you running on the highway.
I'm running 4.88's and 35's on my 13 6 speed JK and am very happy with them for my driving. If I where to put more highway miles on it, I would lean toward 4.56's.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #8 of 8 Old 10-01-2013, 10:02 PM
river2c
2014 JK Wrangler
I have a 2 door Rubicon 6 speed with the stock 4.10s on 35" tires. It does OK climbing mountain grades but 4.56s would be perfect IMO.
2014 JKU Copperhead
river2c is offline
