2013 JKU strange smell - JeepForum.com
post #1 of 8 Old 06-16-2013, 06:33 PM Thread Starter
LTGreek
A few month ago, I bought a new 2013 JKU and now when I hit over 4500 rpm I smell something burning. It goes away after a while but I am beginning to get worried.
My question is Has anybody else had a similar problem? If so, please help so I can tell the dealer where to look. Since they can't find anything.
No leaks,
last oil change at 4000 mile, she burned a half a quart of oil.
No broken hoses,
Not the smell of a semi burning up it's brakes,
Dealer won't spend the time to figure it out.
LTGreek is offline
post #2 of 8 Old 06-16-2013, 07:26 PM
genius
My 2013 unlimited rubicon did the same thing when I floored it. I would smell it coming through the vents when I slowed down. It stopped after about 5000 or 6000 miles. Never found out what it was.
genius is offline
post #3 of 8 Old 06-16-2013, 07:38 PM
AlbertaJeeper
Ya I've noticed a smell like that a few times, I always just assumed it was a vehicle in front of me. Must just be some sort of chemical or paint or coating that wears off
AlbertaJeeper is offline
post #4 of 8 Old 06-16-2013, 09:12 PM
wilgeno
Bug-Out!
wilgeno's Avatar
I noticed a odd smell after driving to Duluth, MN yesterday. When I stopped I stepped out and smelled what was maybe oil or similar fluid burning. I poped the hood and looked around. I didn't see any signs of fluid leaks. Very weird. BTW: I just turned 1000 miles on her yesterday.
wilgeno is offline
post #5 of 8 Old 06-16-2013, 10:50 PM
tonywauls
My jeep has 5000 miles on it and i just replaced the exhaust. Now ihave that smell too. I think its just burn off and will go away but definitely worrysome.
tonywauls is offline
post #6 of 8 Old 06-16-2013, 11:35 PM
OregonVette
This will go away.
In 2006/-2008 there were many JKs with this exact same situation. Especially if you get them wet/muddy. I always thought it was the catalytic and/or the coating the put on the exhaust system. Idk. Just a guess. Btw, it stopped about a year later
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline
post #7 of 8 Old 06-17-2013, 04:10 AM
tankinyj
First couple thousand miles on my 2012 had that weird smell. Completely normal, nothing to see here
2012 JK, 44s locked on 4.56s, 4:1, 3" on clayton arms, 37" PBRs
Crush Orange Jeep Member #55
tankinyj is offline
post #8 of 8 Old 06-17-2013, 05:33 AM
Wavedatya
2010 JK Wrangler
Probably just oil from the manufacturing process burning off. It could also be just the environment. Sometimes I smell biting when driving but it goes away so I assume its someone else or a factory nearby.
If there is no smoke I wouldn't worry too much. Good news is you went to the dealer so if anything should happens or burn you have it on file you complained it.
Could also be the exhaust you're smelling. I'm sure they have oil in them from the manufacturer that will burn away
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
