2013 Jku Gearing question - JeepForum.com
post #1 of 11 Old 07-08-2013, 11:10 PM Thread Starter
ball0616
I need to update my profile but I have a 2013 JKU with 3" BDS lift, pintler beadlocks, and 35" falken wild peaks. Just had the gears swapped out with 4.88's and run around 3100 Rpms going 75 mph. My question is this bad for the engine? I like the power but the gears just seem to be too much.
ball0616 is offline
post #2 of 11 Old 07-09-2013, 03:36 AM
AveCat
No should be fine. You gas mileage will suffer but your engine should be just fine.
2012 Wrangler JK 3.6 W/ 6 Speed bought 2/15/13
2.5" Rock Krawler Lift - Bilstein 5100s - 315/70/17 Duratracs - AEV Control Arms
TruckLite - Rigid
AveCat is offline
post #3 of 11 Old 07-09-2013, 06:47 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
Your engine redlines at almost 7000rpm. What are you worried about
My builds:
and
or follow us on
spyder6 is offline
post #4 of 11 Old 07-09-2013, 10:49 AM
1222
RIP John
1222's Avatar
That is a lot of rpms to be cruising down the freeway with, who in the heck advised you to install those gears for a 2013 and 35s?
1222 is offline
post #5 of 11 Old 07-09-2013, 10:57 AM
spyder6
spyder6's Avatar
2010
Sounds perfect to me
My builds:
and
or follow us on
spyder6 is offline
post #6 of 11 Old 07-09-2013, 11:16 AM
jchappy
2011 JK Wrangler
I think someone advised you wrong on your gear set, 4.88 would be good for a 3.8 but not a 3.6 unless you plan on going bigger tires soon
MY NEW JEEP- 2011 JEEP JKUR, Body Armor front bumper, Warn XD9000I winch, Synthetic winch line,XRC Rear Bumper W/Tire carrier, OBA W/1Gal Tank, Terafex 2.5in spring lift, Bilstein 5100 shocks,GY 315/70R17 Duratracs, 4.88 G2 gears, Cobra 75 CB
MY OLD JEEP-1999 Wrangler Sport 4.0L, 4" Pro Comp Lift, 33" BFG's, 8K winch, SYE, Viking soft top, onboard CO2 and all the recovery straps and equipment
jchappy is offline
post #7 of 11 Old 07-09-2013, 11:16 AM
1222
RIP John
1222's Avatar
It would.
1222 is offline
post #8 of 11 Old 07-09-2013, 11:25 AM
spyder6
spyder6's Avatar
2010
It would.
My builds:
and
or follow us on
spyder6 is offline
post #9 of 11 Old 07-09-2013, 11:41 AM
222Doc
222Doc's Avatar
I would not have went past 4:56 with only 35" as the long term view if a DD on any 012+. If an off road toy sure. 4:88 is more a performance gearing for 35"s. 4:56 would have been spot on . 4:88 would lean to 37"s. but I would NOT even think about that with a D30 front unless this is a mall crawler.
222Doc is offline
post #10 of 11 Old 07-09-2013, 04:55 PM
Butterjeep
2015 WK
OP, you're fine. I'd say you're about right but if you have to choose, I'd always have a bit too much gearing than not enough. Kind of the same thinking when driving a stick where I'd rather be a gear lower vs a gear higher. Revving slightly higher is always better than lugging your motor.
The Pentastar loves to rev and 3000 to 3500 rpm at freeway speeds is no problem. Your gas mileage may suffer slightly but the difference is minimal.
Not that you need it and especially with today's advanced oils and cleaner fuels, it's really not an issue but it was actually recommended to drive a gear lower on the freeway every once in a while to "blow out" the carbon buildup on your valves. Stay on top of your oil changes and enjoy your Jeep!
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #11 of 11 Old 07-23-2013, 03:03 PM Thread Starter
ball0616
Thanks for the responses. I originally planned on 4.56's but the tech said I would be happier with the lower gear. I do some crawling here and there but it just seems like a lot of RPM's for a DD.
I have no intentions on going to 37's so looks like I will just suffer some gas mileage, not that I bought a jeep for its GREAT gas mileage anyway.
ball0616 is offline
