2013 JKU engine rattles on startup - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 2013 JKU engine rattles on startup
Savvy Aluminum Gas Tank SkidFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 04-15-2014, 12:15 PM   #1
Can-Am
Searched the forum , didnt see anything . My 2013 JKU sounds weird on startup , like its low on oil almost , like a dry start . I use Mobil 1 Synthetic and factory filters , and i change oil every 5k miles . Bugs the crap outta me .
Anyone else ? Or point me to a thread if there is one . Many thanks .
2004 KJ Liberty Limited (kids)
2011 KK Liberty Jet (wifes)
2013 JKU Sport (mine)
Can-Am is offline   Reply With Quote
Unread 04-15-2014, 12:40 PM   #2
ck1
2014 JK Wrangler
i just bought my 2014 JKU and it does the same thing and drives me nuts...it only does it stone cold like sitting over night...thought it would go away after the first oil change but guess not...i only have 400 miles so lets see after the first oil change...curious on what others have to say
14 JK unlimited- AMPD
91 XJ Ltd,RE 3.5 Sf JKS LCAs, JKS Track Bar, TNT unibody stiffeners
ck1 is offline   Reply With Quote
Unread 04-15-2014, 04:19 PM   #3
df5745
My 2013 JKU does the same thing. Bought it used about 2 months ago and it has about 13,100 miles on it. It only does this when it sits a few days without being used. Hopefully someone can chime in if this is an issue that needs to be addressed by the dealer or a common issue with the 3.6.
df5745 is offline   Reply With Quote
Unread 04-15-2014, 05:03 PM   #4
222Doc
Its a design feature.
[URL=http://www.bullhead4wheelersinc.com[/URL]
222Doc is offline   Reply With Quote
Unread 04-15-2014, 07:19 PM   #5
gjeffers72
My 2007 does it still at 110000 miles. Im pretty sure Mine is a heat shield vibrating and only does it for about 5-10 seconds after cold startup. I quit worrying about it long ago!
gjeffers72 is offline   Reply With Quote
Unread 04-15-2014, 08:09 PM   #6
mtnbiker995
Livin the dream
mtnbiker995's Avatar
2009 JK Wrangler
Mine does it as well if it's cold outside! Pushing 100k miles and still running strong! (well as strong as a minivan can run )
My rebuild
mtnbiker995 is offline   Reply With Quote
Unread 04-16-2014, 04:26 AM   #7
Bnabb
Every jk I've seen or heard about does it on cold startup, like the old fords use to do just not nearly as bad.
1993 YJ
2001 XJ
2009 JK
1950 Chevy 3600
Bnabb is offline   Reply With Quote
Unread 04-16-2014, 08:12 AM   #8
20181c
2009 JK Wrangler
Check to see if there is an extended, (large capacity ) oil filter on it. I had the same problem when I installed a larger capacity oil filter on my 2009 Rubi and took it to the dealer and they told me to put a regular size filter back on. I went to NAPA and bought a standard size WIX Gold filter and installed it and the problem went away.
09 Rubi Unlimited Stone White
ORH liner, Cooltech, CB, Weathertech, Thule Track system.
20181c is offline   Reply With Quote
Unread 04-16-2014, 11:33 AM   #9
jasonl23
This is normal on this engine. My 2012 JK, my wifes 2011 Grand Cherokee and my 14' all do it.
jasonl23 is offline   Reply With Quote
Unread 04-16-2014, 11:38 AM   #10
JIMBOX
My 2001 Ford Ranger doesit (200,000 miles), but not the JKUR-
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote
Unread 04-16-2014, 12:11 PM   #11
paul84043
A little clatter and possibly injector noise is always normal at startup. Every vehicle I have ever owned did it to some extent.
As long as it goes away in a few seconds, it's nothing to worry about.
A sure fire fix is to keep the radio turned up when you shut off the Jeep. That will quiet it right down at startup.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline   Reply With Quote
Unread 04-16-2014, 08:28 PM   #12
Butterjeep
Yep, both my 3.6's (JK and WK2) do it. It's the lifters clattering until oil pumps up into them. No big deal.
2012 JK
2014 WK2
Butterjeep is offline   Reply With Quote
