2013 JKU Belly Skid - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 2013 JKU Belly Skid
Corbeau Seats & Harness from CCOR!*VOTE NOW Help Metalcloak Giveaway an XJ Suspension*Bds suspension discount
Unread 02-18-2014, 04:48 PM   #1
2013JK4Rubicon
Junior Member
2013JK4Rubicon's Avatar
2013 JKU Belly Skid
An open forum question here friends. My 10-A Rubicon needs some help
around her midsection. Any reccomendations on skidding her front to back please. And more importantly why. Your input is very welcomed
2013 10A JKU ANVIL - Metal Cloak (MC) GC & 6-Pak shocks, MC Overland innner & outer Fenders, rock sliders and lower body armor,5:13's, ARTEC Axle Truss, 3 piston SS calipers,Tom Woods 1310 shafts, MT 37" ATZ-P3's, SPOD, Genisis Dual Battery Holder & Isolator w/ dual Optima's, Warn 9.5 CTI-S & Pro Link, ARB CKMTA12 w/ CMM ARB Compressor Underseat Mount, Rigid Industries 40" E-2, 2-SRQ's out back, 4-D2 drivers up front, XRC Atlas rear bumper and tire carrier, GOBI Rack, Truck Vault w/110V power inverter & ARB 50QT
2013JK4Rubicon is offline   Reply With Quote
Unread 02-18-2014, 05:46 PM   #2
mrwhipple
I went with aluminum skids. Plenty beefy, much lighter than steel and they won't rust. I've beat the crap out of mine and they're holding just fine.
River Raider, ASFIR, TNT Customs all make great aluminum skids.
If you're looking at steel skids: JCR, River Raider, Rock Hard, M.O.R.E are all great companies. OrFab is releasing a full set of skids in a couple of months I believe. They're really nice. TNT might have steel versions as well.
silver jkur
mrwhipple is offline   Reply With Quote
Unread 02-19-2014, 12:52 AM   #3
ben_badassjeeps
Vendor
We've got a few options for you to think about...
First up is this JK Transfer Case Skid, in 1/4" Aluminum from Genright:
Going this route will give you about an 1-1/2" of extra ground clearance. It's a big investment as you won't be able to use the stock gas tank in its existing location. Going with this setup, your best bet would be to ditch the stock tank and run the matching Genright tank to go with it. This whole setup would set you back $1799.98 and is only available in aluminum.
If you spent the same money on a RiverRaider setup, you'd end up with something like this:
This system is available in Steel or Aluminum. The image and link above is that of the aluminum version. Weighs in about 73 pounds and can also be upgraded to include RiverRaiders UHMV polyethylene panels that are designed to slide over rocks and obstacles. The aluminum version pictured above would be in the same ball park as the Genright option at $1724.99. Your clearance gains are roughly the same as the Genright system, but you gain the addition of a not just a transfer case skid, but also a gas tank skid, oil pan skid, transmission skid, evap skid and we even throw in a fumoto oil drain valve. Basically bolt it up and go wheel.
Ben Whitney, Owner
Boss Research Inc.
Phone: 778-435-2169
E-mail: ben@badassjeeps.com
Website: www.badassjeeps.com
Use the coupon code: "jeepforum2014" for a 5% discount on all of our Currie Enterprises, Genright Offroad, RiverRaider Offroad and RCV Performance Gear!
ben_badassjeeps is offline   Reply With Quote
Unread 02-19-2014, 01:18 AM   #4
HOKIES2010
HOKIES2010's Avatar
2011 JK Wrangler
Going through this process as well. So far I have narrowed it down to JCR and Clayton since I am not going with Aluminum. If I were to go Aluminum I would either go with Genright or ASFIR. Also tyring to figure out if I want to change out the factory cross member. It seems to get banged up really easy. Clayton, OR-FAB, Synergy and Poison Spyder are just acouple that make HD cross members. The OR-FAB one is supposed to raise clearance and the Syngery has the skid built in with te crossmember.
I really like the way Clayton and JCR are designed. I have alot of JCR stuff and their quality is top notch and they are cost effective plus they have really good customer relations. Brian is the one I catch on here. I contacted Clatyon to make sure their skids would work with my JKUR since I am not using their long arm kit. I would do the same if you like them, I talked to Alex through here on JF and he was very helpfull. Neither one of those make a gas skid yet. I havent commited on that yet anyways. I know Clayton was in the R&D phase last time I checked.
These things can range huge in price. That went into my steel choice. Affortable options can be had in the steel range from the EVO protek to the JCR skids or you can go all out aluminum.
Hope it helps
And does anyone have any thoughts on the rear driveshaft/diff skid AEV makes? I haven't hung my rear diff on anything yet but that would seem like it could go bad if you did.
Black 2011 JKU Rubicon/ 6spd w/5.13 gears/ 5.5" RK X-Factor Mid Arm (3.5") Springs, RRD Shocks/ Poly Inner/Outter Sleeves and C-Gussets/ Reid HD Knuckes/ 37" Nitto Trail Grapplers on 17" MB72s/ ACE Flat Fenders/ JCR Front Stubby Stinger, Rear Stubby Bumper and JCR Deluxe Sliders/ Warn 9.5 cti w/Syn line/ OR-Fab Swing Away Tire Carrier w/Fuel Can mounts
Oct 2012/Dec 2013 JKOTM
My work in progress:http://www.jeepforum.com/forum/f96/r...dated-2206865/
Couldn't have done it without Jason@KrawlOff-Road.com!!!
HOKIES2010 is offline   Reply With Quote
Unread 02-21-2014, 07:13 PM   #5
David_M
David_M's Avatar
I too am in the process of deciding on a skid system for my '13 JKU. I have been holding out for the Nemesis Industries unit which has been in R&D for some time now. Honestly, my patients are about to run out and I'm going to pull the trigger on another manufacturer soon if Nemesis doesn't deliver soon. I also understand that Artec is about to release a complete steel version soon. They would be another brand I would consider. Hoping to make a purchase soon.
My '13 Gecko JKU On 37's Build
David_M is offline   Reply With Quote
Unread 02-21-2014, 10:05 PM   #6
darkknight1999
Aut Vincere Aut Mori
darkknight1999's Avatar
Looks like I'll be saving up for the RiverRaiders setup... that setup is awesome
JOHN
"Pumping lots of bass to a tweeter is like stuffing a basketball into a pigeon... neither will survive"
"So yeah... if you're not going to do a job right, either because you're just to damn lazy or you're don't know how... then yeah, don't touch it, because then someone has to clean up the freaking mess you made." - ME!
KCCO
darkknight1999 is offline   Reply With Quote
Unread 02-21-2014, 11:08 PM   #7
mrwhipple
It is sweet.
silver jkur
Unread 02-22-2014, 08:31 AM   #8
2013JK4Rubicon
Junior Member
I agree the GENTRIGHT looks great, leaning towards the RR setup. pics coming soon.
Unread 02-22-2014, 09:43 AM   #9
222Doc
i think that pic of the RR is old design. Its one piece now. were that one is two. Getting to oil is not clean even with the access panel. most go to a "fumoto valve. to make it a celan and simple job. Now my valve went bad this last oil change noticed it was leaking the slow drip.
If you have a Auto i would wrap the Ypipe if its still under the trans pan(2d no choice). once you close up that area with a skid. I have no #'s on how hot that makes the oil. but my intuition says its enough, off road crawling in rocks to create as much added heat to nullify the coolers ability. That ypipe gets very hot, after i wrapped it the pipe is no longer baking that area.
http://parker4wheelers.tripod.com/index.html
http://www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote
Unread 02-22-2014, 09:47 AM   #10
BruceM1964
I'm not a fan of aluminum skids, had a cobble stone go through one on a VW TDI, notorious for low slung oil pans, I believe a steel skid would have prevented the $1000+ bill that ensued.
BruceM1964 is offline   Reply With Quote
Unread 02-22-2014, 10:04 AM   #11
Maertz
Hating Jk's Since 07'
Maertz's Avatar
2009 JK Wrangler
id personally make my own..id use aluminum and possibly uhmv also. if i recall a 4x8 sheet of 1/4 aluminum is under 200 bucks and you could cover probably everything you wanted.
Wishing I Wasn't Part Of The 'JK' Crowd...
September 2013 JKOTM
A JK On Junkyard 60s
Maertz is offline   Reply With Quote
Unread 02-22-2014, 10:30 AM   #12
2013JK4Rubicon
Junior Member
hey Maertz....is that you volunteering to come down to Capitan and help me do that?
We have lots of National forest to cruise around in afterwards.
Unread 02-22-2014, 10:40 AM   #13
Dumpsterfish
Dumpsterfish's Avatar
This thread is relevant to my interests...next mod will be full skid replacement. I really want to go aluminum (the freakin' JKU is heavy enough as it is), but will Al hold its own in the rock gardens of SoCal? I feel like I might just have to buy the parts again in a couple seasons.
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...stock, for now.
Dumpsterfish is offline   Reply With Quote
Unread 02-22-2014, 10:59 AM   #14
mrwhipple
The aluminum will hold just fine. No worries.
silver jkur
Unread 02-22-2014, 01:54 PM   #15
Maertz
Maertz's Avatar
2009 JK Wrangler
Lol where u at?!
