2013 JK Regear - Page 2 - JeepForum.com
post #16 of 26 Old 09-13-2013, 07:20 AM Thread Starter
razor1115
Originally Posted by TrailRated2011 View Post
@razor5111: Is this the Gear Ratio Chart that you are referring to for your decision making?
http://www.tnjeeps.com/uploads/galle..._46_253610.jpg
correct
razor1115 is offline
post #17 of 26 Old 09-14-2013, 05:40 AM
SLADE
Stop being afraid of gears.
I'm running 35's and 4.88's on my 13 JK with the 6 speed and can run 60mph - 65mph and stay in the green/ECO area of the tac. My speedo is recalibrated with the AEV Procal and I'm getting the same MPG (17mpg - 17.8mpg) that I did with 3.73's and 285's (33" tire). When I was running the 285's and 3.73's, I wanted 4.10's.
You will still be in the green/ECO on your tac with 4.56's, 35's, and running 70 mph. 4.10's will not comfortably give you the full use of 6th gear especially if you do any towing/hauling or driving in the mountains.
I can guarantee 2 things.
1) You will not regret going with 4.56 gears.
2)If you go with 4.10's, you'll allways wish you chose 4.56's.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #18 of 26 Old 12-19-2013, 07:50 AM Thread Starter
razor1115
FYI - going with 4.56 gears. Already have everything spec'd out, just looking for an installer.
post #19 of 26 Old 12-19-2013, 06:47 PM
buns79
When you find one let me know, I just ordered my 4.88s today! A friend of mine will do it but he might have to go to Texas for work for like 6 months so if he does I'm going to need a installer too!
13 jku 6sp, 4:88s, elockers, 3.5" RK, Ps fenders and front bumber, ace rear, 37" km2s Olllllll0
buns79 is offline
post #20 of 26 Old 12-20-2013, 07:38 AM Thread Starter
razor1115
10-4
post #21 of 26 Old 12-20-2013, 07:25 PM
buns79
Not real close to you but these guys came recommended to me and I was quoted 200-250 labor per axle for gear and locker install... Bates Automotive
www.batesautoandtow.com
108 N Eaton St, Edinburg
(217) 820-6721
more info
buns79 is offline
post #22 of 26 Old 07-18-2014, 06:57 AM Thread Starter
razor1115
Did a great job:
Quad Cities - Moline
DK 4x4 5331 Avenue of the Cities
Dave Koenig in Moline
309-739-0056
Public 2 Collaborators 3 views
Created on May 21 By Updated May 22
Rate this map Write a comment KML
Moline, IL 61265
post #23 of 26 Old 07-18-2014, 06:57 AM Thread Starter
razor1115
Did a great job:
309-739-0056
Moline, IL 61265
post #24 of 26 Old 07-19-2014, 07:24 AM
lumpster
lumpster's Avatar
Happy with the results? 4.56 turn out spot on?
lumpster is offline
post #25 of 26 Old 07-19-2014, 10:28 AM Thread Starter
razor1115
Yes happy. A lot better trail manners now and better high altitude capability. 14-16mpg on highway but was running 80mph, 2600ish rpm and lots of wind. 19-22mpg through all the CO Rockies (lower rpm crisis speeds). Plenty of power now in 6th gear while running highway speeds, too
post #26 of 26 Old 07-19-2014, 03:01 PM
SLADE
Good to hear.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
