2013 exhaust on a 2009? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 2013 exhaust on a 2009?
Last Day to take advantage of 5% off August PromoThe Cure for your Tie Rod Roll!The Original 3/8" Ruffstuff Diff Cover!
Unread 08-29-2015, 11:10 AM   #1
jimk403
2009 JK Wrangler
I need to replace the mid pipe on the 09. Before I cut it off, just want to verify the 13 pipe will fit. Both 4 door.
Just my opinion, yours will differ.
Proud owner of: '09 Rubicon Unlimited, '90 XJ, '88 XJ, '77 J-10
jimk403 is offline   Reply With Quote Quick reply to this message
Unread 08-29-2015, 12:00 PM   #2
222Doc
222Doc's Avatar
i would bet not as a direct fit. so many changes went into the 3.6.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 08-29-2015, 07:02 PM   #3
rich6700
Will not fit. 2 completely different systems.
rich6700 is offline   Reply With Quote Quick reply to this message
Unread 08-29-2015, 09:31 PM   #4
jimk403
2009 JK Wrangler
In a word, kinda. Sitting on the ground next to each other they look nearly the same. The piece I needed is from the y-pipe to the muffler, just to clarify. The 2013 is a couple inches (at most) shorter. But it's on, resonator and all. Just as quiet as the hushpower that I removed.
