2013 Check Engine light - JeepForum.com
post #1 of 16 Old 06-01-2013, 07:45 AM Thread Starter
blackbonnie
My check engine light came on at around 2100 miles the other day. I have a 13 JKUR. I had a 12 JKUR last year and the same thing happened - needed the head replaced. I have tried the gas cap and tried the on-off, on-off thing to get the code....not happening. My guess is that the head problem Chrysler says they have fixed is still out there. Anyone have this yet?
blackbonnie is offline
post #2 of 16 Old 06-01-2013, 11:42 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Is the light on steady or flashing?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 16 Old 06-01-2013, 11:49 AM
2Five22
Symptoms?
'13 JK Rubicon in white - the German Shepherd's
'13 JKU Sport in gecko - her Majesty's
I am just the chauffeur.
2Five22 is offline
post #4 of 16 Old 06-01-2013, 07:37 PM
NCSahara
2006 KJ Liberty
Don't guess go to Advance or Auto Zone and get it scanned or just get it to the dealer on Monday.
NCSahara is offline
post #5 of 16 Old 06-02-2013, 12:00 PM
Godholio
Yeah this.
Your diagnostic process went from gas cap to bad cylinder head with no actual procedure to figure it out.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #6 of 16 Old 06-02-2013, 02:44 PM
222Doc
222Doc's Avatar
with one post we may never know.
If it mills out to P302. p306 then it may well be the same issue and is not a good sign.
222Doc is online now
post #7 of 16 Old 06-02-2013, 03:57 PM Thread Starter
blackbonnie
Ok, sorry for no immediate follow up....I don't live at my computer screen. ZERO symptoms and now the light has gone off. This is exactly what happened with my '12 which was a bad head. I was simply looking to see if anyone knows if the '13's have this head issue also even though Chrysler says it was less than 1% and they have fixed it. I am guessing no one else has had this problem so I will be taking it to the dealer for correction. Haven't had the chance with life and kids. I will post the answer once I have it.
post #8 of 16 Old 06-04-2013, 12:34 PM
BK0311
My 13' check engine light came on around 5000. The oil pressure sensor gauge had gone bad.
2013 JKR
BK0311 is offline
post #9 of 16 Old 06-04-2013, 01:44 PM
222Doc
222Doc's Avatar
need to read the code, You can not guess.
post #10 of 16 Old 06-04-2013, 02:14 PM
Spank
2014 JK Wrangler
The CEL can be a bazillion different things. Don't assume, check the codes.
Wouldn't a gas cap issue present GASCAP on the dash instead of a CEL or did they change that?
'14 Wrangler Unlimited Rubicon
Spank is offline
post #11 of 16 Old 06-06-2013, 09:44 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
from the 2013 JK owner manual:
If the vehicle diagnostic system determines that the fuel filler cap is loose, improperly installed, or damaged, a “gASCAP” message will display in the odometer display area. Tighten the fuel filler cap properly and press the TRIP ODOMETER button to turn off the message. If the problem continues, the message will appear the next time the vehicle is started.
from the 2013 JK service manual:
Diagnostic Trouble Code
P0457-LOOSE FUEL CAP
Theory of Operation
Fuel level is recorded when the ignition key is turned off and is compared to the fuel level when the ignition key is turned back on. The Powertrain Control Module (PCM) recognizes an increase in fuel level and will fail the Large leak test because the fuel cap is broken or not installed properly. GAS CAP will be displayed to inform the owner that the cap is off or loose.
When Monitored:
Engine running. Ambient Temperature between 4° C and 35° C (40° F and 95° F) Close Loop fuel system. Test runs after failing the large leak size test as inconclusive and the PCM has sensed a fuel increase.
Set Condition:
If a leak greater than .090” is detected by the Powertrain Control Module (PCM) for three consecutive cold start trips after a significant fuel level change, this DTC will set. One good trip turns off the MIL.
Possible Causes
LOOSE OR MISSING FUEL CAP
JeepCares is online now
post #12 of 16 Old 06-06-2013, 10:36 AM
Wrigley
Theory of Operation
When Monitored:
Set Condition:
Possible Causes
I got the "GASCAP" display on my 2013 JK. I took the gascap off, put it back on tightly, and the "GASCAP" display on the odometer display went away on its own within 10 miles.
Mike
Wrigley is offline
post #13 of 16 Old 01-10-2014, 12:29 PM
labelle15
I'm having the same problem. I haven't taken it to the dealership yet though because the check engine light came on a couple of days ago. I tried the on off trick and nothing happened. The light is steady, no blinking. No symptoms. Any advice?
labelle15 is offline
post #14 of 16 Old 01-10-2014, 12:45 PM
Jiblet
When you say nothing happened, you mean it didn't run the diagnostic at all or just didn't show a code?
Most chain auto parts stores read codes for free. And not every code shows up through the inboard diagnostic anyway.
Jiblet is offline
post #15 of 16 Old 01-10-2014, 12:55 PM
STORM_JK
Only way to know is to have it checked, they can see history codes as well if it turned off
'13 JK 6-spd | 3.5" RK | 35" MTR/K | Lots Of Welding
STORM_JK is offline
