2013 breather tubes - JeepForum.com
post #1 of 7 Old 04-01-2013, 09:48 PM Thread Starter
Filthy-Beast
2013 breather tubes
If it was already known, I missed it. While doing the front lift on my 2013 JK I noticed that the front axle breather tube ends at the top of the shock tower on the drivers side and not up higher on the firewall. did anyone else find this?
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #2 of 7 Old 04-01-2013, 10:00 PM
ncb
My 2009 is the same.
ncb is offline
post #3 of 7 Old 04-01-2013, 10:00 PM
222Doc
222Doc's Avatar
same on our 012
222Doc is online now
post #4 of 7 Old 04-01-2013, 10:18 PM
brianjw
Yep, same on the rear. Pick up some rubber tubing and vacuum hose connectors and extend them. Don't forget the transfer case and trans breathers while you're at it.
brianjw is offline
post #5 of 7 Old 04-01-2013, 10:21 PM
Tanimal
I just ran them both to the inside of my Jeep and as high up as I could go. No water should get to them there and haven't had any smell or leaking inside the cabin.
Pictures are from when I monstalined my tub and I have a couple other pics on page 3 of my build thread.
Front:
Rear:
Learning as I go and it's worth every penny!
Tanimal is offline
post #6 of 7 Old 04-01-2013, 11:11 PM
Racing Ron
FYI - if your axles / tcase / trans is hot and gets in cool/cold water, you will have water enter through the seals regardless of breather tube length.
Cross a stream - check/change the fluids.
Regards,
Ron
Racing Ron is offline
post #7 of 7 Old 04-01-2013, 11:19 PM
joe002
Tanimal - make sure you never overfill your diffs or you'll have a mess.
2008 Rubicon - 2 Door - Flame Red - Automatic - MyGIG - Power Group - Deep Tint.
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Stubby Bump, Currie F/R Adj Trac Bars, Daystar Upper Dash, FireStik FireFly antenna, Kilby Rear Shock Skids, LoD Sig Stubby Bump, Midland 75-822 CB, Mopar Filler Door & Locking Gas Cap, Rancho LCA Skids, Rancho Oil Pan Armor, Riddler Diff Covers, custom Rubi Sliders, Sylvania X-treme Headlights, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relo, Woods SS Relo, Yukon 5.38s
joe002 is offline
