I have a 2013 JKUR on order, and noticed many guys on various JK forums have been complaining of "rattling" issues with their 6-Speed Manual Transmissions.
I would like to ask all new 2013 JK owners with Manual Transmissions to "chime-in" on this Poll, and elaborate (mileage issue(s) were noticed, etc) with posts as you see fit.
They're complaining because they're all ninnies that don't know any better. 75-80% of the 6 speeds (including both of mine) have rattled in neutral since the introduction of the 6speed in late. 2005
I have a 6spd 2013 JKUR (only 450 miles). I don't notice much difference in vibrations from any of the three TJs I've owned in the past. I haven't experienced any of the ghost shifting out of gears that others have complained about on the forums.
what you're talking about is isolated. every time i see someone complain about their transmission rattling its while its in neutral idling. they follow up that comment with how they just spent 30,000 on their Jeep and they feel it should be perfect despite that they've never own a Jeep before and have no concept of the component difference between car and truck.
Personally I think it's all relative to what you've driven before.
The standard is a little clunky, that's just the way it is. Doesn't mean it's going to explode any time soon.
What we need is a new poll that says "have you owned a manual transmission before?" and only allow the people complaining about it to vote.
I've owned manual transmission 4x4s and sports cars from 1988-2012 and every single one of them has rattled, clunked, and vibrated. It's the nature of the beast when you've got a direct linkage between the flywheel and tires. You're going to get these "symptoms". It's 100% normal. That's why when you let a mechanic look at it, he'll be like...Ok, what's the problem again?
I have a 2012 Rubicon (6,500 miles) with the 6 speed and I have started to notice a rattle in 4th gear around 2,000 rpm under moderate load. Full throttle and the noise goes away.
The NV3550 in my '04 Rubicon made noise in neutral, this is different.
Well I for one am surprised. We can soundly and scientifically deduce now that 20% of all Manual Jeep Wranglers have problems based on the survey which at this point reflects said scientifically sound data point.
Whoodathunk?
And my wife says the interwebs are useless... Hah!.
Mine rattled in thrid gear too on acceleration, I wedged my hand between the plastic radio console and the plastic shifter surround (where the mesh holder thing is) and no more rattling.
I have an '11 JKU 6spd. Does the same thing in 4th or 5th...usually it's because it should've been say in 3rd instead of 4th, 4th instead of 5th and so on. I've had a 99tj 5spd and a '02tj 5 spd...they both did the same thing. I could be way off but maybe you're shifting too early and putting stress on it.
I have no rattles in my transmission. Only noises i notice are when i am shifting from 1st to 2nd. I am pretty sure these noises are normal since you are shifting from a 4.1 reduction gear to a 2.06. I might be off on these values but I know they are close and either way I am not going to worry about it.
My 13 has about 2700 miles on it. Last night I noticed a small ticking or rattling when sitting in neutral. If you press the clutch it goes away. No noise while in gear that I can hear.
That's what mine had, and it is starting to come back. My transmission was completely rebuilt within 2k miles, was good for another 3 and I just heard it again for the first time a few nights ago.
I've read it could be a input shaft or a throw out bearing, both were replaced on mine, and the sound came back. It doesn't affect the transmission that I can tell, it still runs and shifts smooth, but I'm going to take it back in a few weeks to get a new transmission put in it.
I believe it is the throw-out bearing. Just gonna leave it alone unless it gets much worse. Turning up the radio or removing the soft top seems to fix it.
My Jeep made a loud knocking sound about 2,500 miles in and it was the throw-out bearing. I had it replaced under warranty and I haven't had a problem since. The shifter rattling is a common thing, but eventually it'll get to the point where the constant vibration will weaken the plastic cap piece of the shifter knob and the noise that thing will make will drive you ****ing insane. Luckily, there are a variety of aftermarket shifter knobs to solve that issue.
Yes, it's a Jeep and not a luxury SUV, but I don't think it's unreasonable to want your brand new $30,000 vehicle be perfect. It still irritates me that Chrysler thinks it's cool to continue putting ****ty ball joints, ****ty trackbar mounts, and ****ty radios in the Wrangler.
Hoo Hoo, It started doing on the way home today so I took a members suggestion to push the Xfer case lever forward and the rattle stopped. Everytime I ran the rpm up and it rattled, I would push the lever forward and it stopped. So happy now. No I'm not taking it in, but will see if I can find out exactly what's loose or misadjusted.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
