2012 Wrangler Third brake light out. - JeepForum.com
post #1 of 5 Old 08-14-2013, 04:35 PM Thread Starter
paul84043
Apparently I'm the only person to ever have the center brake light fail.. I've searched and come up empty.
Went in for an oil change today and they tell me my third brake light is out.
I am still covered under warranty, but they didn't have anyone on hand to look at it, so I brought it home and tore into it myself.
I know floating vehicle electrical systems are a PITA, but I put a meter on the brake light connector and get no voltage from either connector to the door latch or across both terminals in the connector... I didn't try to land it anywhere else, I figured the bare metal door latch was a pretty good "ground".
I had this same problem metering a VW fuel pump, so it's probably something I'm doing wrong..
Side brake lights are working fine. Wiring looks fine.
Is there a separate relay for this light? (I seriously doubt it)
No other mods to this area of the Jeep.
I ohm out the LED light itself and get about 450 megohms, which seems high. The reading jumps around a lot though.
Anyone else attempt to troubleshoot this problem?
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #2 of 5 Old 08-14-2013, 07:20 PM
Prot
Prot's Avatar
2014 JK Wrangler
You do what a diode really does right? It allows electricity to flow in only one direction. Reverse your leads and post your reading.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #3 of 5 Old 08-14-2013, 08:28 PM
ncb
Hook meter leads to the two wires have someone press the brake pedal and check for 12 volts. If you have twelve volts then connect the brake light directly to the battery to test it. If it doesn't light up reverse the wires. I can't remember which color wire is + and - on the light. Start simple before ripping it apart.
ncb is offline
post #4 of 5 Old 08-15-2013, 05:52 AM Thread Starter
paul84043
I did this and got nothing, but I don't know how Chrysler does it's electrical. I'll get a longer test lead from work today so I know I'm landing it on a good solid negative to the battery and try again. I had my daughter run the brakes for me and the others were coming on.
I had this same issue on a VW fuel pump where I tested it every way to Sunday and never got a reading, but the new fuel pump worked...?
Freaking vehicle electrical systems...
I didn't reverse the leads on the LED assembly itself. By that time I was hot, sweaty, and seriously wondering if my meter is toast.
It's under warranty still, I just like to dig into things myself if possible. Even if the LED assembly has a blown diode (yes....I know what a diode is) it's a sealed unit and they should still replace it at no cost to me.
It's just frustrating because it should be so simple...yet it never is...
post #5 of 5 Old 08-15-2013, 07:37 AM
ncb
The Jeep is wired like most other vehicles. Chassis/body is a ground. In the case of the third brake light one wire is -/ground and the other is +12 volts.
ncb is offline
