2012 Wrangler Dash Removal/Lockpick Install - JeepForum.com
post #1 of 30 Old 01-14-2012, 11:20 AM Thread Starter
budmanm3
Just wanted to make an addition to this guys post on how to remove the dash by adding some photos for anyone that may find it helpful. I installed the CHR550 Lockpick device today.
I found these instructions helpful for 2011 and there wasn't anything different for the 2012.
http://www.jeepforum.com/forum/f96/2...amera-1120789/
Originally Posted by airstuff View Post
Just to help clarify the radio removal steps, which were a little sketchy in the prior posts: 1.Pull out the rubber tray from the top of the dash, you may need to give it a little tug. Remove the 7mm screw you find there. 2. Carefully pry away the plastic panel which is just below the steering wheel, prying the upper sides away first and easing your way down both sides. Use a very thin screwdriver and pad the surrounding trim so as not to leave marks. The bottom of the panel has plastic half-hinges that engage corresponding slots in the panel below the panel you're removing. When this panel is removed, you'll see two 7mm screws, one on the left of the steering column and one on the right. You'll note that these screws secure two tabs on the bottom of the instrument panel bezel, remove both screws. 3. You're actually going to be removing about half of the instrument panel bezel, which spans the area from the driver's door to just to the right of the radio. Don't worry, it's not as major a project as it seems. 4. Where the power window switches sit, they're surrounded by a small bezel. Prying carefully from the bottom, again using a pad where necessary, you will pop out the switch assembly and the surrounding bezel as a unit. Tug on this to get access to the switch/harness plug, which has a red button on the right side. The button is actually a catch, and you need to push on one end of it to release the harness from the switch. You'll now see a 7mm screw in the hole where the window switch was, remove it. 5. The instrument panel bezel is now removable; it's held in place only by friction tabs. Carefully lift the portion of the bezel just forward of the forwardmost, rightmost section (near the tray which you pulled the rubber tray from). With a little pressure, the friction tab will pop loose, and you can move around the bezel perimeter, popping the tabs loose as you go. 6. Adjust the steering wheel downward and you'll be able to lift the entire bezel assembly free. 7. The radio is in place with 4 7 mm screws, remove them and slide out the radio.
To re-install, just reverse the process.
In the beginning..
The pictures shall explain the rest.
2012 Sahara Unlimited
budmanm3 is offline
post #2 of 30 Old 01-14-2012, 11:21 AM Thread Starter
budmanm3
budmanm3 is offline
post #3 of 30 Old 01-14-2012, 02:22 PM
smittycm
Thanks for taking the time to post the pics. Pics truly are worth a thousand words. I'd choose a few pics like yours over written instructions every time.
2012 JKU Sport S, RK 2.5" Max Travel, Bilstein Shocks, AEV Savegre Wheels, GY Duratrac 315/70R17
smittycm is offline
post #4 of 30 Old 01-14-2012, 09:48 PM
cfp40
Great write up and pics. Thanks
cfp40 is offline
post #5 of 30 Old 01-14-2012, 10:39 PM
mattlago
Budman, my wife just bought me one of these for my birthday and I am going to install tomorrow or the next day. When is your birthday because I feel like I need to buy you a gift for writing up such a great install!!! My laptop will be in the passenger seat reading this as I do it. Thanks so much!
behold a pale horse: and his name that sat on him was Death, and Hell followed with him...
2012 JKU RUBI PALE TAN
mattlago is offline
post #6 of 30 Old 01-15-2012, 04:38 PM
basecamper
2011 WK
Budmann Great write up
So this is a 430N with a 6spd do all the lock pick features work? I have read about issues with the 730N and 6 spd but until now have not found anybody who has done it with the 430N
basecamper is offline
post #7 of 30 Old 01-15-2012, 08:20 PM
misfitJason
damn nice
misfitJason is offline
post #8 of 30 Old 01-15-2012, 08:24 PM
1222
RIP John
1222's Avatar
Excellent write-up and those are great pics that make it easy to understand the take down procedure.
1222 is offline
post #9 of 30 Old 01-17-2012, 08:41 AM Thread Starter
budmanm3
Originally Posted by misfitJason View Post
damn nice
Thanks guys.. i know pictures always help me, so figured I'd help everyone out.
I am having an issue with the Nav in motion. Everything else seems to work. The techs are working with me to figure it out, hopefully since I am somewhat local to them, I am going to meet with them and let them sort it out for the everyone's benifit.
budmanm3 is offline
post #10 of 30 Old 01-17-2012, 09:26 AM
Charles
2017 WK
Charles is offline
post #11 of 30 Old 01-17-2012, 11:15 AM
Deuskid
great write-up & pictorial,
subscribed for future reference
Deuskid is offline
post #12 of 30 Old 01-31-2012, 12:11 PM
amarzano
Great Write up!
I am looking at this for a 2012 430N Wrangler as well. I do have a question..
I see on the Costal site a V.4, CH550 and C8? What are all these different versions? Which do I need? V.4?
Thank you again!
Alex
amarzano is offline
post #13 of 30 Old 02-03-2012, 07:55 PM
mattlago
Any thoughts on why after installed only had passenger speakers and only at half volume? I pulled out to read more but as all plug in to factory slots I cant imagine what I messed up. Any advice is appreciated
2012 JKU
mattlago is offline
post #14 of 30 Old 02-25-2012, 01:22 PM
cbboard
thanks for the write up. it was of great help! made it really quick!
cbboard is offline
post #15 of 30 Old 02-25-2012, 05:48 PM
kade
how do you remove the dash part around all switches under the radio ?
kade is offline
mirror , mygig , uconnect , upgrade , wiring harness
2011 Dash Removal + Lockpick + camera rxjoe JK Wrangler Technical Forum 81 07-16-2012 02:48 AM
2011 / 2012 Dash & Stereo Removal video Charles JK Wrangler Technical Forum 8 06-23-2012 09:38 PM
Dash Removal For New Cd Install '98 gary1 Wrangler General Discussion 1 07-29-2008 01:07 PM
2008 Wrangler X Unlimited Dash Removal? mikeyshine JK Wrangler Technical Forum 5 06-25-2008 01:01 PM
Wrangler Dash pieces removal thinkwoods TJ Wrangler Technical Forum 4 08-31-2006 05:00 PM
