2012 Wrangler Auto Noise normal? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 2012 Wrangler Auto Noise normal?
Building a Bumper?Ruffstuff Axle Simple Swap Kit!~Artec JK 1 TON SWAP~
Unread 12-22-2011, 03:07 PM   #1
Fellstar
I'm usually pretty good at sniffing these issues out, and I've done multiple searches on Google and multiple JK related sites looking for any posts on this. I'm completely neurotic when it comes to my vehicles and generally hear more noises than most people.
When I put the car in gear there's a whine coming from the drive line. This whine is only audible when sitting still, or moving very slow. The whine goes away if I shift the transmission into neutral or park.
Have about 1400ish miles on her so far.
Anyone else noticed this noise?
Fellstar is offline   Reply With Quote
Unread 12-22-2011, 05:40 PM   #2
Fellstar
Dealer says front pump on the trans is louder than average. They're offering to drop the trans and replace. Telling me it isn't hurting anything.
2012 Rubicon - ACE Eng. Rock Sliders, Rockhard4x4 Full Front Bumper, SmittyBilt XRC8, Level 8 Strike 5 16x8.5's wrapped in 315/75-16 Nitto Terra Grapplers, 3" Teraflex coil lift with shock adapters, Teraflex HD Tire Carrier Hinge, Teraflex Exhaust Spacers. 1/2" coil spacer up front, 3/4" coil spacer in the rear.
Unread 12-23-2011, 05:49 AM   #3
MYounts
2014 JK Wrangler
I'm glad I'm not the only one. Sometimes when I'm walking down the street I here things going wrong with cars driving by. I've usually found that if it doesn't sound right it probably isn't--fortunately you found the "smoking gun."
MYounts is offline   Reply With Quote
Unread 12-23-2011, 07:16 AM   #4
Fellstar
Exactly the same.
Unread 04-11-2013, 02:38 PM   #5
mtbr
I've been searching for someone else with this issue too!
A year ago i had a tranny line leak fixed. it may have always
been there but after this is when i noticed the whine when
putting into gear. The dealership replaced the valve body
and filter which seemed to fix the problem...for a few months.
The noise came back and the service manager said it was just
fluid noise (not!) and don't worry about it. Well it seems to be
worse and much more noticeable once the Jeep is warmed up.
I'd love to hear from others with this issue, i'll take mine in soon
and post the outcome.
>(Automatic)
>Most noticeable when warmed up
>Putting into Drive or Reverse the noise is heard for a couple seconds
>Sometimes after driving for a while it can also be heard for a second
when beginning to move also for a second when turning the Jeep off.
2012 4 door Sahara / Black
2008 4 door Sahara / Rescue Green Jeep Club Member #15
1992 YJ / White
mtbr is offline   Reply With Quote
Unread 04-11-2013, 05:50 PM   #6
1222
Make mine a Jeep!
1222's Avatar
I have a noise too but not sure itís what you guys are hearing. Mine almost sounds like an alternator whine. When Iím in park and give more rpms the wine corresponds to the increase in engine speed. Been meaning to have the dealer take a look but actually forgot about it until this thread showed up.
1222 is offline   Reply With Quote
Unread 03-28-2014, 01:49 PM   #7
mtbr
>(Automatic)
A year later and the noise is still there, definitely not better but can't say its much worse. Dealer still says fluid noise (never heard fluid make that kind of noise)......just hope its covered with the drive train 5/100 warranty......
1992 YJ / White
Unread 03-28-2014, 09:56 PM   #8
PhatJK
2009 JK Wrangler
I have an 09 JKU auto and it's making these slight rattling noises that are so faint that you usually can only hear them while the Jeep is standing still like what the OP indicated.
When I shift from D to N, there is a slight whine of the hydraulic shifting into neutral and the rattling change tone and sorta came back. If there are music or road noise, you can't hear it. Also, the noise is louder during cold weather and it's getting warmer and the gear noise is almost noticeable.
I realize the OP posted about the 2012JK but maybe Chrysler design their auto the same way, with more gears that is.
[URL="http://www.flickr.com/photos/14945982@N08/"]My Flickr Page[/URL]
[SIZE="3"][COLOR="White"][B]09 Unlimited Rubicon [/B][/COLOR][/SIZE]
Teraflex 2.5" spring lift kit
ORFAB tire carrier
PhatJK is offline   Reply With Quote
Unread 03-30-2014, 02:04 AM   #9
73azbronco
13, dead silent in or out of gear. Ymmv.
73azbronco is offline   Reply With Quote
