2012 and up JK oil filters: Be careful what you buy. - JeepForum.com
post #1 of 4 Old 11-02-2013, 09:40 PM Thread Starter
1222
RIP John
1222's Avatar
Heres some very important info from JeepCares that concerns the 2012 and up (3.6 engine) JKs.
You can/should also check out this thread from charliebrownjk that prompted this sticky.
Thanks to JeepCares for this info:
Originally Posted by JeepCares View Post
Just an FYI - current MOPAR numbers:
A NEW OIL FILTER IS RELEASED FOR 2014 MODELS THAT INCLUDE A 3.6L / 3.2L OR 3.0L (PENTASTAR FAMILY ENGINE)
The oil filter that was used in the 2013 Pentastar engines WILL NOT work with the 2014 engine.
Using a 2013 filter on 2014 model engines will create an oil leak situation.
2014 - 68191349AA - Filter Kit = Filter and Cap O-ring
Not backward compatible
2013 is 68079744AB - Filter Kit = Filter and Cap O-ring
Not forward compatible
The below 2014 engines will also use the 2014 filter 68191349AA - Filter Kit = Filter and Cap O-ring
2014 3.6L, DS DX JC JF JK JS J3 LC LD LX RM RT VF WD WK W6
2014 3.2L, KL K2
2014 3.0L, JK LX WK (BUX)
1222 is offline
post #2 of 4 Old 12-31-2013, 11:21 PM Thread Starter
1222
RIP John
1222's Avatar
Pics courtesy of number40Fan.
2013 Filter
2014
1222 is offline
post #3 of 4 Old 01-15-2014, 10:14 AM Thread Starter
1222
RIP John
1222's Avatar
Update:
Here is a bit more info concerning the 2012 and up JK oil filters. The first two quotes below were taken from a thread in in the JK tech section and Im just assuming the info quoted is correct. The last quote is from the Allpar site explaining why the differences between the 2013 and 2014 oil filters and why they are not interchangeable. Thanks goes to Godholio for the link.
The purpose of this sticky is just to make you aware that there is a difference between oil filters with the Pentastar (3.6) engines and to help avoid problems when purchasing one.
If in doubt about what oil filter is the right one for your year of Jeep then I advise you to double check with any Jeep dealer parts department to remove any confusion.
Originally Posted by zpayne08 View Post
Anyone came across part number 68079744AC?
Originally Posted by Jiblet View Post
That's the latest version for the 2013 filter.
Originally Posted by Allpar
As we noted some time ago, the 2014 V6 engines have a redesigned oil filter cap and O-ring, which is not interchangeable with the 2013-model-year engines. The part number for 2013 and earlier filter-and-O-ring kits for V6 engines is 68079744AB; for the 2014 model year, 68191349AA. The kits are not interchangeable the 2013 kit cannot be used on the 2014 V6, and the 2014 kit cannot be used on the 2013 V6.
(2011-2016)
1222 is offline
post #4 of 4 Old 11-20-2015, 09:53 AM Thread Starter
1222
RIP John
1222's Avatar
Great info here. Thanks goes to Neo1130 for posting this video in another thread.
Originally Posted by Neo1130 View Post
Different lengths check video below at 7:20
http://www.youtube.com/watch?v=jjGnEI1HmNY
(2011-2016)
1222 is offline
Closed Thread
