2012 Rubicon Sway Bar Disconnect - JeepForum.com
post #1 of 59 Old 06-03-2012, 10:38 PM Thread Starter
Fluevog
I have a 2012 black rubicon and the dealer said that you can disconnect the sway bar with a push of a button. How do I do this, I heard you have to be in a certain gear and going so fast but I don't know. Also do I physically grab the sway bar with my hands to remove it or what? Thanks in advance
/l , [____],
l------L--[]lllllll[]-_ ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
()_) ()_)==♠=)_)
Fluevog is offline
post #2 of 59 Old 06-03-2012, 10:40 PM
Moto4x4
you probably shouldnt be moving at all and in park. I dont know how JK's auto disco works but i wouldnt be moving while doing it, and no i dont believe you even have to get out of the jeep so you wouldnt even touch the swaybar
Moto4x4 is offline
post #3 of 59 Old 06-03-2012, 10:47 PM
MKWrangler
You need to be in 4wd to engage the disconnect. You push the button that says "sway bar", no reason to get out of the vehicle. I recommend reading over your owners manual, its very informational, I do this on every vehicle I get.
MKWrangler is offline
post #4 of 59 Old 06-03-2012, 10:49 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
just put it in 4WD Low and hit the button. doesn't matter if you're moving or not.
My builds:
and
or follow us on
spyder6 is offline
post #5 of 59 Old 06-03-2012, 10:50 PM
jeepinjeffrey
^ there you go its pretty simple but rear the section in that manual I think you have to be going a certain speed or slower for it to release.
2003 Wrangler Sport
4.5 Rubicon Express Lift|33" BFG KM2s|Ion Alloy 174|And never ending wish list!
jeepinjeffrey is offline
post #6 of 59 Old 06-04-2012, 01:21 AM
ronjenx
ronjenx's Avatar
It will disconnect in 4hi, too.
ronjenx is online now
post #7 of 59 Old 06-04-2012, 03:08 AM
1222
RIP John
1222's Avatar
It will also reconnect if you exceed a certain speed (18 mph) and disconnect automatically once you slow down within the operating range once again.
1222 is offline
post #8 of 59 Old 06-04-2012, 11:41 AM
smcutter
Wow, that is some of the worst feedback I can recall seeing on this forum.
The swaybar disconnects with the push of a button in 4HI or 4LO. It will automatically reconnect if you exceed 18mph (or shift into 2WD), and it will automatically disconnect again when you drop below 18mph. If you press the swaybar button while on the freeway (or the locker button for that matter) the relevant dash lights will just flash at you in mockery.
For the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline
post #9 of 59 Old 06-04-2012, 11:52 AM
durable1
The full, entire and correct story is stated above!
durable1 is offline
post #10 of 59 Old 06-04-2012, 12:10 PM Thread Starter
Fluevog
Sounds good I'll be heading off road this weekend and I'll try it out
/l , [____],
()_) ()_)==♠=)_)
Fluevog is offline
post #11 of 59 Old 06-04-2012, 12:29 PM
smcutter
Since this appears to be your maiden voyage, make sure you have some more experienced offroaders with you. They'll be able to let you know if/when you need to disconnect the swaybar, use the lockers, etc. And having an experienced driver acting as your spotter will help you start off with better habits.
smcutter is offline
post #12 of 59 Old 06-04-2012, 10:02 PM Thread Starter
Fluevog
Yea I will definitely go with some experienced jeepers, but when you say lockers, what does that mean/what are those?
/l , [____],
()_) ()_)==♠=)_)
Fluevog is offline
post #13 of 59 Old 06-04-2012, 10:06 PM
kade
and before you go how about reading your owner manual!!!!!!
so you don't have to ask a question like you just did
MY BUILD 2012 JKU
http://www.jeepforum.com/forum/f96/kade-2012-jku-build-1305112/
kade is offline
post #14 of 59 Old 06-04-2012, 10:15 PM
Charles
2017 WK
What is a sway bar?
Charles is offline
post #15 of 59 Old 06-04-2012, 10:16 PM
smcutter
Oh boy. Watch all of the videos on your DVD manual... please. And what the hell kind of salesman sold you a Rubicon without telling you why it costs $8k more??
The key benefits of the Rubicon over the other trim levels are:
- Electronic swaybar disconnect
- Electronic front and rear lockers
- Super-low gearing in the transfer case (in 4LO)
Before you head out on the trail, do the research to familiarize yourself with what each of those things means.
smcutter is offline
sway bar disconnect G-MANtj TJ Wrangler Technical Forum 17 09-22-2009 04:20 PM
Rubicon axel lock/sway bar disconnect switch pod lonewolf50 JK Wrangler Technical Forum 2 08-04-2009 04:33 PM
Rubicon sway bar disconnect jknutter TJ Wrangler Technical Forum 8 08-24-2008 02:54 AM
sway bar disconnect 2442george JK Wrangler Technical Forum 12 03-16-2008 07:58 PM
Rubicon Electronic Sway Bar Disconnect JK_Jeep JK Wrangler Technical Forum 6 05-26-2007 09:50 AM
