2012 rubi check engine light - JeepForum.com
post #1 of 62 Old 12-09-2011, 07:00 AM Thread Starter
smooth9883
Hi guys,
My check engine light just came on in my 2012 rubi after about 1900 miles. I got the codes p2097 and p2099. I guys it is saying im running rich? Should I take it in or just disconnect the battery and let everything reset? Is there a reason why I would be running rich?
Thanks for the help
Update:
I just got the jeep back from the dealer yesterday. They said they don't know why the codes are firing. They had me take the jeep home and they sent in a case to chryslers star team I guess. They said they would have me bring it back in once they figure out what's wrong and how to repair it.
So while I drive this thing as its running rich do I have them inspect my cat for any damage after? What other types of damage could I be causing? Do I have the right to have them give me a rental until they figure it out? I'm worried about causing even more damage.
Thanks
smooth9883 is offline
post #2 of 62 Old 12-09-2011, 07:10 AM
1222
RIP John
1222's Avatar
If it is in fact running rich watch out because that will destroy your catalytic converter overtime.
1222 is offline
post #3 of 62 Old 12-09-2011, 07:58 AM
kik
I would take it in. It's too new.
kik is offline
post #4 of 62 Old 12-09-2011, 08:00 AM
durable1
Yeah!
durable1 is offline
post #5 of 62 Old 12-09-2011, 08:06 AM
Noxian
2011 JK Wrangler
take it in, there is a reason stuff comes with warranties
Noxian is offline
post #6 of 62 Old 12-09-2011, 08:06 AM
Muddy4DSM
That was my first thought. Think it might have something to do with the thin air in Denver?
OO|||||||OO
Muddy4DSM is offline
post #7 of 62 Old 12-09-2011, 02:50 PM Thread Starter
smooth9883
I'm sitting at the dealer now. The only thing I can think is that there is either something wrong with the MAF sensor or O2 sensor. If not that something is going on with the computer. The air fuel ratio should be determined by both those sensors I believe so I'm not sure what's going on.
I guess I'd rather have it running rich than lean. I had problems with my C5 and it went into a secondary fuel table after I had knock. Really bad performance and bad gass mileage. I would assume the jeep has knock sensors.
Oh well, I guess I'll find out in a bit.
post #8 of 62 Old 12-10-2011, 09:39 AM Thread Starter
smooth9883
Here we go again!
Yesterday the dealer told me that the O2 sensor was reading to much carbon during the break in period. They said they reset the computer and all should be fine.
So on the way home last night of course the check engine light comes on with the same codes. I will have to take it in again and waste more of my time
Here's a few questions. Usually there is two much carbon created when the system is running rich. Does anyone know why the system would be running rich? Also, if there is carbon build up on the o2 sensor should they replace the sensor? In an airplane if you get to much carbon build up on a mag you lean the crap out of the engine and rev her up to get burn the carbon off. I'm not sure what is going on. What I really hate is how dealers solve only the visible problem. In this case the check engine light. What they should be solving is what is causing the problem. In this case why am I running rich.
I'll keep you updates.
post #9 of 62 Old 12-10-2011, 11:12 AM
222Doc
222Doc's Avatar
kind of old school, but I would pull plugs and look at them. If its to rich I would be worried about the cats. Hows your MPG? Rich it should be lower. Might be a long shot here too... you idle alot or perhaps driving it to easy? I might be getting altimers here but i can not recall if these are DI(direct injection)? Other DI motors have a carbon issue too, its a documeted issue with about all of them, not so much 4 bangers but the V motors. Most of these they claim is because people drive to easy on them. Gm's respons I did not like was , " drive it like you stole it " really? have you gave it some Wot runs to blow it out?
In town I find that the autos tend to keep the rpms very low, here the speeds are 25-45 and the Jeep will if allowed to stays in 4th and even OD, rpms 1200+-. I find that I like the feel of 3rd at 25mph 4th at 45mph, it gets the same mpg. but keeps the rpm about 2k.
222Doc is offline
post #10 of 62 Old 12-10-2011, 05:18 PM Thread Starter
smooth9883
I would actually say I've been driving it a little to hard, but I do sit in traffic with it. Very curious problem and annoying. The MPG is horrible about 14.
post #11 of 62 Old 12-10-2011, 05:43 PM
222Doc
222Doc's Avatar
14 is perhaps a little low but I have seen mine in that range if alot of stop and go, though around here its rare. intown i get 16.5-17, i could get better if i was more of a hypermiler.
222Doc is offline
post #12 of 62 Old 12-10-2011, 06:07 PM
guarnibl
2009 JK Wrangler
If it's a lot of stop and go 14 is pretty normal, especially if you're in a lot of hills around the Denver area. When I was up there I was at around 8, lol.
2009 Jeep Wrangler Rubicon (6mt) (in progress)
- 42x14.50 MTR's, Custom Cage, FF D60's F/R w/ ARB's and 5.38's, 4 Link Rear, 3 Link Front, 14" RR King 2.5's, 18" RR Fox 2.5's, Fox Air Bumps
- 108" wheel base
guarnibl is offline
post #13 of 62 Old 12-13-2011, 07:14 PM Thread Starter
smooth9883
Updated
post #14 of 62 Old 12-14-2011, 09:12 AM
Millermagic
Ahh, Chrysler quality strikes again.
Have you looked at the plugs? Do they have soot on them from running too rich?
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #15 of 62 Old 12-15-2011, 03:02 PM
pentastarguy
2015 JK Wrangler
and a bump so we can follow the op results.
pentastarguy is offline
2012 Rubi with check engine light Scott123 JK Wrangler Technical Forum 19 01-06-2015 05:10 PM
2012 rubi versus 2012 mw3 ? TYPHOON4X4 JK Wrangler Technical Forum 17 11-25-2011 09:14 PM
Check Engine Light/Check Gauges Light eastwood1972 TJ Wrangler Technical Forum 3 11-16-2010 05:06 PM
O2 sensor 03" Rubi fixed passed e-check light came back on RDMcCoy TJ Wrangler Technical Forum 2 03-03-2009 07:21 AM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 08:02 AM
