2012 Road Trip MPG (Very Low) - Page 2 - JeepForum.com
post #16 of 48 Old 12-24-2012, 08:21 AM
222Doc
222Doc's Avatar
if you look at the window sticker and READ it. under those epa numbers(highest mpg) in FINE print just under each of those numbers you will read that in town is 14-17 and 17-25.
222Doc is offline
post #17 of 48 Old 12-24-2012, 08:37 AM
bill9274
2011 JK Wrangler
the auto is geared really low wich is cool. you just need taller tires. im in the same boat i have a sport auto with 3.73's and the little tires 2700 rpms at 70. ill be getting 33's soon.
Bill
bill9274 is offline
post #18 of 48 Old 12-24-2012, 08:43 AM
brianjw
My stock 12 jkru manual with 4.10s made 19mpg at 60-65 no problem in the summer with no water on the roads. After 35s and 3.5" lift it would do 17-18 highway in the summer.
I made one 1000 mile trip early winter, lots of wind, standing water on the road and winter gas, driving 80mph and got 14mpg the whole trip. Not bad if you ask me, for what it is. There are tons of variances and using the trip average mpg isn't accurate anyway. You need to hand calculate over a few tanks to get accurate mileage.
brianjw is offline
post #19 of 48 Old 12-24-2012, 09:04 AM
paul84043
How many miles on it? Have you done an initial oil change yet?
Our 2012 4 dr 6 spd sport has never dialed in anything under 17mpg and averages 18.7 hand calculated mixed driving.
My guess is that you probably got nailed by a few different variables, was it windy? lots of hills? Winter blend gas?
I dont know..the pentastar with 4.10's should do really well...
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #20 of 48 Old 12-24-2012, 09:07 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
Originally Posted by zrultima
Dont drive 70 go 60 mph the 4:10 is what kills you i have a dually which gets 24 mpg hwy but i drive 50-55mph hills do kill the mileage and heavy tires. My dually has 3.54 gears just for reference plus a diesel so a bit higher mpg than a jeep
Lol no. It's a 24 valve petrol engine with VVT. The difference between 3.73 and 4.11 would be nearly undetectable
My builds:
and
or follow us on
spyder6 is offline
post #21 of 48 Old 12-24-2012, 09:07 AM
jstrubberg
2009 JK Wrangler
Seems low. If you are checking the dash gauge, forget it. It's notoriously inaccurate, and it's really bad right at first. Mine is now reliable to within about 6/10ths of an mpg, but that's after 45,000 miles of me driving. It started off well over 1mpg off.
jstrubberg is offline
post #22 of 48 Old 12-24-2012, 10:21 AM
shedendblue
2014 JK Wrangler
Seems that no matter what I do in my 12 Sport (3.73) I get between 16 and 17 mpg. It does go down a bit when I'm trying not to be a rolling road block to the Audis, Mercs, and BMWs on the autobahn - the Jeep just isn't made for 85-95 mph...
That which does not kill me has made a grave tactical error....
shedendblue is offline
post #23 of 48 Old 12-24-2012, 10:36 AM
paul84043
Umm....no. I'm sure youre mileage would drop horribly at those speeds..
I average about 72 on the freeway and can dial in about 21 on a tank.
post #24 of 48 Old 12-25-2012, 12:01 AM Thread Starter
Cosmobull
Follow up to all the questions...
I did have the initial oil change done at 700 miles and switched to synthetic. I now have just under 3000 on the clock.
I have a manual and had it on cruise the whole way except for speed traps. It wasn't windy or hilly.
I did a manual calc of my mileage and ended up with about 14.7 which included some in town driving.
I don't drive like I stole it and I wasn't using defrost or AC.
Lastly I did read the fine print and it didn't say I was going to get less than city mileage on the highway. Once again I'm not crying here, it's a jeep which I've had three others. I'm just a bit disappointed in the printed and hyped mpgs.
Cosmobull is offline
post #25 of 48 Old 12-25-2012, 12:03 AM Thread Starter
Cosmobull
And by the way, thanks for all the responses. Part of the fun of owning one of these hogs is the other people that own them too...
post #26 of 48 Old 12-25-2012, 06:07 AM
Prot
Prot's Avatar
2014 JK Wrangler
That last 5 to 10 mph will cost you fuel economy, but not because of higher rpm's. It's mostly because of increasing wind resistance.
Keep at it 60 or 65 mph at the most and you will get a few mpg better.
Should have never sold the wife on buying the Jeep for fuel economy......You would have better off selling her on improved safety, more room, etc. Many women will react in a very positive way when improved safety is mentioned. It's kind of like the way many men react in a very positive way when more power is mentioned when describing a vehicle.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #27 of 48 Old 12-25-2012, 10:08 AM
doc5339
How do you think a stock 2013 JKUR manual trans 4.10 will do with 33" Pizza Cutter BFG LT255 80 17 "E" range will do with MPG?
They are heavier due to size and construction, but only 1" taller than OEM tires. I know that it will throw the speedo/odo off, but I am hoping not to lose much over stock.
Why e range? C to d is roughly 6 lbs heavier per tire. The increased height and minor width increase along with the heavier load should net you about 10lbs heavier per tire. I doubt you will see much more than a half mpg loss on the setup. I only lost 3mpg going to 37x12.50x17Ds on 4.11s
2013 JKU Rubicon
6-Speed MT
4.10 Rear Diff
BFG All-Terrain T/A KO LT265 70 17 (31.6" high)
doc5339 is offline
post #28 of 48 Old 12-25-2012, 11:23 AM
bluegrassguitar
2011 WK
On the highway, I can average around 19 mpg at 65 mph. Around town, stop 'n go, it will get 14-15. I have a 2007 Sahara unlimited with 4.10 gearing. Stock tires and suspension.
bluegrassguitar is offline
post #29 of 48 Old 12-26-2012, 02:14 AM
doc5339
They are "E" Range because that is the only range the LT255 80 17 BFG KM2 comes in. Why the KM2, because that is the only 33" tire that will fit on a 2013 JKUR OEM rim with no mods whatsoever.
I realize that they are heavier, and that the increased unsprung weight will make for a rougher ride and lower MPG.
Just wondering how much lower the MPG will be? 255 80 17 is a true 33" diameter, but it is the same width as stock tires.
2013 JKU Rubicon
6-Speed MT
4.10 Rear Diff
doc5339 is offline
post #30 of 48 Old 12-26-2012, 07:24 PM
5foot19
2016 JK Wrangler
you didn't say how fast you were going. aerodynamic resistance doesn't scale linearly. If you go 10% faster, the wind resistance increases much more then 10% (as does your fuel usage)
5foot19 is offline
2012 , milage , mpg , trip
