2012 JKU Rubi Check Engine Light - Misfire Cylinder 6 - JeepForum.com
post #1 of 4 Old 02-28-2012, 07:54 PM Thread Starter
dbullion
A check engine light illuminated on my 2012 Rubi JKU (10,800 miles) this past Sunday. The code indicated "misfire cylinder 6". Took it to Maxwell Jeep in Austin Monday morning and got a call Monday afternoon saying it was ready to be picked up. The service rep said they flashed the computer with a program update and that the problem was solved.
I picked it up this morning and drove it for about 20 miles before the check engine light illuminated once again. Took it back to the dealer and received a call this afternoon saying that they were going to have to go into the engine to find the problem and should know something by tomorrow afternoon.
Has anyone else had a similar problem?
dbullion is offline
post #2 of 4 Old 07-28-2012, 12:07 AM
xxxshadow
Yes - on my '07 Unlimited....
What did you find out?
xxxshadow is offline
post #3 of 4 Old 07-28-2012, 12:34 AM
96lasersnake
I know a lot of the 12's are having cylinder head problems causing a misfire code, not sure which cylinder number it is. There is a huge thread on here on it.
96lasersnake is offline
post #4 of 4 Old 07-28-2012, 01:21 AM
73azbronco
here we go again... Can a mod merge this with the pentastar thread?
73azbronco is offline
2012 , check engine light , misfire cyl , misfire cyl 6 , misfire cylinder 6
2012 Rubi with check engine light Scott123 JK Wrangler Technical Forum 19 01-06-2015 06:10 PM
2012 rubi check engine light smooth9883 JK Wrangler Technical Forum 61 04-27-2012 10:35 AM
Went mudding, Now check engine light with Cylinder misfire? chris4jeep TJ Wrangler Technical Forum 7 01-09-2012 01:59 AM
Check engine= cylinder #1 misfire sicandtwisted TJ Wrangler Technical Forum 31 07-05-2011 08:27 PM
cylinder misfire but no check engine light 03bluerubi TJ Wrangler Technical Forum 0 03-16-2008 05:38 PM
