2012 JK dome light upgrade - Page 4 - JeepForum.com
post #46 of 71 Old 02-25-2013, 09:45 AM Thread Starter
robvb525
2014 KL Cherokee
Originally Posted by Digital504 View Post
1 | 4410-x9: 578 LED Bulb - 9 LED Festoon | $ 4.74 |
4410-B9: Blue
2 | 921-x12: 921 LED Bulb - 12 Wide Angle LED Mini Wedge Base| $ 4.95 |
921-B12: Blue
for the 921-B12 bulbs you got, does the light project forward to the front of the cab? it says its a 75 degree beam angle. i spoke with someone from superbrightleds and he recommended i go with the a bulb that was a 360 degree beam angle, but i really dont see the point in that. i have yet to take the dome light so i dont know which way it points..
2014 Cherokee Trailhawk
Past Jeeps: 99 XJ Classic, 02 WJ Overland, 12 JKU Sahara
robvb525 is offline
post #47 of 71 Old 02-25-2013, 11:38 AM
cyberpyrot
Originally Posted by xycarp View Post
ok... this is getting even weirder... I removed the LED bulbs entirely and the map lights under the mirror still stay on. They are on when driving and when stopped and cannot be turned off via switch. When parked they seem to eventually time out and shut off. I will replace the stock bulbs later today to see what happens. I may have to take this to the dealer. Something very strange here... ???
I know this seems like a silly question. you know there are two switches for the dome lites one on the dome light itself and another on the turn signal colum have you tried the switch on the colum?
cyberpyrot is offline
post #48 of 71 Old 02-25-2013, 05:08 PM Thread Starter
robvb525
2014 KL Cherokee
installed the LED's from NorthRidge 4x4 today. a definite increase in usable light output. not blue, cool white as they call it. weird thing is, open any door or unlock and all is normal. but if i tap the light just to turn on a single dome light it blinks like a strobe light. i called NorthRidge they said others have experienced this and it just goes away in a week or so. pretty strange..
robvb525 is offline
post #49 of 71 Old 02-25-2013, 07:10 PM
smcutter
This was my LED Dome Light upgrade solution. I ran an LED strip through a Daystar rocker switch wired directly to the battery (through an inline fuse, of course). You can read my whole write-up here.
For the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline
post #50 of 71 Old 02-25-2013, 07:48 PM
TJeep32
2009 JK Wrangler
http://www.superbrightleds.com/morei...toon/237/1121/
Will that work in an 09?
Sent from my GS2 using JeepForum
TJeep32 is offline
post #51 of 71 Old 02-26-2013, 06:32 PM
Shenck
Shenck's Avatar
Thats what I got in my 2007. Works fine.
------ED-----
2007 Rubicon 6-Speed, 3" Lift with 35's
1993 Cherokee Country, 3" AAL. with soft 8's & 31's
Shenck is offline
post #52 of 71 Old 02-26-2013, 06:44 PM
TJeep32
2009 JK Wrangler
Now if i have a two door, is that the only bulb i need?
TJeep32 is offline
post #53 of 71 Old 02-27-2013, 07:41 AM Thread Starter
robvb525
2014 KL Cherokee
update on the northridge LEDs. after a day the blinking issue stopped, just as they said it would.
robvb525 is offline
post #54 of 71 Old 02-27-2013, 10:04 AM
Shenck
Shenck's Avatar
[QUOTE=TJeep32;15043255]Now if i have a two door, is that the only bulb i need?
Yep.
------ED-----
Shenck is offline
post #55 of 71 Old 02-27-2013, 11:27 AM
TJeep32
2009 JK Wrangler
Cool, thanks man
TJeep32 is offline
post #56 of 71 Old 03-02-2013, 06:21 AM
xycarp
My issue was when I had the three LEDs installed (2 in middle dome, 1 in rear dome on a 4 door), the map light under the rear view mirror stayed on all the time (yes, i know about the buttons on it, plus the ability to turn all the lights on and off).
When driving, the map light would flicker very lightly, or just stay on dimly lit. When turning off the car, removing the key and locking the car... the map lights would stay lit in a dim mode. After several minutes they would turn off.
I found that when i removed the middle dome lights all together, the map lights would go on. STRANGE. When i installed one of the LEDs and one of hte original map lights, all worked normal. With two stock dome lights, all work normal.
I am currently running with one stock white and one LED blue light in the middle dome light. It works fine this way. Not sure what else to do... ?
When others speak of taking a few days to settle in... is it related to what i describe? I dont understand how, but...?
xycarp is offline
post #57 of 71 Old 03-02-2013, 08:18 AM
Filthy-Beast
Did you put a festoon canbus LED in the rear?
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #58 of 71 Old 03-02-2013, 09:52 AM
xycarp
Yep.. I installed these three lights...
1 4410-x9: 578 LED Bulb - 9 LED Festoon 4410-B9: Blue $4.74
2 921-x12: 921 LED Bulb - 12 Wide Angle LED Mini Wedge Base 921-B12: Blue $4.95
Running these three and stock map lights, the maps lights stay on.
Running the festoon, 1 LED and 1 Stock... it works fine.
xycarp is offline
post #59 of 71 Old 03-03-2013, 10:11 AM
Proto732
OK, I ordered some of these but the cargo Festoon bulb won't light.
SuperBrights shows 3 possible cargo area bulbs ...
1 says specifically it is a CAN bus bulb,
  • Part Number: 4410-W1-CB
the other 2 do not.
  • Part Number: 4410-x9
  • Part Number: UPCB-xWHP30-FES
Naturally I went with the one you mentioned: 4410-x9, but it doesn't light when installed.
Slightly confused.
Proto732 is offline
post #60 of 71 Old 03-03-2013, 10:30 AM
Filthy-Beast
This is what I ordered for the rear and that works. I have no problem with the map lights.
http://www.precisionled.com/festoon-...4smd-leds.html
Here's the pair I ordered for the front. (note: these are the red version)
http://www.amazon.com/dp/B004D2XYA4/..._M3T1_ST1_dp_1
For Sale:
