2012 JK Clicking/Creaking Clutch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 2012 JK Clicking/Creaking Clutch
Poison Spyder JK LED Taillight & Wiring Harness KitsPoison Spyder JK Crusher CornersPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 07-09-2015, 08:06 AM   #1
bdubnit
I've got a 2012 JK with 36k miles one it. I started developing a clicking noise in the clutch pedal when I depress it. that quickly turned into a creaking/squealing sound in just a couple days. It only happens after i've driven it for a few miles and everything has warmed up. Otherwise when I first start it in the morning and depress the clutch pedal its all smooth.
I've done some searching and some people say its the TOB and some people say its the slave cylinder. I'm leaning more towards the slave cylinder.
Either way I took it to the stealership and they found a TSB on it which advised them to lube the springs... (guessing the one thats in the slave cylinder?) well needless to say two days later its making the noises again.
I'm taking it back in tomorrow as i've got the max care extended warranty. I'm just trying to see if anyone has had this same issue and can comment any further.
bdubnit is offline   Reply With Quote Quick reply to this message
Unread 07-10-2015, 07:59 PM   #2
number40Fan
2014 JK Wrangler
Yep. There is a return spring on the clutch pedal that the TSB advises them to lube. If the noise went away after they lubed it and then returned, then that is the noise you are hearing.
number40Fan is offline   Reply With Quote Quick reply to this message
Unread 07-13-2015, 11:22 AM   #3
JeepCares
FCA Customer Care
JeepCares's Avatar
Hey bdubnit,
I've provided the service bulletin below for your review. Are you still having this concern? If you took it back to the dealer, what was the diagnosis?
TSB: 06-001-13
SUBJECT: Squeak When Depressing The Clutch
OVERVIEW: This bulletin involves lubricating the clutch pedal return spring stop.
MODELS:
2011 - 2013 JK Wrangler
NOTE: This bulletin applies to vehicles built on or before May 31, 2013 (MDH 0531XX) equipped with a manual transmission (Sales Code DEH).
SYMPTOM/CONDITION:
Squeak from under the dash when depressing or letting go of the clutch pedal.
DIAGNOSIS:
If the customer describes the symptom, perform the Repair Procedure.
Ryan
Jeep Social Care Specialist
JeepCares is online now   Reply With Quote Quick reply to this message
Unread 07-14-2015, 02:03 PM   #4
bdubnit
Originally Posted by JeepCares View Post
Hey bdubnit,
TSB: 06-001-13
MODELS:
SYMPTOM/CONDITION:
DIAGNOSIS:
Thanks for the Reply.
I took it back to them and they said their transmission tech had 5 vehicles in already. we decided it would be best for me to bring it in this week, that way it would be nice and warm (making the noise) when I got there and they would be able to get it right in. Taking it in tomorrow. will update further after I hear back from them.
Unread 07-15-2015, 11:54 AM   #5
JeepCares
FCA Customer Care
JeepCares's Avatar
Thanks for the update. Please keep us updated on the diagnosis!
Ryan
Unread 07-16-2015, 12:02 PM   #6
bdubnit
Just got the call back from the dealership and they can't reproduce the problem. They say they've driven it for a good 20 miles and still no noise. It was making the clicking sound when I dropped it off but i'm sure it sat for a while before they got to it.
Either way I found this thread: http://www.jk-forum.com/forums/stock...linder-278107/
Seems like its more of an annoyance than anything (which i'm fine with) but I was erring on the side of caution that it could be a bigger problem. If it gets to be too bad, then i'm just going to fix it myself I guess.
Unread 07-17-2015, 07:28 AM   #7
JeepCares
FCA Customer Care
JeepCares's Avatar
bdubnit,
I appreciate you updating with the dealer diagnosis. If the concern worsens, let your Service Manager know. I would recommend taking a dealer representative on a test drive so you can duplicate the concern for them.
Feel free to PM me any additional questions or concerns!
Ryan
