2012 jeep wrangler... Lift kit? Shocks? - Page 3 - JeepForum.com
post #31 of 45 Old 07-17-2012, 04:31 PM Thread Starter
Filthy4x4
2014 JK Wrangler
Originally Posted by jezzalachis View Post
Just FYI, the 2012+ has a different engine and transmission and does require different gears than a comparible 2007-2011 3.8L model. Previously DAK09 was quoting "performance" gearsets for a 2007-2011 JK with 35" tires. Consult the 2012+ (3.6L) charts for your regear, it is confusing at first, but best not to get mixed up between the 3.6L and 3.8L when choosing to regear your JK.
So do I need to re-gear or will I be ok??
Filthy4x4 is offline
post #32 of 45 Old 07-18-2012, 03:40 AM Thread Starter
Filthy4x4
2014 JK Wrangler
OK now to decide for 17" or 18"?? pro and cons please, other than $$$ ??
post #33 of 45 Old 07-18-2012, 07:43 AM
Blstr88
I just installed the RK 2.5" kit with Bilstein 5100s...I've only got about 75 miles on it so far, but Im very happy with the quality of the kit and the ride!
2013 Commando JKUR - bone stock
Blstr88 is offline
post #34 of 45 Old 07-18-2012, 07:46 AM
Blstr88
Probably just personal preference between 17 or 18s...
I personally prefer less wheel and more rubber...thats typically better for offroad and it gives it more an "offroad Jeep" look...however 17-18 really wont make a huge difference. The 18s will cost you more obviously and the tires for the 18 will probably be a few bucks more...as far as tire availability anything you want would probably be available in either, so thats a non-factor.
Personal preference really!
Blstr88 is offline
post #35 of 45 Old 07-18-2012, 10:54 AM
LVCapo
2015 JK Wrangler
Seriously, look into some 15"s. you can get tires and wheels for about the same price as 17" tires alone....and down the road you'll save a ton of money when it comes time for new tires.
LVCapo is offline
post #36 of 45 Old 07-18-2012, 04:47 PM Thread Starter
Filthy4x4
2014 JK Wrangler
so the only difference with 17" and 18" is the price? no difference in ride? height? or gas milage??
post #37 of 45 Old 07-18-2012, 05:14 PM
Caribic-TJ
yes. and 3x no.
08 JKU Rubicon
98 TJ fully locked
Caribic-TJ is offline
post #38 of 45 Old 07-19-2012, 09:30 PM
aftahour
2011 JK Wrangler
Tires i notice offroading minimum is 30 or 32. The bigger the rim and tire the less mpg. I just run the stock 17 w/ 305. 65. 17 procomp. Rims make the jeep look nice unless u get bead locks.
aftahour is offline
post #39 of 45 Old 07-20-2012, 11:45 PM Thread Starter
Filthy4x4
2014 JK Wrangler
Bead locks can you please post an example??
post #40 of 45 Old 07-21-2012, 12:07 AM
Spagary
bead locks are trail specific wheels that people buy so that they dont blow out on the trail and bead off the wheel (correct me if im wrong guys)
Spagary is offline
post #41 of 45 Old 07-21-2012, 12:39 AM
aftahour
2011 JK Wrangler
http://en.wikipedia.org/wiki/Beadlock
aftahour is offline
post #42 of 45 Old 07-21-2012, 09:29 AM
countrybassist
2011 JK Wrangler
I would check out OME
countrybassist is offline
post #43 of 45 Old 07-22-2012, 08:47 PM
aftahour
2011 JK Wrangler
Heres more info on gearing from a mag I had
aftahour is offline
post #44 of 45 Old 07-22-2012, 10:36 PM
LVCapo
2015 JK Wrangler
If you search for "Gear Ratios" the various charts for Auto/Manual 2007-2011 and 2012 have been posted. Umerous times on this forum.
LVCapo is offline
post #45 of 45 Old 07-23-2012, 06:21 AM
paul84043
You really shouldn't "Need" to regear with the '12 unless you are planning on doing some pretty serious rock crawling and you want the lower gearing like a Rubicon. For anything else, the '12 has plenty of power.
It's completely personal preference though.... Don't worry about it yet, it's not going to be an issue.
Beadlockers are very specific purpose built rims and may be illegal in your area, check your laws before going with them. I know in Utah, there is only one style of beadlocker that's legal on a regular street vehicle.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
aev , lift advice , rock crawling , shocks , suspension lift
What's the best shocks for a 1999 Jeep Wrangler Sport with a 2.5 inch lift? pgatour11 TJ Wrangler Technical Forum 8 02-16-2012 06:00 PM
2012 jeep wrangler unlimited 2inch teraflex lift ideas? garettt520 JK Wrangler Technical Forum 0 09-28-2011 09:58 AM
Lift for 2012 Wrangler RCS JK Wrangler Technical Forum 19 09-01-2011 09:13 AM
Got a 2012 Jeep JK? Want a free Rancho suspension and shocks? Rancho_Lifts JK Wrangler Technical Forum 6 08-17-2011 08:37 AM
Skyjacker 4" Economy Lift Kit with Hydro Shocks for 97-02 Jeep® Wrangler TJ as00519 Wrangler General Discussion 2 05-21-2011 08:46 AM
