2012 jeep wrangler... Lift kit? Shocks? - JeepForum.com
post #1 of 45 Old 07-10-2012, 10:05 PM Thread Starter
Filthy4x4
2014 JK Wrangler
Hey guys....
Its about time for me to pull the trigger on a lift kit/shocks. However I feel that every shop I talk to is giving me their own (BIAS$$$) opinion on which lift is the best one.
So you guys helped me with my tires/wheels (nitto trail grapplers) by the way 35x12.50x17.
So now I'm in need of your lift/shock suggestions!!
Here is what I am looking for: A 2.5"-3" lift that will not jeopardize ride quality or handling... I will be driving this rig on LA streets 90% of the time but will also like to be able to take it up to big bear/MOAB once in a while and let her tear up the trails with out a problem.
This is what I got so far:
Shocks:
1. Bilstein 5100
2. Bilstein 5160 (overkill) but look sweet
3. Fox IFP
Lifts:
1. Teraflex 3" kit with 4 arm suspension
2. AEV 2.5" lift
3. ROCK CRAWLER 2.5" lift
4. BDS 3" Coil Lift
5. (insert your favorite)
Since this is a somewhat $$$$ big purchase I could really use some/any advice!!
The car is a 2012 Wrangler Sahara 4 door with 3.73 gears
Filthy4x4 is offline
post #2 of 45 Old 07-10-2012, 10:39 PM
aftahour
2011 JK Wrangler
I have the blistens 5100 and teraflex 3" lift on 32 and love it. My rig 2011 jku. 90% is dd like yours. Love it and no problems so far.
aftahour is offline
post #3 of 45 Old 07-10-2012, 10:44 PM Thread Starter
Filthy4x4
2014 JK Wrangler
thanks!
post #4 of 45 Old 07-11-2012, 04:03 AM
agenbroad99
Check my signature... TF 3" with Bilsteins... A good combo on and off road. Only think I dont like is the TF "quick" discos... A real PITA!!
2008 JKUS Banks Monster, 4.88 G2 Gears, PureJeep Rocker Guards, AEV Savegre w/315/70/17 Duratracs, Body Armor Rear w/Tire carrier, Teraflex 3" with Bilsteins, Rough Country Bumper with Engo 10K install, Evo sleeves and gussets, oh yeah and Flat Fenders.
http://www.youtube.com/watch?v=whKFbphWpvY&feature=player_embedded
agenbroad99 is offline
post #5 of 45 Old 07-11-2012, 04:54 AM
DaK09
Teraflex 3 in is a good lift and is popular on this coast.
I went with the Rock Krawler 3.5 X factor. IMO get a little more flex with it and you get a little more lift with the RK's as according to them, "you are going to put extra stuff on the jeep like skids, rock rails and such so when you are done you still have your 3.5"s of lift. True or not I don't know but there ya have it.
Either lift has great street manners.
Shocks-have the bilstein 5100's with no complaints.
Tires- toyo's. Nice but freakin heavy
Gears- with 35's you will want to step up to 4.88's with a manual and at least 5.13 and highly recommend 5.35's for the auto.
DaK09 is offline
post #6 of 45 Old 07-11-2012, 07:38 AM
Caribic-TJ
5.35 gears would be overkill, who is highly recommending this for the 2012 models if you want to run 35" tires?
08 JKU Rubicon
98 TJ fullu locked
Caribic-TJ is offline
post #7 of 45 Old 07-11-2012, 08:37 AM
jeeptrix
2009 JK Wrangler
Question,
Do you have to have the dealer install the lift if you are to maintain your warranty or all of it, or how does that work? Can you do any brand of lift? Height? etc?
2009 Wrangler Sport JKU: 35" Mickey Thompson MTZ/17" Pro Comp Xtreme Wheels/ 3" BDS Lift/4:88 gears/ARB Lockers/ARB Air Compressor/Rugged Ridge Front Bumper/ Rugged Ridge 8500lb Winch/Cold Air Intake/Borla Dual Exhaust/Tuffy Underseat Security and Trunk Enclosure/etc. etc. etc.
jeeptrix is offline
post #8 of 45 Old 07-11-2012, 08:46 AM
ncb
Jeep can't void the entire warranty due to a lift. They can deny a warranty claim if it can be proved that the lift caused a part to fail. For example if a drive shaft failed due to the lift causing a bad pinion angle. Some dealers are more mod friendly than others.
ncb is offline
post #9 of 45 Old 07-11-2012, 05:38 PM
KenMarti
I got 4" ProComp lift, excellent ride and handling, running 35" Toyo MT's on 20" XD's, 4.56 G2 gears are perfect with the 35's, 90% street driven, trails and beach on the weekends. Pulling 2400 rpm's at 70 mph with 18mpg
KenMarti is offline
post #10 of 45 Old 07-11-2012, 05:43 PM
SubAtomicGenius
2011 JK Wrangler
I'm running the 3" Teraflex full-flexarm (8) lift kit. Really great lift, make sure you get the front adjustable trackbar for 3" and over.
Teraflex quick discos cannot re-engage without ratchet straps or finding a rock to crawl a wheel onto to line the damn things up!!! Love my ratchet straps, make lining up quick discos a cinch.
SubAtomicGenius is offline
post #11 of 45 Old 07-11-2012, 05:44 PM
SubAtomicGenius
2011 JK Wrangler
OP has a 2012, you're quoting pre-2012 3.8L gearsets which do not apply!!!
post #12 of 45 Old 07-11-2012, 05:58 PM Thread Starter
Filthy4x4
2014 JK Wrangler
OK, So I've narrowed it down to the TF 3" lift..... now not sure which one to get can you point me in the right direction? and don't wanna have the sway disco problem like the above user
Thanks!
post #13 of 45 Old 07-15-2012, 03:54 PM Thread Starter
Filthy4x4
2014 JK Wrangler
Bump
post #14 of 45 Old 07-15-2012, 03:57 PM
Spank
2014 JK Wrangler
You can't go wrong with AEV or Teraflex. I'm running the AEV 3.5" lift and it rides better than stock.
'14 Wrangler Unlimited Rubicon
Spank is offline
post #15 of 45 Old 07-15-2012, 05:05 PM
TheBoss
I agree, I've run Teraflex and am currently on a 2.5 AEV kit. Nothing but good things from these manufactures. RK ,Synergy,Currie,Claytons,JKS all are great choices as well. As hard as the decision may be ask yourself what your immediate goals and base the suspension around it.
TheBoss is offline
aev , lift advice , rock crawling , shocks , suspension lift
What's the best shocks for a 1999 Jeep Wrangler Sport with a 2.5 inch lift? pgatour11 TJ Wrangler Technical Forum 8 02-16-2012 06:00 PM
2012 jeep wrangler unlimited 2inch teraflex lift ideas? garettt520 JK Wrangler Technical Forum 0 09-28-2011 09:58 AM
Lift for 2012 Wrangler RCS JK Wrangler Technical Forum 19 09-01-2011 09:13 AM
Got a 2012 Jeep JK? Want a free Rancho suspension and shocks? Rancho_Lifts JK Wrangler Technical Forum 6 08-17-2011 08:37 AM
Skyjacker 4" Economy Lift Kit with Hydro Shocks for 97-02 Jeep® Wrangler TJ as00519 Wrangler General Discussion 2 05-21-2011 08:46 AM
