2012 Jeep Unlimited HEAT - JeepForum.com
post #1 of 57 Old 10-13-2012, 10:47 AM Thread Starter
OBXJEEPN
Hey fellow Jeepers.
Bought a 2012 Jeep Wrangler unlimted in June, Me and wife have been happy with it so far until last week. Had a cold spell come thru. Wife went to use heat, but no hot air on drivers side just cold air, passenger side vents are blowing 50 degrees hotter air. Took to Hall Jeep in VA Beach, they said they have never seen this before. Service guy found dark colored antifreeze and was advised by Techs at Chysler/Jeep HQ to change oil cooler than flush system. If that does not work to replace Heater core. I'm not to concerned about the Money cause this is all covered under warranty. Have any of you heard this before or seen it. OIIIIIO
OBXJEEPN is offline
post #2 of 57 Old 10-13-2012, 11:04 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Just common sense tells me that if the JK is blowing hot air on one side and not the other, the heater core is fine and the vent delivery system is not working....just saying, you know...
Look this up under Hakam's Razor.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 57 Old 10-13-2012, 11:28 AM Thread Starter
OBXJEEPN
Thats what I said to the Service manger. But I guess it appears they found another issue with the antifreeze (only 9000 miles).
OBXJEEPN is offline
post #4 of 57 Old 10-25-2012, 02:01 PM
cquinnz12
dont feel so bad, my new JK 2012 only has 1400 miles on it and it is already in the shop getting a new transmission. I hadn't even made a payment on it.
cquinnz12 is offline
post #5 of 57 Old 10-25-2012, 02:19 PM
1222
RIP John
1222's Avatar
^^^Sorry to hear about your problems and hope it gets resolved soon. What Trans do you have, stick or auto? Also please fill in your profile when you get a chance, thanks.
EDIT: to the forum.
(2011-2016)
1222 is offline
post #6 of 57 Old 10-25-2012, 02:23 PM
1222
RIP John
1222's Avatar
So OBXJEEPN, did you ever get the heating problem fixed and what did it turn out to be?
(2011-2016)
1222 is offline
post #7 of 57 Old 10-27-2012, 02:57 PM
nickmonaco
Originally Posted by OBXJEEPN
Hey fellow Jeepers.
My 2012 just started doing this exact same thing a month ago.
WHITE JEEP CLUB #171
My other Jeep's not a Chrysler.
nickmonaco is offline
post #8 of 57 Old 10-27-2012, 06:31 PM Thread Starter
OBXJEEPN
Update, Picked up Jeep last Saturday. They changed oil cooler first and then flushed Antifreeze 3 times, improved heat by 15 degrees, than they ordered a new heater core and replaced, I guess the inside of the heater core was coated with oil. It blows nice warm air now. Only a week and a half for them to figure out. @ nickmonaco check to see ifyour antifreeze has discolored oil in it, if it does than it's proably same symton as mine. Happy JEEP N.
OBXJEEPN is offline
post #9 of 57 Old 10-28-2012, 04:36 PM
nickmonaco
Thank you ill get on that.
post #10 of 57 Old 10-28-2012, 07:09 PM
mjmnrem
EXACT same problem with mine! Splashing thru some flood water in Va Beach today during hurricane Sandy, I went to straight floor heat. Passenger side smoking hot, I could feel the heat drifting over to my side! I put my hand down and it was quite cool on my side. I will probably print this thread and take it to the dealer!
mjmnrem is offline
post #11 of 57 Old 10-29-2012, 04:08 AM
5foot19
2016 JK Wrangler
Not to sound negative, but you may still have an issue. My 2011 blows ridiculously hot air (I wish I had a temperature reading to put it into perspective, but I swear it is hotter then any other vehicle I've been in in my life). If yours blows something you'd describe as "warm" it is far from working properly.
5foot19 is offline
post #12 of 57 Old 10-29-2012, 04:44 AM
Panhead5
2009 JK Wrangler
I thought I kinda missed the point here but realized the causal part appears to be oil cooler failure .
Panhead5 is offline
post #13 of 57 Old 10-29-2012, 06:28 AM
plac
like oil cooler (is it part of the radiator?) cracking, then contaminating the antifreeze? common prob on the xterras too..
2015 Subaru WRX
plac is offline
post #14 of 57 Old 10-29-2012, 06:31 AM
paul84043
Sounds to me like two separate problems unless for whatever reason, the wrangler has two heater cores.
The core might have been contaminated with oil (which doesn't make any sense to me), but the difference in temp from side to side is a malfunctioning diffuser system.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #15 of 57 Old 10-29-2012, 11:29 AM
WXman
Had my heater core replaced at 6,000 miles (first sign of cold weather). Casting sand from manufacturing is clogging them up. I finally get hot air out of all the vents now, not just the right side. It's a common problem.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
