2011 Wrangler Unlimited Tire Question - JeepForum.com
post #1 of 6 Old 02-27-2011, 06:04 PM Thread Starter
BradWatson
What is the biggest size tire that I can put on a 2011 Jeep Wrangler Unlimited without a lift kit? The tires will be going on Gear Alloy Black Jack wheels size 18X9. My current tires are P255-70-18. Thanks for the help.
BradWatson is offline
post #2 of 6 Old 02-27-2011, 06:11 PM
BRICKTOP2
Unhingd PigFeedng Gangstr
BRICKTOP2's Avatar
http://www.jeepforum.com/forum/f96/j...reads-1074059/
Check out the above link
"Tightening the nut behind the wheel is the most cost effective way to improve the performance of any vehicle."
JK Build Thread
TJ Tub Trailer
BRICKTOP2 is offline
post #3 of 6 Old 02-27-2011, 06:16 PM
MoparToYou
2014 JK Wrangler
Depends on what you are willing to do to be able to run a certain size of tire. 33s fit stock, depending on the backspacing of those Black Jack wheels. With flat fenders you can even run 35s, once again, depending on the backspacing of your wheels.
2014 Grand Cherokee Laredo: 2" Eibach lift, 265/70R-17 BFG KO2's, 17x9 KMC Addicts
MoparToYou is offline
post #4 of 6 Old 02-27-2011, 08:13 PM Thread Starter
BradWatson
The blackjack wheels say they have 10 offset. Not sure exactly what that means. Thanks for the replies.
post #5 of 6 Old 02-27-2011, 08:45 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Go to this site and see what backspacing is vs offset. Offset is from the centerline of the rim to the mounting face of the wheel and backspacing is from the inside rim to the mounting face of the wheel...two different measurements.
http://www.rimsntires.com/specs.jsp
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #6 of 6 Old 03-01-2011, 08:44 AM
brado32
2011 JK Wrangler
Those are cool rims. I just bought a new 2011 wrangler sahara. I assume I can get those rims and use the new stock tires on them?
brado32 is offline
Replacing or Removing Headlight in a Wrangler Unlimited Sport 2011 JohnKraut JK Wrangler Technical Forum 15 01-03-2012 07:34 AM
Fog light bulb size in 2011 wrangler unlimited sport? JohnKraut JK Wrangler Technical Forum 18 12-12-2011 11:40 AM
New 2011 Jeep Wrangler Unlimited Sport JohnKraut JK Wrangler Technical Forum 15 05-16-2011 12:53 PM
Tera Flex 2.5" lift on 2011 Wrangler Unlimited Rubicon? kwpollard JK Wrangler Technical Forum 3 02-15-2011 11:07 PM
Should I buy a 2011 Wrangler Unlimited? JillTheThrill JK Wrangler Technical Forum 15 12-07-2010 07:32 AM
