2011 Wrangler Hand Break Concern - Page 2 - JeepForum.com
post #16 of 23 Old 11-19-2012, 03:17 PM
442Wrangler
In like Flynn.
442Wrangler's Avatar
Originally Posted by ronjenx View Post
That little pawl shouldn't be depended upon to hold the Jeep if there is any incline at all.
Have you ever pulled the lever out of park, and the Jeep was resting on the pawl? Did you notice the resistance and the noise it made? That's wearing away the pawl, making it more apt to slip out of park on an incline.
For those with manual transmissions, people have come out to get in their Jeeps and found them down the driveway, or even across the street, because the engine had slowly turned over, allowing the Jeep to move on its own.
I suppose but have never had an issue with my old XJ which had 220000 on it and I parked it on an incline for 7ish years everyday.
Edit: To stay on topic, I have had this issue as well and oiling the spring took care of it!
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #17 of 23 Old 11-19-2012, 03:31 PM
ronjenx
ronjenx's Avatar
I could tell you have never had an issue with it.
ronjenx is offline
post #18 of 23 Old 11-22-2012, 08:38 AM
rolandthegypsy
Hi guys. I think any car, Jeep or truck owner should always use their parking brakes. The reason for this is simple. If you never use the e brake on an automatic, when you will need it it will not work. the cable will jam in the tubing that directs the cable. It jams because the cable rusts and no longer moves freely.
My e brake broke right after the warranty expired, so I purchased the part and installed it myself. It took more time to remove the transfer case knob than the whole job itself, but that's another story.
rolandthegypsy is offline
post #19 of 23 Old 11-22-2012, 09:04 AM
jrallen
Originally Posted by mgarcia28
It definitely stays up..
That sounds a little personal to me.
jrallen is offline
post #20 of 23 Old 07-27-2013, 06:47 AM
wingit
Originally Posted by mickeymeanie View Post
I had the stealership check mine because it just didn't seem to hold on even the slightest incline. The fix was "pull it up harder and further"... it holds when you do that... but dang, doesn't seem like that should have to be the case. They didn't want to adjust it any because it would just be dragging and wear down to the same point it's at now... makes sense sure, but doesn't seem right to have to pull the thing so hard and so far to get it to engage. Oh well... probably doesn't help that I've got 5,000lbs of Nitto Trail Grappler dragging the thing down the driveway... LOL
I so agree. I actually thought something was wrong with mine. Between the loud clunk and the fact I have to pull it into the back seat for it to actually stop. I had the dealer look at it but they said it was within spec. Personally I think they need to rethink their spec.
Living Life! Because before you know it, it is over!!!!!!
wingit is offline
post #21 of 23 Old 07-27-2013, 09:45 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
when you set the hand BRAKE - if the park pawl BREAKS and the vehicle does roll - it does not gain as much speed and causes less damage when it it is stopped by a house, other car etc.
NOT setting the brake on an incline is much akin to not turning the tires to (or away from) the curb - might as well just aim it a target down hill, stand back and watch the show....
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #22 of 23 Old 07-27-2013, 12:11 PM
jcavitt
Set your e-brake when the transmission is in neutral, let your foot off the brake and let the e-brake hold the vehicle, the shift in to Park. This will allow take the stress off the transmission but it'll still be in park if the e-brake fails. I do this on every vehicle I drive. This also keeps the vehicle from being stuck in park if parked on an incline.
2013 JKUR
35x12.5 MTRs, 16x8 ATX Slot Wheels, Rock Krawler Budget Based Long Travel 1.75" System
jcavitt is offline
post #23 of 23 Old 07-28-2013, 09:09 AM
JKPaul
Yup! That's the way I was taught when I first started driving. Easier on the tranny.
O|||||O
"Clowns to the left of me, jokers to the right.......'!
JKPaul is offline
