2011 rubicon 4 day build teraflex lcg - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 2011 rubicon 4 day build teraflex lcg
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 02-07-2011, 10:59 AM   #46
Mol
Disclaimer: I'm Polish
Mol's Avatar
Originally Posted by TeraFlex View Post
OK good, just wanted to make sure on that. No TeraFlex doesn't suggest or make drop pitmans for JK's, so it would of came with one. I'm very curious about the handling issues that you were having. Can you tell me what your caster setting are?
FWIW - after installing my teraflex 2.5 bb (entirely different system, I know), and adjustable LCAs set to 27-7/8", caster was at +3.6*, a little low but good enough. I had similar handeling/dartiness problems that I wanted to blame on caster, but didn't know how, because caster should have been fine. Here is what I just found out, and it very well may apply to your scenario, 11RUBICON...
My camber was at -0.7 left, and -0.8 right. Factory specs state camber should be set between -0.6 and 0.1. Ideally, camber should be 0, if I'm not mistaken.
Perhaps shimming the ball joints after installing the flip kit will help? I'd be willing to bet your camber was jacked up
2008 JKUR
Raceline - Maxxis - Currie - Synergy - Offroad Evolution - Reid Racing - RCV - Pretty ****ty Crap (PSC) - River Raider - Warn - MBRP - KC - AEV - Offroad Heros - BFG - Teraflex - BDS - Fox - Eibach - Moog
2012 JKU
- The smoking hot wife mod -
Mol is offline   Reply With Quote
Unread 02-07-2011, 11:21 AM   #47
11RUBICON
11RUBICON's Avatar
2011 JK Wrangler
Originally Posted by molshove View Post
fwiw - after installing my teraflex 2.5 bb (entirely different system, i know), and adjustable lcas set to 27-7/8", caster was at +3.6*, a little low but good enough. I had similar handeling/dartiness problems that i wanted to blame on caster, but didn't know how, because caster should have been fine. Here is what i just found out, and it very well may apply to your scenario, 11rubicon...
My camber was at -0.7 left, and -0.8 right. Factory specs should be between -0.6 and 0.1. Ideally, camber should be 0, if i'm not mistaken.
i have been an alingment tech at an offroad shop for several years as well as an aligment tech at les schwab for several years.
My camber is true at L 0.0 & R -0.1
caster is at 3.6 L and 3.8 R
toe is at +.04
remember all i did was flip the drag link.
As soon as i flipped it back it drove perfect.
All i can think of is geometry between draglink and track bar
2011 RUBICON UNLIMITED
FOLLOW MY BUILD
http://www.jeepforum.com/forum/f96/2...x-lcg-1142708/
2009 RUBICON UNLIMITED (WIFES)
2" LIFT, AEV GEOMETRY KIT, BILSTIEN SHOCKS, 4.88 GEARS, 17" ARW WHEELS, 35" TOYO M/T, FABTECH WINCH BUMPER, VISION X LIGHTS,
11RUBICON is offline   Reply With Quote
Unread 02-07-2011, 11:26 AM   #48
Mol
Mol's Avatar
toe is at +.04
There's no chance that your measurements changed after flipping? I wouldn't imagine geometry between draglink and track bar would would cause this, so many kits have been installed without issue...if the track bar was loose maybe, but you seem entirely too thorough for that to be a possibility. I'm at a loss.
Edit: Your toe is a little light...not sure that this will make a huge difference, but maybe the flip amplified it?
2008 JKUR
2012 JKU
Unread 02-07-2011, 11:38 AM   #49
TeraFlex
toe is at +.04
Good caster on that. Now I see the problem. You only install a flip drag link and not the full flip draglink/trackbar drop bracket/brace kit. If you had installed the whole #1600440 kit, you would have had different results. Who did you buy your kit from or installed it?
www.teraflex.biz
j.thompson@teraflx.com
TeraFlex is offline   Reply With Quote
Unread 02-07-2011, 03:31 PM   #50
11RUBICON
11RUBICON's Avatar
2011 JK Wrangler
Originally Posted by teraflex View Post
good caster on that. Now i see the problem. You only install a flip drag link and not the full flip draglink/trackbar drop bracket/brace kit. If you had installed the whole #1600440 kit, you would have had different results. Who did you buy your kit from or installed it?
parts used is a factory right hand drive draglink with a tapperd sleeve, same as used with aev and tf kits.
Track bar is the tf monster for the 4" lcg kit.
A brace to the steer box and steering stabalizer is not going to fix the issue that i am experiencing.
I belive the issue is coming from the maybe the track bar angle to draglink. Combined with maybe a too nutral of a draglink angle
FOLLOW MY BUILD
Unread 02-07-2011, 03:41 PM   #51
TeraFlex
Not correct, that draglink is a TeraFlex only part and not a weaker OEM RHD model like what other companies used. In the #1600440 kit is also included a trackbar drop bracket and brace. You need that drop bracket to correct your steering geometry. Also the newest version of the drop bracket has 2 locations now for the trackbar.
Here's what you need to correct it.
http://www.teraflex.biz/frame-brace-trackbar-drop-jk-front.html
www.teraflex.biz
Unread 02-10-2011, 04:51 PM   #52
11RUBICON
11RUBICON's Avatar
2011 JK Wrangler
Ups just droped off some goodies for me today.
Psc diy rico sliders
looks like i would be able to get to it until wendsay. I will post some pics next week
FOLLOW MY BUILD
Unread 02-12-2011, 12:31 PM   #53
11RUBICON
11RUBICON's Avatar
2011 JK Wrangler
I got off work early yesterday, the wife wasnt home so i decided to install the rock sliders last night.
I got that done as well as the rubicon steering stabalizer
FOLLOW MY BUILD
Unread 02-12-2011, 01:17 PM   #54
11RUBICON
11RUBICON's Avatar
2011 JK Wrangler
I have some pics but they are from late last night so they are not that great i will take some here in a little bit and post them up
FOLLOW MY BUILD
Unread 03-23-2011, 01:28 PM   #55
11RUBICON
11RUBICON's Avatar
2011 JK Wrangler
Here is an over due picture of my poison Spyder DIY sliders.
FOLLOW MY BUILD
Unread 03-23-2011, 04:30 PM   #56
xplosivo1
2011 JK Wrangler
They look good, you have a really nice rig, when I get done with mine it will be very similar.
2011 Unlimited Rubicon / Bright White....stock (but it's a very capable stock)
2007 Unlimited Rubicon / Silver / 35 BFG AT 5/13 Gears / Pro Comp 4" lift - SOLD SOLD SOLD
"I can never again see a UNITED STATES MARINE without experiencing a feeling of reverence." -GEN. JOHNSON, US.ARMY
xplosivo1 is offline   Reply With Quote
Unread 03-23-2011, 06:13 PM   #57
11RUBICON
11RUBICON's Avatar
2011 JK Wrangler
Originally Posted by xplosivo1 View Post
they look good, you have a really nice rig, when i get done with mine it will be very similar.
thank you
FOLLOW MY BUILD
Unread 06-10-2011, 10:22 AM   #58
4WheelPrincess
2011 XJ Cherokee
Yes, Brandon what is next for the Big Black ....
4WheelPrincess is offline   Reply With Quote
Unread 06-10-2011, 12:39 PM   #59
jeepl!fe
jeepl!fe's Avatar
such an awesome build!
i love the rock sliders, probably my favorite sliders.
keep it up!
jeepl!fe is offline   Reply With Quote
Unread 06-10-2011, 01:05 PM   #60
11RUBICON
11RUBICON's Avatar
2011 JK Wrangler
I love the rock sliders, probably my favorite sliders.
Keep it up!
thank you
FOLLOW MY BUILD
