2011 Rubicon with 35" tires - JeepForum.com
post #1 of 22 Old 10-09-2012, 08:22 PM Thread Starter
Fiddycals
2011 JK Wrangler
Will the stock axle gearing on a 2011 JKU Rubicon with auto trans handle
35" tires?
Fiddycals is offline
post #2 of 22 Old 10-09-2012, 08:24 PM
Coolcatracing
http://www.jeepforum.com/forum/f96/j...reads-1074059/
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
Coolcatracing is offline
post #3 of 22 Old 10-09-2012, 08:42 PM
JIMBOX
YUP, the 2011 JKUR won't have any trouble with the 4.10 gears/auto/35" tires-
35" tires?
However, you'll be so miserable, you'll hate to driveit-do some homework--as suggested above !
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #4 of 22 Old 10-10-2012, 03:53 AM Thread Starter
Fiddycals
2011 JK Wrangler
I was told that the Rubicons with an auto trans only came with 3.73 gearing, is there any truth to that? JIMBO, I have do alot of reading and there are alot of mixed opinions. I will be using the jeep for light off roading, local driving and occasionally highway use. I am very curious to know why you would think I would be misersble. Out of my uses for the jeep, what driving would make me the most miserable, highway? Thanks for your help!
post #5 of 22 Old 10-10-2012, 04:07 AM
saddis
2014 JK Wrangler
4.10's
Steven
saddis is offline
post #6 of 22 Old 10-10-2012, 04:59 AM
TheBoss
2012-2013 Rubicons come standard with 3.73 gears with 4.10 as an option. However previous models 2007-2011 Rubicons came with 4.10's with the auto.
Depending on your geographical area ie flatland or continuous grade and elevation changes the 35's may be "liveable". If do it ,pick up a programer such as the Procal to adjust the computer for the size difference. Tire weight will also effect the overall "feel" of the Jeep as well.
TheBoss is offline
post #7 of 22 Old 10-10-2012, 06:53 AM
JIMBOX
Yeah, your 2011 NORMALLY came with 4.10 geras and with an auto--BAD news-for 35s
If you really want 35s then you should regear to at least 4.88 gears, since yours is a DD-
Otherwise you'll never enjoy the gas saving O/D--just won't work with your 4.10 gears and 35" tires-
Since it's a DD/w light off-road use--why do you want 35s and are you ready for a lift/or fender flare change, or after mkt wheels, or spacers--it gets complicated when you got to 35s-
Go to 33s--not much else required then-
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #8 of 22 Old 10-10-2012, 07:56 AM Thread Starter
Fiddycals
2011 JK Wrangler
I have installed a Rustys 3.25 lift and have XD wheels with proper backspacing for 35" tires. I just have to decide on the tire size. I really like the look of the Nitto Dune grappler 315x70-17. The 305x70-17 is not much smaller then the 315x70-17 but is like $80 more a tire. Is the ride that much different between a 315 and a 305? I think the 315 is a little more than a half inch bigger than a 305.
post #9 of 22 Old 10-10-2012, 10:30 AM
1222
RIP John
1222's Avatar
The overwhelming majority choice of gears for the 2007-2011 JKs and the combo that you want to run (35s and auto) is 5.13s. The 2012 and up JKs do not apply.
(2011-2016)
1222 is offline
post #10 of 22 Old 10-10-2012, 11:50 AM
1AAdam
most people re-gear them
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #11 of 22 Old 10-10-2012, 02:55 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
I ran 35X12.5s on the stock Rubi 4.10s. Went straight to the 5.13s after one week driving around town with a weekend run to superlift park. It sucked on highway and off the crawl was still too fast. After the 5.13s it was almost as peppy as the 4.10 with 32s - but can still feel the added weight of the tires.
When I put the 32s back on for highway use - it really gets up and goes! When they are worn I will probably shoot for 33ish for my on highway set...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
post #12 of 22 Old 10-10-2012, 11:54 PM
Tanimal
35" tires?
I run 35s with 3.73s and don't mind it around town but when I jump on the highway I hate it. Looking into 5.13s
Originally Posted by Coolcatracing View Post
+15151504501500230515023x5150101x560560400x5605050 6-3
Learning as I go and it's worth every penny!
Tanimal is offline
post #13 of 22 Old 10-11-2012, 06:39 AM Thread Starter
Fiddycals
2011 JK Wrangler
I am looking for opinions on the largest tire I can effectively run with 4.10's and an automatic transmission. Thanks
post #14 of 22 Old 10-11-2012, 07:23 AM
jstrubberg
2009 JK Wrangler
Regear first, then get new tires. You'll be a lot happier.
jstrubberg is offline
post #15 of 22 Old 10-11-2012, 09:18 AM
Tanimal
Your drivetrain efficiency starts going out the window as you get bigger tires and stay with the incorrect gear ratio. Why don't you go right to the 35 tire like YOU want and see how YOU like how your 4.10s handle it.
This is good advice! I think that gear chart is around here somewhere to tell you what gears for what tires?
Tanimal is offline
